Old 05-10-2014, 09:51 AM   #15
Ryan P
Thanks everyone, I appreciate the help. Hopefully I can wrap this thing up this weekend and go get her tuned.
Ryan P is offline   Reply With Quote
Old 05-10-2014, 02:26 PM   #16
kingkai23
Drives: 13 swp limited
Whats the best source for vacuum for bov and wg i assume its the brake booster line if so is it idea to run a vaccum block? My jdl kit should be here soon
kingkai23 is offline   Reply With Quote
Old 05-10-2014, 09:29 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I prefer the PCV line next to the brake booster line on the back of the intake manifold, but it depends on whether or not you are running a vented catch can. I definitely prefer the vacuum block.
Sportsguy83 (05-10-2014)
Old 05-10-2014, 10:00 PM   #18
kingkai23
No catch can yet no boost guages either yet
Old 05-11-2014, 09:07 AM   #19
Ryan P
I tapped the compressor housing which feeds the vacuum block.
Sent from my SPH-L710 using Tapatalk
The Following User Says Thank You to Ryan P For This Useful Post:
Sportsguy83 (05-11-2014)
Old 05-11-2014, 10:39 AM   #20
Ross
Drives: 85 corolla gts
The compressor hosing is only good for boost reference for boost control. For a boost gauge and bov you need to use ported vacuum from the intake manifold
Ross is offline   Reply With Quote
The Following 2 Users Say Thank You to Ross For This Useful Post:
Ryan P (05-11-2014), Sportsguy83 (05-11-2014)
Old 05-11-2014, 11:57 AM   #21
Ryan P
Noob status
rerouting .... thanks hahaha
Old 05-11-2014, 02:57 PM   #22
kingkai23
What are guys using for vaccum block (brand) wise or does it really matter
Old 05-11-2014, 03:14 PM   #23
Ryan P
Vibrant, it shouldn't really make a difference though. That particular brand just so happened to have a vacuum manifold on sale when I purchased it.
Old 05-11-2014, 10:52 PM   #24
Ross
I typically just make them out of fuel rail stock when I need them.
The Following User Says Thank You to Ross For This Useful Post:
Ryan P (05-12-2014)
Old 05-12-2014, 04:53 PM   #25
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Vacuum for the BOV can be sourced at the purge valve port under the IM (if you are deleting your purge valve).
JDLAutoDesign is offline   Reply With Quote
Old 05-12-2014, 08:48 PM   #26
kingkai23
Thanks last ? Then i should be good where on the oilpan is the best location for drain all of the pictures of jdl kit i couldnt see where people tapped it at
Old 06-23-2014, 09:27 AM   #27
Ryan P
Fa20club strikes again.... the EcuTek license I had purchased in November prior to parting out the kit was never purchased by Toni from EcuTek. It's registered to Fa20club but without a license.... I'm more than annoyed right now, the only advice EcuTek offers is to contact Toni. I have reached out to him but based on prior experiences I won't be hearing back. Who know's I might luck out but I'm not holding my breath, anyone else have any suggestions so that maybe EcuTek will light a fire under his ass or something?
Old 06-23-2014, 10:29 AM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Probably the best you can hope for is seeing if you can get EcuTek to offer you a license for a reduced cost from another tuner. I know @Visconti, @nelsmar, and @jamesm have good relationships with EcuTek.
YES! finally here! :) HELP Obja Scion FR-S / Toyota 86 GT86 General Forum 58 09-07-2012 01:30 PM
Finally here!! _F-R-S_ Scion FR-S / Toyota 86 GT86 General Forum 3 08-26-2012 11:13 AM
Finally got my FR-S :)))) Carban Scion FR-S / Toyota 86 GT86 General Forum 9 08-25-2012 08:26 PM
She's finally here :) wawro569 Scion FR-S / Toyota 86 GT86 General Forum 21 07-25-2012 10:07 PM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
