Member's Car Journals Car journals by our members. |
06-14-2016, 05:04 PM | #85 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
I would enjoy seeing a full tilt NA build. Logically, unless you are building to some class rule or to break some arbitrary record, it's dumb, but from an emotional and freak factor, the purity of and likely sweet sounds of a NFG NA are a wonderful thing. Push the displacement to within a millimeter of it's life, lighten the rotating assembly to the max so it winds up quick and throw some dual downdraft sports injection bodies on it with tuned trumpets dumping through a properly engineered manifold and exhaust, mmm. Imagine those sounds bouncing off the canyon walls while you try to keep the car from physically doing the same.
The Following User Says Thank You to themadscientist For This Useful Post: | justatroll (06-14-2016) |
06-14-2016, 05:06 PM | #86 | |
Drives: Full race 4cyl boxer
I wonder WHY he would decline such a public validation of his superior engineering skills???? |
08-31-2016, 04:59 PM | #87 |
Driving Coach
BREAKING: This car just put down 195whp on E85 at Moto-East's dyno with 40 degrees of timing on the existing tune.
Ram air torque surges courtesy of the Speed Genius intake Last edited by ATL BRZ; 09-01-2016 at 12:54 PM. |
The Following 11 Users Say Thank You to ATL BRZ For This Useful Post: |
09-01-2016, 12:27 PM | #88 |
Drives: 2013 Brz C38 (bought not built :P)
Yep he finally took up my offer i had organized with phil at moto east. I lol'd a whole lot qhen i heard that.
Sent from my SGH-M919V using Tapatalk |
The Following User Says Thank You to fumanchu1 For This Useful Post: | raven1231 (09-01-2016) |
09-01-2016, 12:49 PM | #89 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
He will come up with some elaborate reason it didn't make his 221 whp
09-01-2016, 01:59 PM | #90 |
Drives: 2013 silver BRZ
I'm excited for this, bring on the popcorn guys
The Following 2 Users Say Thank You to jaymannj For This Useful Post: | brandonblt2 (09-01-2016), raven1231 (09-01-2016) |
09-01-2016, 02:08 PM | #91 |
Drives: 2013 Ultramarine FR-S
The reason on his facebook is because it was "Hot and Humid AF"
09-01-2016, 02:08 PM | #92 |
Drives: 10 Series #974 6m/t
09-01-2016, 03:06 PM | #93 |
Lmao! Of course!
The Following User Says Thank You to weederr33 For This Useful Post: | raven1231 (09-01-2016) |
09-01-2016, 03:45 PM | #94 |
Drives: 15 BRZ LTD, 05 FXT
I wonder if moto east can dig up a stock pull from comparable weather.
09-01-2016, 03:57 PM | #95 | |
I Love custom Turbo kits
Drives: Limited BRZ
This pull was done on a dynojet, which does not have many manipulation parameters available and is the standard for like for like comparisons.... About humidity and heat, I dynoed my car under a roof on high 70s breezy weather and it made 552 whp. Dynoed it a different day at 99 degree weather, under the sun and 90+ humidity and it made 533 whp which is 3.4% less... so yea....
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Carlos_M (09-02-2016) |
09-01-2016, 03:59 PM | #96 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
Look at them torque dips!
09-01-2016, 04:51 PM | #97 |
Sporadic Member
Does someone want to explain what really happened here? Mike Brz claimed that something kicked up from the track and somehow struck his crank and idler pulley (lol) and shot through his hood.
I doubt that something could have just shot up from underneath his engine bay, unless maybe he removed the skid plate? |
09-06-2016, 04:52 PM | #98 | |
The Following User Says Thank You to fumanchu1 For This Useful Post: | KR-S (09-06-2016) |
Similar Threads | ||||
Simmons BRZ Autocross Build, w/JSC Speed | Simmons | Tracking / Autocross / HPDE / Drifting | 283 | 03-29-2014 10:42 PM |
Audio genius needed... | Shit Luck | Electronics | Audio | NAV | Infotainment | 36 | 06-05-2013 06:09 PM |
Some genius scratched my car | Wally Simmonds | AUSTRALIA | 17 | 04-25-2013 11:31 AM |
