Old 05-16-2014, 01:38 PM   #1359
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
About to tackle this V3 install in the next days and going through parts check.
Received my 3.12 pulley and corresponding Gates K060966 belt and also replacing to the supplied Vortech idler pulley with 38006.
couple of questions (note, I have a used kit... hence my questions below)
1. Need to buy extension wires for the MAF. What gauge should I buy? Since the supplied ones were used with the previous owner. Don't want to spend $90 for MAF wire harness...
2. Is everyone running at least the 2.5bar map sensor, or is stock ok? I didn't have a 2.5bar sensor included. I read the manual and I think this is only for the COMPLETE kit, and not the tuner kit. Can someone please confirm I can run the stock map sensor (running stock fueling and stock pump).
Seems like I got everything else... just waiting on Vortech oil for an oil change prior to install.
sissupr is offline   Reply With Quote
Old 05-16-2014, 01:55 PM   #1360
Dezoris
Dezoris's Avatar
You will need the 2.5bar map sensor or whatever sensor the tuner recommends. The stock unit wont work.
Wiring, well someone can answer that. I believe it was 14 gauge that shipped with kit before they had the MAF extension.
Old 05-16-2014, 01:57 PM   #1361
Dezoris
Dezoris's Avatar
Originally Posted by diirk View Post
So with that said it sounds like a catch can or separator is in order.
What's the prefered setup for use with the Vortech?
Dual cans, one on PCV one on breather. The PCV side will need a quality can that can handle boost with no leaks. Breather side just needs baffles.
Old 05-16-2014, 02:47 PM   #1362
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Doesn't Vortech's instructions call for the check valve to be placed on the hose coming from the PCV to the manifold? There shouldn't be any boost going to the catch can if hooked up before the check valve.
I also have the Radium dual catch cans. After 1,000 supercharged kilometers, I inspected them and found a little bit of oil on the PCV side can. Breather side can was dry. How's yours holding up? Are you getting blow by on the breather side?
HRTROB is offline   Reply With Quote
Old 05-16-2014, 03:44 PM   #1363
Dezoris
Dezoris's Avatar
At WOT that check valve still opens, still under vacuum, so I'd make sure its a sealed system.
I had a little but very little, but I have seen several guys on here who are not so lucky and have blown oil into BOV and coated intercooler.
Could be tuning, driving habits or just some motors with less ring seal.
Its one of those impossible to know.
Old 05-16-2014, 08:55 PM   #1364
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Rob, do you have a pic of the hose with the check valve? I just want to make sure I got my catch can installed right.
Tye300 is offline   Reply With Quote
Old 05-17-2014, 12:09 AM   #1365
diirk
diirk's Avatar
Drives: 4Runner
Are there pics or a diagram I can use to plan this out?
Are there preferred units? I was looking at the Cusco. But I'd like something fairly compact. Is there maybe a 2 in 1 unit on the market?
thanks again.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 05-17-2014, 03:44 AM   #1366
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Here's a photo from the Vortech install manual:
Old 05-17-2014, 05:14 AM   #1367
lfuentes92
master boxxy driver
lfuentes92's Avatar
What oil coolers have vortech owners used and fit well?
Sent from my SM-N900P using Tapatalk
lfuentes92 is offline   Reply With Quote
Old 05-17-2014, 06:23 PM   #1368
Tye300
Tye300's Avatar
I used the Mishimoto oil cooler. The new design sandwich plate clears the vortech airbox neatly. I could not use the supplied mount though. It would not clear the intercooler.
Here's the install from my build page.
http://www.ft86club.com/forums/showp...&postcount=276
Old 05-18-2014, 06:59 AM   #1369
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Learned the hard way not to check your blower fluid levels after driving the car. Rounded off the hex hole to turn brass head of the dipstick
Calling Vortech Monday...
F1point4 is offline   Reply With Quote
Old 05-18-2014, 01:09 PM   #1370
ft86me
ft86me's Avatar
Drives: 2013 FRS
Those are expensive as fuck!!! I had to replace both of mine
ft86me is offline   Reply With Quote
Old 05-18-2014, 01:26 PM   #1371
lfuentes92
master boxxy driver
lfuentes92's Avatar
Thanks man imma pick this up soon.
Old 05-18-2014, 01:27 PM   #1372
DJCarbine
Thupercharged
DJCarbine's Avatar
I rounded off my vent plug by accident because I used a metric hex
If I ever round off the dipstick/plug I'm cutting a slot in it for a flat blade screwdriver
2013 FRS
Vortech V3 11psi
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
