Old 12-10-2018, 04:38 AM   #113
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Depends on whether you're fat or not I guess?
I did mine using jack stands and there was not need to remove any covers.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 12-10-2018, 05:17 AM   #114
Legend@wheels
nenber
lol
sounds good for me -im not fat but i have quite big hands .
hope its not too crowded hah
anyhow if i go for that method i dont need to remove anything from inside the car right ?
Legend@wheels is offline   Reply With Quote
Old 12-10-2018, 06:13 AM   #115
sav
sav's Avatar
Nope, it's completely accessible from underneath.
95RON SAV Tuned
Old 12-10-2018, 06:19 AM   #116
Legend@wheels
nenber
aiight thanks
The Following User Says Thank You to Legend@wheels For This Useful Post:
sav (12-10-2018)
Old 12-10-2018, 06:49 AM   #117
Legend@wheels
nenber
Lifted the car up.
I cant get my hands in there .
Sent from my SM-G960F using Tapatalk
Edit
Its ok thx
Old 10-06-2019, 09:25 PM   #118
devtec
Drives: 2015 Subaru BRZ Limited
After getting two gear levers replaced the rattle kept coming back. I've eventually managed to fix it by getting to the root of the problem - the thin washer at the bottom of the gear lever under the car.
You'll see a split pin holding the gear lever to the rod on the gearbox. Remove it together with the thin washer and replace with a thicker steel washer and refit the pin. Problem solved.
( It's the joint right at the bottom of this pic that you're looking for.)
Pics from this thread:
http://www.ft86club.com/forums/showthread.php?t=31340
BTW.
I've sprayed some Liqui Moly Tacky Lube Spray in there as well for good measure.
EDIT:
Special thanks to @Freedom who noticed the loose washer.
Anyone know the size of this washer? ID/OD?
devtec is offline   Reply With Quote
Old 01-01-2020, 07:55 AM   #119
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Originally Posted by continuecrushing View Post
Skip that, just replace the whole shifter with a kartboy shifter/bushings.
Support a forum vendor!
See @tom@kartboy
Direct link
I have a kartboy shifter, and have NO rattles.
Did your shifter rattle before installing the Kartboy shifter?
Razzle is offline   Reply With Quote
Old 04-03-2020, 11:25 AM   #120
acunat
Drives: 2017 BRZ PP
Anyone know the size of the washers? ?part numbers? Wanted to order some - since everything is shut down and cant just run out and try a couple.
acunat is offline   Reply With Quote
Old 04-03-2020, 11:54 AM   #121
sav
sav's Avatar
No idea, I simply used one I had laying around.
95RON SAV Tuned
Old 04-03-2020, 12:06 PM   #122
gpvecchi
gpvecchi's Avatar
Toyota SU003-00892
Subaru 35038CA010
Same part...
Old 04-03-2020, 12:17 PM   #123
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
I purchased 10mm washers from Lowes, stainless steel and nylon. With the SS I was not able to put the pin back in (~2.05mm thich). Nylon worked (1.65mm thick), but I'm going to check it to make sure it's not wearing poorly.
tehShirt is offline   Reply With Quote
Old 04-04-2020, 03:51 AM   #124
gpvecchi
gpvecchi's Avatar
Stock ones are conical
Old 04-05-2020, 03:59 AM   #125
mkodama
86Drive Challenge
Drives: 2017 BRZ PP
mkodama is offline   Reply With Quote
Old 11-18-2021, 03:04 PM   #126
FrickingReallySlow
Drives: 2015 FR-S
Necro thread... looking at the 2022 shifter linkage the pin holding the washer (no change) has been changed to a ring clamp. Otherwise everything looks the same although not the same part numbers.
https://parts.subaru.com/a/Subaru_20...11-350-01.html
I might order this ring clamp and see if it works better than trying to find a slightly thicker washer. not sure how such a tiny ring clamp works is it just one piece that's stretched to fit on?
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
sav (01-02-2022)
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 10:09 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 01:21 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
FR-S Shifter Video xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 08:20 PM
