Old 05-05-2014, 09:17 PM   #1
TTGT
TTGT's Avatar
Drives: 2013 Whiteout FRS
Extreme drop
Fixing to order a set of bc extreme drop coilovers.Plan on maxing them out on drop. What else are you aggressive wheel guys using? Lca or better to go with uca? And what else would u guys recommend? Spring rates?
TTGT is offline   Reply With Quote
Old 05-05-2014, 09:19 PM   #2
dbrandt01
Drives: none
I'm on stock wheels. LCAs are a most. I need them bad, but I'm waiting til I buy new wheels to get them. I chose 8k spring rates. While I am what some people claim as slammed, but only dropped 2 1/4". I'll raise it up an inch whenever I get wheels. I have pics if you want, just ask
dbrandt01 is offline   Reply With Quote
Old 05-06-2014, 07:53 AM   #3
TTGT
TTGT's Avatar
Yes, post pic if u could.
Old 05-06-2014, 11:33 AM   #4
dbrandt01
Drives: none
This is why LCAs would be good
The Following User Says Thank You to dbrandt01 For This Useful Post:
TTGT (05-13-2014)
Old 05-08-2014, 05:26 PM   #5
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
It depends on what you want to achieve.
Extreme Drops are great. I'd highly suggest getting them with Swifts, they greatly
improve ride quality. Anything around 10k is a pretty good spring rate. In general,
all of the coilovers around the $1k price range are pretty much the same. They will
all most likely have clunking from the sway bar end links, and dampen pretty much
the same. Extreme Drops will go the lowest out of the bunch though.
If you want to fit aggressive wheels, I'd suggest UCA's first, if you want to remove
camber, LCA's would be a good choice.
moomoopanda is offline   Reply With Quote
The Following User Says Thank You to moomoopanda For This Useful Post:
TTGT (05-13-2014)
Old 05-08-2014, 07:59 PM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
I would suggest PBM LCA, they have massive camber adjust ability and at a great price. The shop that did my alignment was surprised how much camber I can get out of them.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 05-08-2014, 09:13 PM   #7
dbrandt01
Drives: none
I looked at them, they're the same price as SPC. But their site says out of stock. Where did you get them?
Old 05-08-2014, 09:16 PM   #8
WolfsFang
Scrape Master
WolfsFang's Avatar
only place is their site, SPC maxes out a -2 camber while PBM LCA can go far more, so far im at -3.
The Following User Says Thank You to WolfsFang For This Useful Post:
dbrandt01 (05-08-2014)
Best price Bc extreme drop coilovers? TTGT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-01-2014 11:42 AM
bc coilovers extreme drop mrharry Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-17-2014 06:00 PM
Bc extreme drop kit Cu0ngsayz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-03-2014 10:06 PM
BC Racing Extreme Drop Coilovers 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 10-16-2013 11:42 AM
WTB: BC Br Extreme drop WolfsFang NY / NJ / CT / PA 4 06-29-2013 04:19 PM
