12-30-2018, 08:21 PM | #20217 |
Drives: LS Swapped Scion FRS = 440HP
Today:
(sorry didnt take a photo after the center console was in) |
01-01-2019, 08:54 PM | #20218 |
Drives: GR Corolla
Did a brake fluid flush today. New year, new fluid I suppose. lol. In all seriousness, the brake pedal always felt worse/more travel to stop compared to OEM fluid after I had a shop change it to Torque RT700 (I used the same RT700 in my Yaris, and the brake pedal felt great).
Anyway, I decided to switch to Amsoil to give it a try since I like their products, and RT700 doesn't seem to last long before it starts turning brown...brakes now start stopping as soon as I apply the brake pedal. |
01-01-2019, 09:35 PM | #20219 | |
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
01-01-2019, 10:15 PM | #20220 | |
Drives: GR Corolla
If I were you tho, I'd run a DOT3/4 or DOT3 fluid, and switch to a DOT4 with every track day, and back to DOT3/4 or DOT 3 after each track day. Although that would cost quite a bit of money, but at least you're brake fluid would be as efficient as possible for daily driving and track days separately. |
01-01-2019, 10:27 PM | #20221 | |
01-01-2019, 10:51 PM | #20222 |
Drives: GR Corolla
What about price? If one is replacing their brake fluid 5+ times a year, I'm sure it'll add up quickly. Just using Amsoil as an example, their DOT4 fluid is double the price of their DOT3/4.
01-01-2019, 10:56 PM | #20223 |
But changing it before and after a track day is somehow cheaper? If you are changing it every 2 months, you don't need to replace it for the daily driving time between track days. Either you ruin it at the track and replace it when you get home or you replace it before going to the track, right? 2 months isn't enough time for your brake fluid to attract a significant amount of water
01-01-2019, 11:15 PM | #20224 | |
Drives: GR Corolla
I don't know how competitive the other poster was, but some people are really competitive, and will take into consideration anything that could be a disadvantage to them. Like I said, I haven't done much research on brake fluid since I do not track or drive any of my cars hard at all. So, I don't know how much heat cycling the brake fluid degrades it. Also, by track days, I'm assuming large tracks with enough braking force to potentially heat up the rotors enough to glow. If I were to track my cars now, I'd probably just stick with DOT4 and replace it every 6 months if combined with daily driving since I would be in a "gaining experience" mode rather than a full blown competitive mode. Shoot, DOT3/4 might even be good enough in that scenario. |
01-01-2019, 11:24 PM | #20225 | |
Drives: 2015 FR-S (Steel)
Depending on the tracks I change it either every 3 months or every 2 months, it really just depends. I don't feel any difference in feel, but I'd rather be safe. Spending is part of tracking, gotta pay to play. $20 a bottle isn't much to ensure the brakes work. |
01-01-2019, 11:33 PM | #20226 | |
Drives: GR Corolla
I also consider tracking and auto-x to be two different things, so I'm not sure if those that say they track mean an actual course like Leguna Seca, etc, or they count auto-x as tracking. |
01-01-2019, 11:41 PM | #20227 | |
I don't mean track days as in auto-x. I do circuits, I go to tracks like Buttonwillow, Chuckwalla, Willow Springs, etc. |
01-01-2019, 11:51 PM | #20228 | |
The Following User Says Thank You to Ashikabi For This Useful Post: | VittorioS (01-01-2019) |
01-02-2019, 01:01 AM | #20229 | ||
Drives: GR Corolla
Yeah, that's what I figured since you don't get up to the speeds of a track on an auto-x course, plus the gaps between runs is long unlike the hot lapping done at track days. Also why I said I would probably change it every 6 months if I were to start tracking plus DD'ing my cars, just for peace of mind and the fact that the Torque fluid started turning brown in a year of just plain DD'ing. Oddly enough, the RT700 lasted longer in my Yaris than it did in my FR-S. I guess another good way to tell if your brake fluid is done for is using those test strips or devices. |
01-04-2019, 04:40 PM | #20230 |
helmholtz resonator
Drives: '15 ultramarine
I made an appointment to have my Bilstein B6 and my Verus fuel flap door installed at The Racers Line on the 19th. So excite.
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
