Old 05-08-2017, 12:12 PM   #29
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by GrimmSpeed View Post
Should be a cool comparison once you get the GrimmSpeed intake back on. Back when we tested our prototypes against a silicone inlet+ K&N panel filter we saw a couple more ponies in the midrange, and a bit more torque. I really feel like the area that our intake makes power is going to compliment where the 2017 manual cars are making power. Should probably produce a little bit more power in those areas too, so we'll see!
Very few people look at directions anymore, but please make sure to do so with our intake. The most important point is if you put the filter onto the intake tube too far the tube will stick past the venturi on the filter, and give some weird airflow readings. During our dyno testing the difference between a filter that was on too far, and one that wasn't was substantial. I know you said your tuner saw some MAF scaling issues, so you'll want to be sure that you just do not put the filter on the end of the tube farther than 1in MAX. I usually do about .75in, and keeping the filter as straight on the tube will help some too. Should be a cool test!
Chase
Engineering
When I installed it the first time, I broke out the tape measure to make sure it was in the right spot I will make sure to be precise with it this time too.
I already let my tuner know of the change and re-dyno. He wants to see the logs before we put it back on the dyno, to see if anything changes again with the MAF.
Swapping the intake over tonight then I'll dyno again later this week.
Thanks!
justinco is offline   Reply With Quote
Old 05-08-2017, 12:21 PM   #30
imnotsureaboutbrz
Drives: between cars...
Originally Posted by nikitopo View Post
I will have to disagree on this. Please be aware that the newer changes didn't pass the emission tests in Europe and the manufacturer is selling now the revised models with the old engine (MT & AT). I would say that they felt some pressure to provide more power and tried their best even though they were aware that they'll cross the limits in certain regions.
Originally Posted by D_Thissen View Post
I didn't know that either but according to the brochure on toyota.nl, both auto and manual cars have 147kw (~200hp).
https://www.toyota.nl/brochures/gt86-brochure.json
See now that makes sense... I've been watching all these 2017 brz/86 review videos from europe (UK mostly) and wondered why they didn't have the red intake when they popped the hood...
imnotsureaboutbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to imnotsureaboutbrz For This Useful Post:
D_Thissen (05-08-2017), nikitopo (05-08-2017)
Old 05-09-2017, 02:48 AM   #31
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by justinco View Post
Interesting results from my dyno session with the 2017 car. Largely the same as my 2013 FRS, but with some differences. Primarily, the 2013 FRS made less power stock, while the 2017 BRZ made more power stock. However, peak power was nearly identical between both cars. I was hoping the 2017's would gain more overall, but it looks like they are pretty efficient from the factory compared to the old cars and end up almost the same when you have similar upgrades.
2017 peak power, 91oct street tune: 182hp/147tq @ the wheels (altitude corrected).
Details in the video.
I am accepting such dyno results with a salt of grain. The information here is contradictory to other evidence. Check here: http://www.ft86club.com/forums/showthread.php?t=118320
The real difference of the older stock cars ('13 - '16) with the '17 cars is 5 hp. Additionally, you're saying that the bolt-ons and tune on the new car gave minimal peak gains. If we subtract the 5 hp difference, then I would expect that the peak gains of the same parts on the old car to be also minimal.
My overall point is that the argument "the old cars were not efficient from the factory" is nonsense. It was just a big greenfield for the aftermarket scene and some vendors exaggerated the results for their own benefit with specific products.
Old 05-09-2017, 08:15 AM   #32
Teseo
Drives: frs
13' stock tune sucks ass. Rich on the top and lumpy on idle
Old 05-09-2017, 08:41 AM   #33
steve99
Drives: FT86
Heres a log of this guys 2017 stock brz
http://www.datazap.me/u/justinco/201...-2-4-7-9-10-11
Now you will notice two things
1. It doesn't run pig rich like the older cars, 2017 12.5 AFR, the older cars ran down into the high 10 AFR like 10.8
2. The STFT is still active all the way to redline at WOT , ie its running CLOSED loop all the way. This equals better AFR control. The old tunes went OPEN loop fuelling after a short period of WOT.
Around 12 is what most tuners leaned out the old tunes to get a bit more power higher rpm if the fuel was good enough.
In the new tunes its already done so its likely to limit gains you can make with tune alone. Which this guys before and after dyno appear to show.
The 2017 ECU software has changed not just the setting in tune tables.
They have completely revised the fuelling strategy, its much more complex than the old fuelling logic, additional fuel tables and changed logic and runs closed loop almost all the time.
They also have two timing and fueling maps/modes in the ZA1JKxxx roms.
The Following 7 Users Say Thank You to steve99 For This Useful Post:
200hp/tonne (05-09-2017), FRSBRZGT86FAN (06-25-2018), invaliduser (05-09-2017), justinco (05-09-2017), phm14 (05-11-2020), Prodigalson (09-15-2018), sato (05-16-2017)
Old 05-09-2017, 09:24 AM   #34
wparsons
wparsons's Avatar
The factory claim is 5hp, real world dynos show more like 10-15whp more stock vs stock on the same dyno in similar conditions. The <=2016 were a bit overrated on power, the 2017's are more true to the claimed hp.
The tunes on the original cars were rushed, and it showed in many ways. The 2017's have a much more refined tune.
@justinco just goes to show how poor the factory exhaust manifold and tune of the first gen 86's were. It would be interesting to see auto-x times between your old frs and new brz though.
Enough that the new ones are a class higher than the earlier cars.
It's the same engine, just different manifolds and tunes.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
D_Thissen (05-09-2017), justinco (05-09-2017), phm14 (05-11-2020), Teseo (05-09-2017)
Old 05-09-2017, 09:38 AM   #35
D_Thissen
D_Thissen's Avatar
@justinco posted before/after dyno videos of his 2013 frs. Not looking at the actual numbers, there were gains across the rpm band. Early cars had deficiencies, which were corrected for the 2017MY with a revised exhaust manifold, tune and other things. Which is possibly the reason why the gains aren't as great on the newer cars.
[ame="https://www.youtube.com/watch?v=2h4kkTgmjXE"]Scion FRS post upgrade dyno numbers - YouTube[/ame]
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 05-09-2017, 11:03 AM   #36
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Do you know if the ECU hardware is the same?
Also, what is the point behind multiple ignition maps?
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 05-09-2017, 11:33 AM   #37
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Hi Steve. A few questions ...
How do you monitor the AFRs? I've seen different dynos of the older cars (stock) and the AFRs were totally different.
They are running now in closed loop almost all the time for better fuel consumption. This was confirmed by the factory.
Old 05-09-2017, 11:50 AM   #38
wparsons
wparsons's Avatar
If the car in question has been tuned, then the AFR will be whatever the tune is commanding. If you're relying on the stock primary O2, it'll be different because it can only read so low without being re-scaled.
flickr
Old 05-09-2017, 12:19 PM   #39
steve99
Drives: FT86
The log above AFR measured by vehicles 02 sensor, the 2017 tune calibrates it down to 10 afr.
The previous tunes only calibrated 02 sensor down to 12.17 afr so even if it ran way richer (which it did) you could not see the correct reading using the vehicle o2 sensor unless you flashed a tune with 02 sensor recalibrated to read lower afr. Or you had to use a tailpipe sensor, these usually read a little different to the vehicle 02 sensor that right near the exhaust port, tailpipe sensor usually read 0.5 to 1 afr point leaner from what ive seen.
Here is log of an older STOCK rom , note how the AFR just flatlines at the sensor reading limit of 12.17, its rearly running afr down to 10.8 or so
http://www.datazap.me/u/steve99/brz-...zoom=1718-1986
See Image at end of this post the STOCK fuel table targeted by ecu in older roms 2012-2016, high rpm/load its targeting in the 10 AFR
Pretty well every tune ive logged tuners have leaned out the old tunes to around 12 to 12.3 at high rpm/load. this was an easy power gain, they also did changes to cam timings.
however ive seen a few kw gained on cars that ran rich by simply leaning them out to what the original tuner set (ie the maf scaling was off due say intake change) correcting the afr got you a few kw without changing anything else.
They don't seem to be claiming better economy figures on our web site still got 7.8l/100km as per old version
A01G is older rom, K00C is 2017 rom
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Old 05-09-2017, 12:49 PM   #40
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
As you should. Pretty sure I made that clear in the video that there are so many variables to take into account, and this was just 1 test. You are welcome to perform your own and share
The Following User Says Thank You to justinco For This Useful Post:
Old 05-09-2017, 12:58 PM   #41
steve99
Drives: FT86
The ecu hardware and processor appear to be same.
however while you can flash older roms to the 2017 ecu , don't, their appears to be changes to the Security system in the 2017 and the car wont start ecu and immobiliser modules throw a hissy fit, believe me I know. You can get it working again by resyncing all the security modules, but you need the 2017 rom.
All the changes to fueling strategy and timing strategy are not yet fully understood, especially by opensource guys. Ecutek guys have got most of it sorted, but think theirs still a few unknowns.
Old 05-09-2017, 01:16 PM   #42
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Another thing to add about ECUtek: It seems the RaceRom features (ie: launch control, flat-foot shift, auto-blip downshift, etc) do not work on the 2017 cars. I have done extensive testing with my tuner and cannot see to get them to work. Map switching via the cruise control stalk is also not working, we had to go back to the old style map switching, which works (gas pedal + defrost button).
The Following 2 Users Say Thank You to justinco For This Useful Post:
D_Thissen (05-09-2017), steve99 (05-09-2017)
stock tune only bolt ons dyno slow15frs Engine, Exhaust, Transmission 14 05-12-2016 12:42 AM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
My Dyno Tune Results brz961 Software Tuning 3 08-28-2014 11:43 PM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno l8apexr CANADA 23 04-25-2013 06:50 AM
