Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
01-01-2017, 06:28 PM | #1 |
Drives: scion frs
Tire questions
I recently purchased winter tires after learning my lesson from last winter. I went with the champiro ice pro 235/45/17 mounted on the OEM wheels.
What psi should I inflate them? I currently have them at 33psi but it seems kinda low. Also, do all FRS have the same TPMS codes? I bought some aftermarket wheels from a member and it came with the TPMS. Sent from my iPhone using Tapatalk |
01-01-2017, 07:05 PM | #2 | |
This thread may shed some light on your TPMS question: http://www.ft86club.com/forums/showthread.php?t=82211 humfrz |
01-01-2017, 08:24 PM | #3 | |
Drives: scion frs
I'm still confused about the tpms. The person who sold them to me, said that he copied the oem codes to the aftermarket wheels. Now do all wheels have different codes compared to other FRS cars? Sent from my iPhone using Tapatalk |
01-01-2017, 09:03 PM | #4 | |
Only happy when it rains.
Drives: series.blue
As for pressure, definitely go higher. I pumped mine up to 40 because it made them feel better on dry pavement. But it depends on how you want them to feel and what the max pressure for your tires are. |
The Following User Says Thank You to why? For This Useful Post: | zman (01-01-2017) |
01-01-2017, 10:26 PM | #5 | |
Drives: scion frs
What size tires do you have Sent from my iPhone using Tapatalk |
01-01-2017, 10:31 PM | #6 |
Drives: series.blue
01-01-2017, 10:53 PM | #7 |
Drives: 2017 BRZ
Lower pressures can be helpful if it is icy/snowy, but it can be OK to go up some for between crap. They'll always be squishier, and always be less performant in dry/wet. I run 36psi and drop it if needed.
The Following User Says Thank You to cjd For This Useful Post: | zman (01-01-2017) |
01-04-2017, 10:33 PM | #8 |
Drives: scion frs
I drove it today and it definitely needs more air. The car wiggles a lot and the abs kicks in a lot while making turns . Not sure if it's the tire size or warm weather.
01-06-2017, 07:35 PM | #9 |
Drives: series.blue
it is the lack of traction. Winter tires have less traction than stock. The only time I've ever had the traction control kick in is when I have winter tires mounted. I even managed to do a 4 wheel drift in the rain on an on ramp with the stock tires and traction control acted like it was normal and nothing to worry about.
01-06-2017, 07:47 PM | #10 | |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
NARFALICIOUS
Noob Poster 1988 | 2016 |
01-06-2017, 07:51 PM | #11 |
Drives: scion frs
01-06-2017, 07:58 PM | #12 | |
Site Moderator
Drives: ichi 86 Project
As for car wiggling is due to soft wall, it's something that need to get used to, but it's somewhat common in winter tires. As for ABS kicking it, it's your driving. Gotta learn summer driving and winter driving |
The Following User Says Thank You to ichitaka05 For This Useful Post: | zman (01-06-2017) |
01-06-2017, 08:12 PM | #13 | ||
I am running the Champiros as well and they have a very aggressive tread that will walk through the worst ice and snow thrown at them but are not fond of warm, dry conditions. Don't go nuts with the pressure since they get even more squirrely if to high. I stick to 34PSI.You will get used to them. They are a surprisingly good tire for the price.
The Following User Says Thank You to Tcoat For This Useful Post: | zman (01-06-2017) |
01-06-2017, 08:29 PM | #14 | |
Drives: scion frs
Yes I do drive a bit hard. Also, I noticed that it was very dangerous going over 70 as the car was very unstable. Sent from my iPhone using Tapatalk |
Similar Threads | ||||
Tire Rotation Interval Questions | HunterGreene | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 11-03-2016 09:40 PM |
Wheel/Tire Questions Regarding Width | Strife26 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 04-04-2016 01:09 PM |
Winter Tire questions 2015 FR-S | Sapper211 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-03-2016 03:14 AM |
Tire questions | Thataznguy001 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 01-03-2015 06:55 PM |
Couple tire/wheel questions | Jayde | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-19-2012 02:18 PM |
