Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
08-13-2018, 02:11 PM | #16 |
Drives: 2017 BRZ PP WR Blue
The stock lug nuts on these cars are not great. While they may be fine if you simply commute and rotate tires once a year for the life of the car, I can tell you that if you do track days (put extreme amounts of heat into the whole assembly) and remove the wheels frequently under these conditions (hot pad swap, inter-session rotation, tire swap, etc.), you may very well run into issues. I have had stripped nuts on this car and as well as my '15 WRX (same part #). I know, I know - "monkey with the wrench", "operator error", etc... I always thread the nuts on by hand and torque to spec. I NEVER impact them on. These things do not get "cross threaded". The threads themselves get damaged.
ps - check the calibration on your torque wrench. Most people use cheap wrenches, which is fine, but make sure they are calibrated or they are useless. Frankly, I would be more concerned about doing damage with under torqued nuts than over, but "correct" beats both! |
08-16-2018, 09:36 PM | #17 | |
Financial Distress
Drives: 2017 GT86 325WHP
Cheers! |
The Following 2 Users Say Thank You to scottryan For This Useful Post: | Tcoat (08-18-2018), Ultramaroon (08-17-2018) |
08-16-2018, 09:41 PM | #18 |
Financial Distress
Let the record show in the OP I stated that I definitely tightened the lugs over 89lbs, had just bought the car, didn't know a lot about the etiquette. I own a torque wrench now and have new lugs, learned from my mistake haha
The Following 2 Users Say Thank You to scottryan For This Useful Post: | BirdTRD (08-17-2018), Ultramaroon (08-16-2018) |
08-16-2018, 09:43 PM | #19 | |
chicken tonight
If you loosened them before re-tightening, then that's half the battle. If you're a big guy, 89 lbft is pretty easy.
The Following User Says Thank You to Ultramaroon For This Useful Post: | scottryan (08-17-2018) |
08-16-2018, 09:44 PM | #20 | |
chicken tonight
can't breath
08-17-2018, 06:52 PM | #21 |
Financial Distress
The Following User Says Thank You to scottryan For This Useful Post: | Ultramaroon (08-17-2018) |
08-17-2018, 07:12 PM | #22 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
That's what my father referred to as "blue torque"...torque it 'til your blue in the face. |
08-17-2018, 07:17 PM | #23 |
chicken tonight
For me, axle nuts are the only thing that come close to that category. I have to be really careful. Small wrenches help.
08-18-2018, 03:23 AM | #24 | |
I managed to break many a wheel stud back in the day and eventualy realized if I used an actual wheel wrench instead of a long handled breaker bar then it wasn't side loading the stud and taking it beyond its limits. The stock nuts and studs on these cars are up for any task (even track) if the proper tools and methods are used. They should not stretch, cross thread or fail in any manner if proper tools and methods are used. It is a simple nut holding a part on by friction so why would they fail just from being taken on and off?
The Following User Says Thank You to Tcoat For This Useful Post: | BirdTRD (08-18-2018) |
Tags |
lug, nut, wheel |
Similar Threads | ||||
DIY: 86 Tightening Torque Values | zeal86 | DIY (Do-It-Yourself) Guides | 55 | 06-20-2023 12:42 PM |
BRZ Steering Right Tightening + VSC Fault?? | BRZ2Bars | Issues | Warranty | Recalls / TSB | 4 | 05-07-2015 03:58 PM |
BRZ stock lugs and lock nuts w/ key | scion dad | Wheels and Tires | 0 | 09-15-2013 09:46 PM |
Tightening the Rear | scottynoshotty | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 05-16-2013 12:57 PM |
Stock Lug Nuts?? | ESC POD | Northwest | 8 | 10-15-2012 12:43 AM |
