Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-19-2018, 08:03 PM | #15 |
Drives: 2013 FRS
I’m back to looking at the relays. With the car on I pull the starter relay out and check power. I get power to pin 5 which I shouldn’t. That pin should only power when the key is in the start position. I then pull the inhibitor relay and pin 5 losses power. Turn the key to start and pin 5 powers up like it should. I jumper pin 5 to pin 3 for the starter relay and turn the key to start and the car started. So I then did a test on the inhibitor relay by supplying 12 volt to it and I can hear it clicking. I then test the wires to the inhibitor relay. With the key on pin 1 is getting power like it should. When I jumper pin 1 to pin 3 I get power to pin 2 of the starter relay. If the inhibitor relay is working correctly that where the power would be. With the jumper in the inhibitor relay still I jumper pin 2 to pin 3 for the starter relay which should start the car but nothing happen. I have put put different relays in and still nothing. But I did get it to run for a few so that good
12-19-2018, 08:27 PM | #16 | |
Project Shadow
Drives: 2015 BRZ Limited 6MT
12-23-2018, 12:15 PM | #17 |
Drives: 2013 FRS
12-24-2018, 03:11 AM | #18 | |
Where in Washington do you live? Are you going to BBQ the turkey .. Here is what you need to chase down the electrical problem - humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Drakiv (12-24-2018) |
12-28-2018, 03:37 AM | #19 | |
Drives: 2013 FRS
I live on Whidbey Island We got power on the 24th so we were able to cook. |
12-28-2018, 03:01 PM | #20 | |
humfrz |
