08-22-2017, 08:19 PM | #43 |
Drives: BRZ 2017 Pure Red, MT
08-23-2017, 11:46 AM | #44 |
Drives: 2014 Subaru BRZ
Skimming the thread here, it sounds like folks just want STX...
I think a realistic spec class would be Street Class rules, but just a class of only FRS/BRZ/GT86 with its own PAX. The only exception I would add is you can use any parts from any other twin, so people don't cry about TRD Parts, Gearing, etc... This would make it so no other car could show up and ruin the class, such as the ND Miata. |
The Following 2 Users Say Thank You to Kuro86 For This Useful Post: | strat61caster (08-23-2017), Twinz (08-23-2017) |
08-23-2017, 12:58 PM | #45 | |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
08-23-2017, 04:29 PM | #46 |
btr.life
Drives: 2022 GR86
I have nothing against the idea. But, this happens in (almost) every street class. Does the SCCA then make a spec class for the ND, once its reign is over? I don't know the answer...but, this is one reason I stopped running street/stock classes 3-4 years ago.
The Following 2 Users Say Thank You to justinco For This Useful Post: | DaWorstPlaya (08-24-2017), strat61caster (08-23-2017) |
08-23-2017, 06:49 PM | #47 | |
As for spec classing, I think if there is enough of a following for a car I would. That way you don't alienate drivers, since not everyone wants to jump into Street Touring. BUT I would put a contingency if participation is low 2 years in a row, then eliminate the class (Much like SSR). That way SCCA isn't maintaining dozens of spec classes that no one races in. |
08-23-2017, 10:55 PM | #48 |
Custom User Title
The logistics of this sound way too complicated. I think it would be better for them to just create a new street class, move D-H down a letter, and pull some of the current C and D cars into the new D.
If you look at class participation at nationals they have several street classes that are overly represented vs. the others.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
The Following User Says Thank You to Locust For This Useful Post: | DaWorstPlaya (08-24-2017) |
08-24-2017, 12:35 AM | #49 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
Personally, I think a Spec class between DS and STX would be great.
DS really only gets expensive when you go with high-end shocks like MCSs. For STX, when you factor in popular mods like the AP Racing BBK, wider wheels and tires, etc. the cost gap is clear. Not only that, but for many who dual duty their twins, you lose a fair amount of practicality by making the jump to STX, but at the same time, you miss out on a lot of good shit staying in DS. If I had any say in a Spec class or a new class between Street and Street Touring, I would propose something like the following: - 8" wide wheels max (+/- Xmm from stock offset) - 200TW tires minimum - Spec dampers (OTS Yellows or something similar) - Spec lowering spring - Spec camber plate (or like anything aside from the Raceseng Cascam plate) - Open camber bolt - Open rear LCA - Open sway bars front and rear - Whiteline poly diff inserts - Whiteline poly subframe inserts - Whiteline poly transmission mount insert - Open intake - Open catback exhaust - Spec tune - Open brake pads In my mind, the biggest issue with STX is cost, and the biggest issue with DS is camber limitation. The Spec class could slot right in between with much more lenient camber mods and also the ability to run the Whiteline bushings that are affordable and serve as a solid foundational basis for a dual duty twin. |
08-24-2017, 12:49 AM | #50 |
btr.life
Drives: 2022 GR86
To me, the word "open" does not belong anywhere in a spec class. Change all your opens to spec *something* and sounds good. One of the goals (I think) behind a spec class, is to take away all the guess work.
Whatever comes of it, I'll be staying in STX
The Following 2 Users Say Thank You to justinco For This Useful Post: | Shark_Bait88 (08-24-2017), strat61caster (08-24-2017) |
08-24-2017, 10:08 AM | #51 | |
Drives: 2013 Firestorm FR-S
If they went with a spec aftermarket camber bolt (like Whiteline) you can still get a good amount of camber. I had -2.5 with just Whiteline bolts. It's not ideal to where the car should be with camber, but it's not bad either. Intake is pretty much a cosmetic mod, I see very little reason to allow it as it will just add to costs. Same with a tune if you aren't allowing a header as well, which I wouldn't want either because then you're getting way too close to STX. I would like the bushings, hadn't thought of that before. I'd also say to make rear LCAs spec. Catback and sway bars stay open, since that's pretty common in every class.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
08-24-2017, 11:20 AM | #52 | |
This. Also, the more you add for stupid stuff like Bushings and such, the more complex it becomes and the more you will have people questioning it. No need for subframe bushing inserts. K.I.S.S. Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following 3 Users Say Thank You to M0nk3y For This Useful Post: |
08-24-2017, 11:46 AM | #53 |
Drives: '13 FRS - STX
Have you tried them? They're kind of fantastic on this car. The only reason I'm not putting my car in DS right now is that I don't want to take out those inserts.
The Following User Says Thank You to strat61caster For This Useful Post: | ApexEight (08-24-2017) |
08-24-2017, 12:13 PM | #54 |
The only reason I could see them making a class for the twins is to create a street class where the twins would be competitive. I doubt they are going to make an STX-lite class to create a "cool setup" class just for us.
If it's a street class for the twins, then allowing the best "street" parts from all 86's makes sense and won't require new structures for policing. I also think it would be fair to have a participation requirement to keep the class. The fact that there are so many people that want to run street in the twins is really the only justification for carving out a spot just for our car. |
08-24-2017, 12:16 PM | #55 |
It was just a rough outline lol.
I don't think most are able to achieve -2.5 with just crash and camber bolts, which is why I would want plates. I don't care for intakes either. The DS rules of a drop-in filter and silicone tube are good enough for me, just thought I'd include it. As for the tune, I would want it not because of power, but for the softer rev limiter and slightly sharper throttle sensitivity. And @M0nk3y, those bushings aren't "stupid stuff", nor do they add much complexity. They're affordable and easy to install while increasing bushing life and increasing performance, but hey, to each his own. Like I said, what I laid out was just a rough outline. |
08-24-2017, 12:33 PM | #56 | |
Yes I have them. Doesn't matter in Spec. Everyone has to play on the same platform. You know, the whole idea of spec Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | strat61caster (08-24-2017) |
Similar Threads | ||||
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
