Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
01-31-2019, 06:48 PM | #1 |
JDM Vaping Stance Nation
Drives: 2013 White
What is this black stuff in my clutch reservoir?
42k miles, changing out my fluids and when I took the cap off the clutch fluid reservoir I saw this.
Any idea what it is and how do I clean it?
Clueless
01-31-2019, 07:27 PM | #3 |
Drives: 2013 White
I just vacuum bled in new fluid and it didn't really go away. Old fluid was brown, new is clear.
If I agitate the black stuff it'll move. Should I stick a brush in there?
Clueless
01-31-2019, 09:21 PM | #4 | |
humfrz |
01-31-2019, 10:11 PM | #5 |
Drives: 2013 White
Doesn't float, it's just at the bottom. The new fluid is clear though.
Clueless
The Following User Says Thank You to YamahaR86 For This Useful Post: | humfrz (01-31-2019) |
01-31-2019, 11:30 PM | #6 | |
It's just a hydraulic system, not an operating room - humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Grady (02-01-2019) |
02-01-2019, 12:37 AM | #7 |
chicken tonight
It's rubber worn from the piston seals. No worries.
02-01-2019, 01:51 PM | #8 |
Only users lose drugs.
Drives: All the time
Happens all the time...I use a q-tip and swab it clean when I do a flush. Still doesn't clean things beyond the reservoir though, so there's probably no point in doing it, other than it making you happy.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
02-02-2019, 06:08 PM | #9 |
Drives: MDX, Camry
I stirred it up really well before bleeding. It's all gone afterwards.
Sent from my Pixel 3 XL using Tapatalk |
The Following User Says Thank You to qqzj For This Useful Post: | YamahaR86 (02-04-2019) |
Similar Threads | ||||
What's the black tire stuff dealerships use? | BigHugeFatGuy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 06-02-2017 02:23 PM |
Black Flakes in Coolant Reservoir?? | John Rambo | Issues | Warranty | Recalls / TSB | 7 | 07-15-2015 05:58 PM |
CruiseControl's Ultramarine FR-S - Perrin Tips, Shark Fin, JDM Stuff, Other Stuff | CruiseControl | Member's Car Journals | 4 | 07-01-2014 05:53 PM |
Anyone with black/aluminum acrylic stuff from DD? | Vmax911 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 11-05-2013 08:26 PM |
