Old 07-18-2013, 04:28 PM   #29
OrbitalEllipses
Drives: Attitude
while the MT requires a shift to 3rd to hit 60 (or so I'm told).
It does in fact require a shift to 3rd.
Dadhawk (07-18-2013)
Old 07-18-2013, 06:21 PM   #30
Rich@ViscontiTuning
Drives: 2012 VW GLI
You can get a semi-decent launch if you don't press the brake all the way in, but it would be hard to hold a line.
If you could get a full "clutch drop" type launch, I actually think the AT would be faster because it will do 60MPH in second gear (I've done it) while the MT requires a shift to 3rd to hit 60 (or so I'm told).
All the more reason to upgrade your ECU with V-Tune . We've got two more aggressive stages of Traction Control and we've raised the rev limit in 2nd so you can hit 60mph. This is of course in addition to several more awesome improvements for both MT and AT.
Rich@ViscontiTuning is offline   Reply With Quote
The Following User Says Thank You to Rich@ViscontiTuning For This Useful Post:
Old 07-18-2013, 06:26 PM   #31
Hardrock4445
Hardrock4445's Avatar
My theory on slow 0-60 for AT, you can only launch around 2500. An by the time you are done with a small amount of wheelspin you are smack dab in the middle of the torque dip. One advantage to AT which really saves face for this AT, you can hit 63 in 2nd gear. This completely saves face for the AT owners. If you had to add the time to shift 2-3 it would be 7+. My AT 0-60
[ame]http://youtu.be/EpAh7rRooOU[/ame]
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following User Says Thank You to Hardrock4445 For This Useful Post:
Old 07-18-2013, 06:57 PM   #32
kidgogeta
Drives: FRS
Rich do we (auto) drivers get any fun stuff like launch control?
kidgogeta is offline   Reply With Quote
Old 07-18-2013, 07:00 PM   #33
autobrz
Drives: Mazda 3
who cares about 0-60? Who drives around town launching their car from every stop?
real world driving is about 25-60 or 35-70 or 65-90.
I bet in those situations, the AT and MT are neck to neck.
autobrz is offline   Reply With Quote
Old 07-18-2013, 07:58 PM   #34
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
V-Tune definitely made a big improvement on pump, and huge on E85. You definitely still launch into the dip but it's vastly less detrimental. Pulls through the dip quick, and the 5500-7000 yank is way more pronounced. Are the more aggressive traction control options still present in the current auto tune? I thought we only had the one map at the moment. Maybe I'm just bad at making the cruise control stalk switch for me.
Nightbringer is offline   Reply With Quote
The Following User Says Thank You to Nightbringer For This Useful Post:
Rich@ViscontiTuning (07-19-2013)
Old 07-18-2013, 08:52 PM   #35
Hardrock4445
Some people do care. me personally, I don't. but its still fun once in a while.
Old 07-19-2013, 08:12 AM   #36
wparsons
wparsons's Avatar
Can't have launch control with a torque converter. The stall speed of the converter is too low to need launch control. If you push hard on the brake and floor it in D the speed the engine revs to is the stall speed of the torque converter.
Originally Posted by FRSBRZGT86FAN View Post
Hmm. Who cares about the speed, I just like the fact paddles make me feel like an F1 driver. Also maybe they will add some sort of launch control in the future, I know Ferrari's and Nissan's launch control holds first or second gear and constantly modulates the brakes for best traction and acceleration then learns the surface once you do it once making it a tenth of a second or two faster the next time you run it on that surface, maybe in the next generation?
Ferrari and Nissan have real clutches, not torque converters so they can disengage the clutch to get the revs up before launch and also modulate the clutch as part of the launch control algorithm if needed. With a torque converter you simply can't change the stall speed of the torque converter on the fly, you need a different torque converter.
flickr
Nightbringer (07-19-2013)
Old 07-19-2013, 11:02 AM   #37
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Thanks for clearing that up, but with development constantly happening with Lexus/Toyota/Subaru there shouldn't be any problem with creating a new torque converter, but it really wouldn't be worth it to shoot the price up AND a dual clutch system would also cost more.
Old 07-19-2013, 01:17 PM   #38
wparsons
wparsons's Avatar
A higher stall torque converter wouldn't cost any more up front in the development of the car, but a higher stall speed means more slippage until it locks up and more drivetrain losses. You'll never see a high stall converter come stock in a car like this.
IMO, it should have a dual clutch box for the "auto" option, even more efficient than the current auto and could add launch control.
flickr
Old 07-19-2013, 02:27 PM   #39
Nightbringer
Drives: Scion FR-S
Having a DSG variant like the GTi would be fantastic. I toyed with the idea of a higher-stall converter, but losing the "tightness" of the factory converter, it'd be vastly less enjoyable in corners and part-throttling around town. DSG is the best of both worlds, though the trans is drastically more expensive in and of itself, with the added maintenance costs all the dual clutch transmissions carry. Our shift times, shockingly, aren't that far behind many of the DCTs (without reflash). Never seen a converter transmission that'd shift this quickly on command.
Old 07-19-2013, 03:27 PM   #40
wparsons
wparsons's Avatar
^^ Keep in mind that the transmission ECU locks up the torque converter as soon as it can, even at part throttle, so if you can find a higher stall torque converter with lockup functionality and the transmission ECU could be flashed to not lock up quite so early I'm sure you could keep the current behaviour in corners and at part throttle.
flickr
Old 07-19-2013, 03:41 PM   #41
Nightbringer
Drives: Scion FR-S
That's true, I keep forgetting about the aggressive lockup. Sure do love that feel compared to standard slushboxs. I'm sure there will be a plethora of aftermarket options a few years down the road. Thanks for the info!
Old 07-19-2013, 05:05 PM   #42
Rich@ViscontiTuning
Drives: 2012 VW GLI
Yeah we've made big improvements to the torque dip, especially with our new STG2 flash for those that have upgraded the headers. STG2 is a free upgrade for anyone with STG1 and it's definitely worth checking out! As far as TC options go, those are available in both AT and MT. I'm assuming you still have V-Tune in your car right? Do you know what version you're running? It may be time for an upgrade to the calibration if you haven't done so in a while.
@wparsons did a great job of explaining the inherent limitations of the traditional automatic transmission. I wholeheartedly agree that this car would benefit tremendously from a Dual-Clutch Transmission, just like what's in the VW GTI/GLI range. However.. you may notice I happen to drive a 2012 GLI and even with VW's phenomenal DCT as an option for me when I purchased my car, nothing will ever replace a real 6 speed manual in my opinion. But that's just me
A Week of A/T Manual Shifting Mode Ocala FR-S Scion FR-S / Toyota 86 GT86 General Forum 98 05-15-2013 02:35 AM
More MPG in manual mode (AT) aceangel BRZ First-Gen (2012+) -- General Topics 11 03-27-2013 01:12 PM
AT - Failed to downshift in manual mode abutterman Issues | Warranty | Recalls / TSB 26 03-14-2013 09:11 AM
AT Manual Mode Easter Egg? whataboutbob Engine, Exhaust, Transmission 2 12-14-2012 11:03 AM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 11:40 AM
