Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-06-2018, 05:17 PM | #15 | ||
MCTeeJ and Kodename said it will. Try disconnecting the battery turn the key as you would or press the start button and wait 30 seconds. Then reconnect the battery. Start the car and let it idle for a minute to a minute 30 seconds, and drive off normally. This allows the ECU to relearn the stock tune.
08-06-2018, 10:28 PM | #16 |
Drives: 2014 GT86
FRSBRZGT86FAN: Tunes are not "learnt". Tune is flashed on ECU and until reflashing with other tune, stays same. Things that may change are some learnt pedal travel calibration info & fuel trims from amount of knock ecu saw when driving. There is method to quicken "dead pedal fix" to learn pedal travel sooner, and method for learning fuel trims quicker, after resets. None will change "tune" itself in any way.
08-07-2018, 08:15 AM | #17 |
Drives: FT86
Guy has perrin intake and no tune hence P0420, even if its the 2.5" perrin intake they still throw fuel trims off by about 15%.
the perrin 3" big maf is even worse 25% or more. each time he resets ecu clearing code hes going to get the dead throttle pedal and it will clear his large learned fuel trims. car will drive like crap till ecu learns the 15% plus fuel trims and the throttle pedal trims |
Similar Threads | ||||
P0420 Code | Miguelgomez | Southeast | 0 | 01-25-2018 09:41 PM |
CEL P0420 Code. | VoltsFRS2013 | Engine, Exhaust, Transmission | 22 | 10-10-2017 12:26 PM |
OFT CEL Code reading clearing - reset tune? | Walla Walla | Software Tuning | 4 | 08-13-2016 12:02 AM |
P0420 Code... Need help | R3b00T | Engine, Exhaust, Transmission | 4 | 07-11-2016 04:18 PM |
Code p0420 | Patsully3 | Issues | Warranty | Recalls / TSB | 17 | 02-26-2016 10:45 PM |
