Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 08-22-2013, 01:29 AM   #1345
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
@NIKDENG, yeah, probably.. pero the numbers are quite disappointing lang considering putting an aftermarket filter will give you the same amount of gains compared to changing the whole intake system, quite weird lol thats why i do hope that there would also be numbers regarding torque so as to see the gains as well.. i'm assuming there might be more of a difference there compared to aftermarket drop-in filters
pcuerpo is offline   Reply With Quote
Old 08-22-2013, 10:03 AM   #1346
gpac
Hi guys,
deciding on which rear spoiler to get,
5-axis or TRD?
both should be avail locally.
gpac is offline   Reply With Quote
Old 08-22-2013, 10:31 AM   #1347
ayuk
Drives: none planning to buy
Originally Posted by gpac View Post
Hi guys,
5-axis or TRD?
sir gpac, parehong maganda yan. if your plan is to go trd all the way, then trd na. if you want to be kakaiba go sa 5-axis. good luck sir
ayuk is offline   Reply With Quote
Old 08-22-2013, 11:23 AM   #1348
hanstperez
hanstperez's Avatar
Drives: Toyota 86 2013
Originally Posted by NIKDENG View Post
@hanstperez,
The price of your aero wing from the casa is actually 65,000 pesos. They sell for 35k to 40k second hand. Taiwan made replica TRD ducktails only cost 15,000 pesos painted and installed and second hand ones go as low as 5k. The quality of of the replica TRD ducktails are way-off the original TRDs in terms of fit and finish. I used to have the replica but got so frustrated as the adhesive would slowly peel off especially when they got wet that I eventually got the original one. A better swap will be with a trunk with an original TRD wing as this costs 31k from the casa + cash.
Noted. I wont make the trade then. Thank you for this.
hanstperez is offline   Reply With Quote
Old 08-22-2013, 12:46 PM   #1349
NIKDENG
Drives: RED BRZ
@pcuerpo,
Yes, I felt the same disappointment with the aftermarket air-intake systems. Some even loose power when you put them on. None of them make any torque even worth bothering with. They are for generating engine noise more than anything else but somehow the sound gets annoying at cruising speed. That's why I took mine off and went back to stock with a drop-in HKS filter. To make to most out of these aftermarket intakes would require an ECU tune and even with tuning the gains are really not significant. That's why a quick scan of the ads will show a lot of secondhand aftermarket intake systems for sale. Looks like Toyota and Subaru did their homeworks when they designed the stock intake system.
A lot of us will try to squeeze as much power from the car by putting headers, full exhaust systems, ecu tuning, lightened driveshaft, and intake systems but the most we can get for a NA setup is just close to 200whp. By the time we are done, we will have spent close to the price of a turbo or supercharger which would be the better and guaranteed options for generating more power for these cars.
NIKDENG is offline   Reply With Quote
Old 08-22-2013, 12:53 PM   #1350
NIKDENG
Drives: RED BRZ
Hi guys,
5-axis or TRD?
@gpac,
The 5-axis would be an easier install for the BRZ since you don't have to remove and relocate the Subaru and BRZ emblems on the trunk which is required if you go with the TRD. However, the 5-axis rear spoiler is harder to source locally and is usually by order only with a long waiting time. Both would look good on your car.
Old 08-22-2013, 03:23 PM   #1351
dagame
dagame's Avatar
Drives: Subaru BRZ ZC6 Lightning Red
Hi guys,
5-axis or TRD?
personally i prefer the five axis ducktail over the trd one since brz e para hindi 'poser'-ish.
the five axis ducktail is available locally? which shop has it in stock? i've been looking for that ducktail for almost 2 months, yet most shops are still "shipping" it even if 2 months have already passed
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson, Top Gear S19E3
dagame is offline   Reply With Quote
Old 08-22-2013, 08:50 PM   #1352
ayuk
still "shipping" after two months that only means nothing wil arrive in our native land. by sea it will only take 37-45 days for your shipment to arrive. well if you have the moolah, 2-3 working days by air. try to search on ebay, you might get a better deal
Old 08-23-2013, 02:24 AM   #1353
dagame
dagame's Avatar
i found a few online but i'm trying to look for it locally maybe there's a shop that already has it in stock. better for me if its already available here locally to avoid me all the hassle
Old 08-23-2013, 07:15 AM   #1354
Ojokik
Drives: Toyota 86 Silver Metallic
Meron din ba dito sa atin may cricketing issue? Is it really normal? read sa other thread na dami may ganito. Lumabas yun sa akin after less than 350km.
Dunno if kaya ayusin sa casa.
Ojokik is offline   Reply With Quote
Old 08-23-2013, 09:09 AM   #1355
dagame
dagame's Avatar
what gas are you using? if you're using v-power racing, try switching to blaze. some members have experienced it too and when they switched to blaze, the cricket sound disappeared.
Old 08-23-2013, 12:45 PM   #1356
NIKDENG
Drives: RED BRZ
@Ojokik,
I agree with @dagame, switch to Petron Blaze and your cricket sounds should disappear after all your old fuel has been used up. The reason for the cricket sound is that our injectors do not like fuels with ethanol content which all gasoline blends have except for Petron Blaze which is the only non E10 fuel left. Gasoline with ethanol content and low octane rating are the primary cause for the cricket sounds and the direct injection failures for our cars.
Old 08-24-2013, 12:21 AM   #1357
Ojokik
@NIKDENG and dagame
Thanks so much for the info. Will do that after my next fill-up. I just need to consume first almost a half tank of v-power.
Old 08-24-2013, 01:16 AM   #1358
rudolfryan
Drives: Gt 86
Just got my White Pearl Yesterday. I fell inlove with the car....
Here are some pictures...
rudolfryan is offline   Reply With Quote
