Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
04-20-2017, 05:29 PM | #1 |
Turtle Factory
Drives: Mint M3
1987 GTS- FINAL EDITION
Do non FRS/BRZ/86 Builds have a home here?
Well I guess that my 8th AE86 was bound to be a special one. I have been looking for a clean Hatch for a while. I have had 4 Coupes and 3 hatches, so why not get a hatch for number 8 and even things out. I searched far and wide, and eventually found the cleanest of them all right in my backyard! Here are some pics. I may or may not type up the mod list, but I have 33 pages of receipts, so I may forgo all of that. The car is still nameless, but here she is: 1987 GTS White Unknown miles, but probably a lot. List of Upgrades: Odyssey Battery PC 680 Quarter Master Clutch unit with Disc Slip Yolk U Joint 1310 Tube Yoke 2-28-277 Flywheel 407401-11 Quaife Sierra Sequential 5 Speed Gearbox Tow Hook Wheel Key Diff Bearings M86649 Diff Bearings M86610 Diff Bearings M88649 Diff Bearings M88610 Diff Seal #14750 Drive Shaft Steady Bearing Quaife Bellhousing Adapter Circuit Sports Magnetic Drain Plug Kumho V710 205/50/15 Race Tires CS Fuel Pump BE 131-2085 Water pump Pertronix Flame Thrower 2 Coil M1157, 1156 Bulbs, 89F Mizu R AE86-83 Toyota Aluminum Rad Mizu FS-AE86-83 Fan Shroud Assembly Kumho V710 205/50/15 race tires T3 Rear Traction Brackets Whiteline BTF35Z Front Swaybar Whiteline BTR25Z Rear Adjustable Swaybar PDM Front and Rear Endlinks BOSCH SBQ200 Headlights Genesis Battery, Odyssey Terminals Greddy Shift Knob 14510501 7 Rib Red Top 4AGE Engine Tomei Cams Tomei Cam Gears Clear Cam Gear Cover Not sure what else (No engine build receipts available) PIAA 95040 Silicone Wiper PIAA 95050 Silicone Wiper PIAA 95045 Silicone Rear Wiper CS Coolant Tank Reservoir NTK 24105 02 Sensor 2.5" 304 Stainless 90 degree bend Vibrant 2630 2.5-3" Transition 3.0 304 stainless 90 bend 3.0 304 Straight K&N RE0930 Air Filter Synthetic Power Steering Fluid Open end Spline Lugnuts T01B Fuel Tank BE 173-7904 Ignition Rotor Tire valves Argon Filler Rod BE 052-3001 Front Pinion Seal Papco M12 x 1.5 52mm Extended wheel studs M8 X25mm bolts M6 X16 bolts M8 Flat Washers RCI Camlok Race Bolts Techno Toy Tuning Front AGX Coilovers Techno Toy Tuning Rear AGX Coilovers Tecno Toy Tuning Front Camber Plates Hawk HB203N550 Rear HP+ brake pads Misc interior pieces Moog K9320 Steering Rack Boots Dayco 5050325 Belt Dayco 5050360 BE 131-2011 Water Pump BR1 Front Outer Bearings BR8 Front Inner Bearings 16032 Front Wheel bearing Seals 88506BR Rear Wheel bearings 514000 Rear Wheel Bearings 1955 Rear Wheel Seals BR35 Rear Diff Bearings HM88649 Axle Pinion Seal HM86649 Rear axle Pinion Seal UEO STYLE Tension Rods UEO STYLE Inner Tie Rods UEO STYLE Front Control Arms UEO STYLE Lateral Rods UEO STYLE Outer Tie Rods UEO STYLE Rear Traction Kit 4 Link Cusco 1.5 Way LSD CG Locks Nissan Nagisa Seat Rails Sparco Rev+ Seats Paint and Body Work Clutch Alignment Tool Slave Cylinder Clutch Master Bearing and spacer work Engine Insulator Bolts and Nuts C0TRC-17141-12 TRD JIC ae86T1-S Bullet 505 Type 1k- Exhaust Adjustable Aleternator Brackets Redline Tails KOUKI JDM Bumpers, brackets, lights, badging XXR Wheels (I dont think anyone else makes these monstrosities) Full Welded Cage Harnesses Sparco Monza Steering Wheel And plenty of other stuff I am sure I am missing... Last edited by Tanuki; 05-08-2017 at 06:49 PM. |
The Following 13 Users Say Thank You to Tanuki For This Useful Post: |
04-20-2017, 07:44 PM | #2 |
Drives: 14 Ultramarine FR-S
Sweeeeet - could probably move it to "Member's Car Journal" sub-forum.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD |
The Following User Says Thank You to Phantobe For This Useful Post: | Tanuki (04-21-2017) |
04-21-2017, 04:08 PM | #3 |
Turtle Factory
Drives: Mint M3
04-21-2017, 04:11 PM | #4 |
Drives: 2021 Toyota Supra 2020 4Runner
Story time:
This reminds me of when I found a 78k mile AW-11 (1989 N/A)about 10 miles from my house. White with blue interior, manual with a hard top. I loved that car, and I eventually sold it...and I still regret selling it. Moral of the story: Don't sell this car...you will never find one this good again. Great find! |
04-22-2017, 12:59 AM | #5 | |
Turtle Factory
Drives: Mint M3
Here is my last one I sold: |
04-22-2017, 01:18 AM | #6 |
Drives: GR Corolla
Very nice, clean unit. Was it stock when you got it?
04-22-2017, 01:38 AM | #7 |
Turtle Factory
Drives: Mint M3
The Following User Says Thank You to Tanuki For This Useful Post: | Kaotic Lazagna (04-22-2017) |
04-22-2017, 09:20 AM | #8 |
Drives: frs
Any future plans for it?
04-23-2017, 03:41 PM | #9 |
Turtle Factory
Drives: Mint M3
05-08-2017, 12:00 PM | #10 |
Turtle Factory
Drives: Mint M3
The Following 2 Users Say Thank You to Tanuki For This Useful Post: | daiheadjai (05-10-2017), Tcoat (05-08-2017) |
05-08-2017, 12:15 PM | #11 |
Last Starfighter
Drives: 2016 FR-S Series 2.0
Beautiful! I'd still love to pick one of these up.
05-08-2017, 06:13 PM | #12 |
Turtle Factory
Drives: Mint M3
05-08-2017, 06:14 PM | #13 |
Last Starfighter
05-08-2017, 06:21 PM | #14 |
Turtle Factory
Drives: Mint M3
Similar Threads | ||||
1987 E30 BMW 325is, full suspension refresh, GC coilovers, much more | PR138 | Cars for Sale/Trade | 2 | 11-26-2016 08:22 PM |
Help please.. Looking to get Nameless ... | Mikem53 | Engine, Exhaust, Transmission | 15 | 11-28-2013 01:06 PM |
Nameless | Admired | Engine, Exhaust, Transmission | 40 | 07-20-2013 02:31 PM |
AE86 vs AE82: 1987 BTCC | OldSkoolToys | Other Vehicles & General Automotive Discussions | 8 | 05-10-2011 03:26 AM |
