Old 07-05-2012, 11:26 PM   #1
ZILLA
BRZ #575
ZILLA's Avatar
Drives: 2013 BRZ #575
Arrow ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD!
Check it out. I made the red triangle reflector fuctional as a fog light AND a brake light.
I bought (2) 194 bulb sockets and went to work.
Marked 2 holes.
Dremel'd holes out.
Holes completed.
Bulb sockets inserted snug into the 2 holes.
The housing has been installed and OEM reverse light wiring and new fog light/brake light wiring all zip tied together with protection.
I ran the (+) wire from each 194 bulb to the driver side tail light harness. The green wire is the regular tail light. The red wire is the brake light. The ground wires went to the OEM ground location in the trunk.
Headlights on (One 194 bulb is on in the fog light):
Brakes on (2nd 194 bulb in the fog light comes on):
At night this looks amazing. The camera wouldnt capture just how red and bright the lights really are. You need to see it in person to appreciate how nice it looks. Feel free to ask any questions. ENJOY!
UPDATED with video:
[ame="http://www.youtube.com/watch?v=_5O8RLGRQb4&hd=1"]BRZ / FR-S / FT86 *MOD* Custom Rear Fog / Brake Light COMBO! - YouTube[/ame]
ZILLA
BRZ #575 SWP Limited
18x8" Drag DR-31 +48 | 235/40/18 | 6000K HID Low/High | Wrapped All Red Tail Lights | Rear Fog + Brake Light Combo Mod [Video]
ZILLA is offline   Reply With Quote
The Following 30 Users Say Thank You to ZILLA For This Useful Post:
86BRZ (01-18-2014), Alien_Junky (09-14-2012), Asphalt~86 (01-13-2013), avusblue (07-06-2012), Chinadian (10-19-2013), Guff (07-12-2012), Ice_Man (07-06-2012), idanvan (08-21-2013), jskurucz (07-08-2012), karma003 (07-26-2012), kludger (12-28-2012), Lee358 (07-06-2012), Lorico (05-02-2015), MannyO (07-06-2012), MattR (07-09-2012), Meehow86 (03-19-2013), Moshpit37 (07-10-2012), Noli (02-17-2014), Ornelas66 (11-02-2014), ParangWala (08-11-2012), quik1987 (07-07-2012), Snoopyalien24 (07-10-2012), stalon320 (07-07-2012), Tama-Y (05-16-2013), Techfl3x (05-15-2013), TRD_07 (04-10-2013), uptown (08-19-2012), W2 (07-11-2012), xcelir8brz (07-05-2012), zex (07-06-2012)
Old 07-05-2012, 11:55 PM   #2
xcelir8brz
Drives: 2013 BRZ Limited
Good job.
Sent from my Galaxy Nexus using Tapatalk 2
xcelir8brz is offline   Reply With Quote
Old 07-06-2012, 02:14 AM   #3
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
The Following User Says Thank You to DarrenDriven For This Useful Post:
Old 07-06-2012, 02:10 PM   #4
ZILLA
BRZ #575
ZILLA's Avatar
I forgot to mention, I was originally going to do this with a single 1157 bulb (dual filament, non LED), but after running it with just one filament on, it was far too hot to touch after only 10 seconds, so it would definitely melt the light housing since the bulb would have been around 1/2 inch from the housing once installed. So that it why I opted to do with dual 194's.
ZILLA
Old 07-06-2012, 02:23 PM   #5
DarrenDriven
NW Region Moderator
LED would be a good choice, too. Cheap enough on eBay.
Old 07-07-2012, 04:48 PM   #6
joeschlabotnik
joeschlabotnik's Avatar
Drives: FRS
LED doesn't get too hot in either configuration.
joeschlabotnik is offline   Reply With Quote
Old 07-07-2012, 05:15 PM   #7
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Very nice and clean job!
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 07-07-2012, 08:34 PM   #8
jskurucz
Yep!
jskurucz's Avatar
Drives: 2015 WRX Sti
What's the part number for the sockets, all I can make out it Dorman? Those fit perfectly.
jskurucz is offline   Reply With Quote
Old 07-07-2012, 09:03 PM   #9
robotvoice
Drives: 07 STI
The rear fog light is not intended to be a "4th brake light", it should be wired to the front fogs or a dedicated switch. Write-up is good but it would make more sense to have the rear fog light as a functional modification.
robotvoice is offline   Reply With Quote
The Following User Says Thank You to robotvoice For This Useful Post:
MileMonger (02-08-2018)
Old 07-07-2012, 09:15 PM   #10
ZILLA
BRZ #575
ZILLA's Avatar
Here ya go =)
Dorman/Brake Lamp Socket
Part Number: 85814
http://www.autozone.com/autozone/par...er=600643_0_0_
ZILLA
Old 07-07-2012, 09:17 PM   #11
ZILLA
BRZ #575
ZILLA's Avatar
Its FAR more functional than the REFLECTOR that it was.
ZILLA
The Following User Says Thank You to ZILLA For This Useful Post:
karma003 (08-09-2013)
Old 07-07-2012, 09:25 PM   #12
Enilder
Drives: Porsche
easy DIY! looks great!
Enilder is offline   Reply With Quote
Old 07-07-2012, 10:13 PM   #13
phoenix150
Drives: Miz magna V6 3.6l
I think we are all forgetting something and that is if this a 4th or 3rd brake light, doesn't that mean we can legally remove the brake light in the back window?
phoenix150 is offline   Reply With Quote
Old 07-08-2012, 01:16 AM   #14
robotvoice
Drives: 07 STI
Third brake lights are designed to be eye level with the driver in the car behind you and HIGHER than the main brake lights. Turning your rear fog light into another brake light is unnecessarily redundant. You might face legal problems removing your OEM 3rd brake light as well, especially if you got in a rear end collision. The rear fog only has one purpose and is designed for only that, and it is NOT to serve as another brake light. It would be the equivalent of wiring your turn signals to stay on all the time just because you think it looks "cool".
custom, fog, fog light, foglight, rear fog light
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) -- General Topics 21 11-23-2015 03:23 PM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) -- General Topics 12 06-06-2012 07:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
