02-24-2014, 01:58 PM | #939 |
Drives: White FR-S
We're hoping to keep the return style/swirl pot system around $1.5k or so with the flex fuel option being extra. It will include A LOT of parts, many of them custom components, for the money. The fuel system will include a Fuel Lab FPR, Walbro 485 E85 fuel pump, PnP high current wiring relay, and PnP fuel connections with the price. All of the included fuel lines and in-tank wiring will be teflon lined and E85 compatible.
We're still undecided on how we want to implement the flex fuel connection to the ECU. There are several ways to do this, so we'll likely have several wiring options available. - Toan |
The Following User Says Thank You to ptuning For This Useful Post: | cobrabyte (02-24-2014) |
02-24-2014, 02:02 PM | #940 | |
Drives: 2013 BRZ, 2002 WRX
The Following User Says Thank You to cobrabyte For This Useful Post: | ptuning (02-24-2014) |
02-24-2014, 02:08 PM | #941 |
Drives: Whiteout FRS
swirl pot = fuel sump? Like no lean condition on hard lefts??
life's greatest stories usually start with the words, "fuck it!".
02-24-2014, 02:19 PM | #942 | |
Drives: White FR-S
A surge tank and swirl pot are the same thing. However, a vertically mounted round swirl pot has side feeds for the FPR return and main tank fuel feed. This arrangement promotes a swirling action in the swirl pot/ surge tank that helps to deaerate the fuel coming back from the FPR. In addition it promotes the flow of the generally hotter FPR fuel back to the main tank and the cooler main tank fuel to feed the Walbro 485 pump housed inside of the surge tank. Hopefully this makes sense. - Toan |
The Following 2 Users Say Thank You to ptuning For This Useful Post: | JerryMichaels7 (02-24-2014), SmsAlSuwaidi (02-24-2014) |
02-24-2014, 03:11 PM | #943 |
yep, lol a yes would of been good enough, but i like the detailed answer too. Gonna get all the supporting goods this year and hopefully next year i can pull the trigger...WTB HEADER W/FULL VBAND EXHAUST
02-24-2014, 03:25 PM | #944 | |
Seems Legit
Drives: Toyota
Toan, have you experienced the same issue with the FRS below half a tank? Just wondering if it's an area of concern, primarily the lean condition, for those who daily drive or mainly a track application.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
02-24-2014, 03:29 PM | #945 |
there are some old threads that mention it happening to the FRS
02-24-2014, 03:35 PM | #946 | |
Seems Legit
Drives: Toyota
I understand that but my question isn't really if it'll happen but in what conditions (track, dd, etc) is it most likely to occur.
02-24-2014, 03:48 PM | #947 |
Yeh sorry, the issue was hard lefts on tracks below i think 1/2 or 1/4
02-25-2014, 02:55 AM | #948 |
Drives: 23 BRZ
Have you ever seen an MV Agusta motorcycle disassembled? The mechanic gets to see beautiful works of art as he takes it apart. This photo reminded me of how PTuning is also proud of their work and takes their time to make parts look as good as they work.
02-28-2014, 11:19 AM | #949 |
Drives: 2013 Scion FRS
Bump More Info Coming Soon
The Following 3 Users Say Thank You to Events@Ptuning For This Useful Post: |
03-07-2014, 03:20 PM | #950 |
Drives: White FR-S
Another dyno sheet. '13 FR-S owned by one of our sales staff.
Still zeroing in on the perfect tune for the midrange. We now have over 200WTQ from about 3,200 rpms to 8,000 rpms. Not too shabby. 93 pump gas at 11 psi. PTUNING Spec-SS GT3076R Turbo System w/stock header PTUNING DS-333 3-inch Dual Exhaust System. PTUNING Fueling Package - Map Sensor and FIC 770cc injectors |
The Following 7 Users Say Thank You to ptuning For This Useful Post: | bjun (03-07-2014), Eurasianman (03-07-2014), kanundrum (03-07-2014), kayhettin (03-07-2014), mkivsoopra (03-08-2014), rb6freak (03-07-2014), Sonolin (03-07-2014) |
03-07-2014, 04:34 PM | #951 | |
Drives: 2013 Black FR-S
The Following User Says Thank You to sw20kosh For This Useful Post: | kanundrum (03-07-2014) |
03-07-2014, 09:38 PM | #952 |
Drives: White FR-S
Now that we have a second shop car running just our base turbo set-up, this shouldn't be a problem. I'll check my dyno schedule for next week and see if I can squeeze in a 91 octane dyno tuning session.
- Toan |
Tags |
over 9000, ptuning, turbo kit |
Similar Threads | ||||
FA20CLUB.com Turbo Kit Sneak Peek.... | FA20Club.com | Forced Induction | 98 | 12-14-2013 01:34 PM |
Sneak peek at new 57Xtreme? | vividracing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-07-2013 02:24 PM |
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. | P&L Motorsports | Forced Induction | 179 | 01-31-2013 07:32 PM |
AFE PROTOTYPE EXHAUST: SNEAK PEEK! | autofashionfred | Engine, Exhaust, Transmission | 20 | 08-13-2012 01:22 PM |
Tsukuba Circuit BRZ/FRS showdown Sneak Peek | AVOturboworld | BRZ First-Gen (2012+) -- General Topics | 19 | 06-23-2012 11:13 AM |
