Old 03-11-2016, 03:11 PM   #71
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
Originally Posted by sw20kosh View Post
This thing needs a better tune... That's all. Many people have made 200-215 whp on ACE header and e85. There is no reason this turbo kit should be making that low of a number on dynojet.
Yup, will be getting it tune soon. Just got a quote from WORKS regarding the flex fuel kit and custom tune. Will keep everyone posted on that.
Mr_YUzU_FRS is offline   Reply With Quote
Old 03-27-2016, 05:52 PM   #72
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
What I'm curious about is that on the website they state "Expect gains of ~90 hp, ~90 ft-lbs crank on 91 octane (R+M)/2 gasoline
~55% power increase over stock"
Is it because of the carb tune? So another map on Ecutek could get you those gains? I've had my eyes on this turbokit for a while and I'm hoping to get it sometime, I just hope the numbers on the website are good.
nova.86 is offline   Reply With Quote
Old 03-27-2016, 07:31 PM   #73
Bykov
Drives: 2014 Monogram FR-S Whiteout
All these people bashing on a CARB legal turbo in California for it's cost.... google what it costs to get CARB certified and what it costs to get caught on the streets not running a CARB tune.... it's cheaper to get a DUI in Utah @_@
Maybe not the best choice outside of Cali but in Cali if you want a turbo it would be silly to go with anything else. I lived in Sacramento for over 10 years and it sucked because you always have to "pay to play" whether we are talking about turbo kits or groceries...
I even bought a CARB legal SC just to not have my car taken away from me when I decide to visit family in California because they will pull you over for not looking American enough (I am not American) and the CHP is pretty hostile.
Bykov is offline   Reply With Quote
The Following 5 Users Say Thank You to Bykov For This Useful Post:
86kahl (04-13-2016), DAEMANO (10-22-2017), FRSBRZGT86FAN (04-13-2016), mad_sb (04-13-2016), VMRamos (04-13-2016)
Old 04-13-2016, 12:06 AM   #74
ihmcguinness
Drives: 2016 Series.HyperBlue BRZ
Any update after E85 and additional tuning? Did getting away from the CARB tune yield any better results?
ihmcguinness is offline   Reply With Quote
Old 04-13-2016, 05:28 PM   #75
ATaraxias
Drives: 1994 Geo Metro Hatchback
Talking
Originally Posted by Mr_YUzU_FRS View Post
Ok here it is! The dyno is done on a Dynojet at a S&N Motorsports in Elk Grove near me.
Max whp = 202
Max Torque = 188
Also with this dyno shows weather condition per run and max AFR.
Remember what I said in the start of this post, I am just trying to give this kit a fair review and already stated reasons why I went with this kit. I believe there is still a lot of room for a more aggressive tune but that will be for another day.
If you want, I'll take my full bolton E85 AT down to S&N this weekend and see if your 7K turbo is faster. If anything, it will make it a real "heartbreaker dyno" to see a turbo'ed MT with less power than a n/a AT.
Edit: S&N is busy this weekend, will have to do it the following one. They have a great price on dynotime, nice guys to chat with too.
ATaraxias is offline   Reply With Quote
The Following User Says Thank You to ATaraxias For This Useful Post:
continuecrushing (04-13-2016)
Old 04-13-2016, 05:44 PM   #76
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
OMG THIS PLEASE!!!!
Old 04-13-2016, 05:56 PM   #77
ATaraxias
Originally Posted by Shutter View Post
OMG THIS PLEASE!!!!
3+ runs for well under a hundred dollars and I finally get a number other than my buttdyno. Should have results posted by the end of April.
Old 04-13-2016, 06:48 PM   #78
mad_sb
Drives: 2013 Asphalt FR-S
I was looking at that too, torque maxed out really early then a big drop and up again. Maybe an expert or someone with more knowledge can explain why. Is it the tune or something else?
boost spike followed by boost fluctuation (overshoot / undershoot)
Old 04-13-2016, 07:03 PM   #79
mad_sb
Can anyone knowledgeable explain to me how my AFR map looks? The tech said it looks like a stock turbo AFR map similar to that of wrx, stis, evos and that its more on the safe side.
Looks nice and conservative, a bit leaner than most stock turbo factory tunes cars (because most stock tunes on factory turbo are silly rich up top) but nothing to be worried about since your right in the mid 11's.
Do you have a boost gauge or anyway to log boost? Depending on the tune you may be able to squeeze another 20 or 30 whp out of it with just a boost controller and some logging. But, DO NOT turn up the boost without being able to log knock, afr, timing at a minimum.
Old 04-14-2016, 12:39 PM   #80
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I'm sorry...
202 on a dynojet is pathetic. E85 will get you to that...
What are some baselines on that dynojet that you ran on?
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
ATL BRZ (04-14-2016)
Old 04-26-2016, 01:24 PM   #81
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Delicious Tuning Flex Fuel for @Mr_YUzU_FRS.
E60 tune:
WORKS is offline   Reply With Quote
The Following 3 Users Say Thank You to WORKS For This Useful Post:
DAEMANO (10-22-2017), sroby (02-03-2019), yourboyvic (12-03-2018)
Old 06-23-2016, 11:17 PM   #82
DHitHim
Drives: 2015 CWP Limited BRZ
Works should just come out with a non complaint turbo upgrade. Yes it's not CARB legal but at least the owner has the CARB sticker. Also with a turbo upgrade for this kit, maybe these haters would shut up w their bench racing. At least works stepped up and offered a carb complaint kit. The thing is, after that carb sticker you can tweak some of it. May not be carb complaint but sometimes small non complaint mods slip through the cracks On a visual.
DHitHim is offline   Reply With Quote
Old 06-23-2016, 11:23 PM   #83
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
That will all be up to the owner, really ain't much to change that you can't just get in the aftermarket, only thing holding this kit back are the headers and the down pipe/front pipe design
SC10N driver
StegaDragon is offline   Reply With Quote
Old 09-11-2016, 05:04 PM   #84
Flow
Drives: DGMBRZ
Jarrett gave me a test ride in their shop car when I was having some light work done at their shop. I was very surprised at the seeming total lack of lag, and very impressed with the power and its smooth delivery. While I feel its too much power for my use case - mainly daily driver where I want more power for merging, on-ramps, and the twisties I somehow always seem to find myself on - given the lack of availability of the Phantom ESC, and the Carb cert, I am really considering this solution. (That's it - no #'s, dyno jets, just thoughts and a testimonial from some guy)
Flow is offline   Reply With Quote
WORKS Stage 2 Turbo Kit - Now CARB Compliant/SMOG Legal WORKS Forced Induction 415 10-16-2021 05:55 PM
Works Axle Back Muffler Review (Works ABM) ButeraFRS Engine, Exhaust, Transmission 16 03-15-2018 06:23 PM
WORKS Stage 2 Turbo Kit - Official Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 89 01-13-2017 04:41 PM
CARB Compliant WORKS Turbo Kits - Now Available! 50-State Smog Legal! WORKS Forced Induction 47 01-13-2017 04:40 PM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
