Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-30-2019, 03:51 PM | #1 |
Drives: Frs
How can you be sure there are no leaks after install?
I torqued, and retorqued after 3 heat cycles (kuz i was busy).
Hissing, popping, smell. Those would be for a big leak. Is there a definitive way to be sure there are no leaks at all? Chrisfix's soapy wooder and a blower? Is there a sanity check yall use? Like "if you cant detect it with the hood open youre good" bibbity boppity give me the zoppity |
05-30-2019, 03:53 PM | #2 | |
Can you hear anything? Can you smell anything? The same things apply to small leaks as you mentioned for big ones. If you can't find a leak there probably isn't any.
The Following User Says Thank You to Tcoat For This Useful Post: | Lav (05-30-2019) |
05-30-2019, 04:52 PM | #4 |
Benz Tech
Drives: 2017 BRZ Premium
1 mile lap around the block and park it. If everything was installed correctly there won't be any leaks.
05-30-2019, 04:57 PM | #5 | |
Drives: Frs
I ended up driving 30, then 115, park for 4 days, 115, and then 30 before i could retorque lol bibbity boppity give me the zoppity |
05-30-2019, 05:13 PM | #6 |
Drives: 2013 frs red
Dont worry about it
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Lav (05-30-2019) |
05-30-2019, 05:46 PM | #7 |
Drives: Frs
05-30-2019, 06:47 PM | #8 |
Drives: Toyota 86 GTS Manual 2015
This may not be a popular suggestion but, if you wanna be sure just take it to an exhaust shop and indicate you think you have an exhaust leak. Save you the hassle in the long run.
The Following User Says Thank You to natekwondo For This Useful Post: | Lav (04-16-2022) |
05-30-2019, 07:03 PM | #9 | |
Drives: Frs
Edit: im not opposed to just getting a shop to do it but only if its because they have very specialized tools bibbity boppity give me the zoppity |
05-31-2019, 07:24 AM | #10 | |
Drives: WRB BRZ
This is kind of an extreme type of check to DIY, but this is likely what an automotive performance shop will do to check for exhaust leaks. As other people have said, if it's not obvious, don't even worry about it. You mentioned your concern was CO poisoning, but even if the exhaust is leaking a tiny bit, it's outside the cabin anyways. Very little of that CO, if any, will make it into the cabin, and certainly not enough to cause any problems under normal use (i.e. not sleeping in the car with the engine running). |
The Following User Says Thank You to Fred E For This Useful Post: | Lav (05-31-2019) |
05-31-2019, 08:54 AM | #11 |
Drives: 2017 BRZ
Vacuum to the tailpipe (be sure to seal it so its not just pulling air through the muffler) and a tube to the ear with the other end in hand, checking all the joints. Better than soap because you can be confident even where you can't see clearly.
The Following User Says Thank You to cjd For This Useful Post: | Lav (05-31-2019) |
05-31-2019, 09:28 AM | #12 |
The Dictater
Drives: '13 Red Scion FRS
Am I the only one here who is wondering what was installed before giving advice?
The Following 4 Users Say Thank You to Spuds For This Useful Post: |
05-31-2019, 09:34 AM | #13 | |
Pretty sure that is what others and myself have already said. You ware overthinking this unless you believe there is a leak you can't find. If there is a leak large enough to fill the car with exhaust and poison you then you would have no doubt it was there.
The Following User Says Thank You to Tcoat For This Useful Post: | Lav (05-31-2019) |
05-31-2019, 11:21 AM | #14 | |
Drives: Frs
Similar Threads | ||||
17% LTFT. Checked for leaks and none. | edwardleeaf | Software Tuning | 10 | 02-08-2017 02:02 PM |
Multiple oil leaks. | samisons | Issues | Warranty | Recalls / TSB | 13 | 02-02-2017 03:13 PM |
Flex piping having leaks? | IAmNotTheDriftKing | Engine, Exhaust, Transmission | 7 | 10-19-2013 07:31 PM |
did first oil change and now it leaks | Bakemono858 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 10-18-2013 09:17 PM |
New exhaust leaks | Vukodlac | Engine, Exhaust, Transmission | 35 | 02-27-2013 11:41 AM |
