08-23-2014, 12:11 AM | #169 | |
Drives: Scion FR-S/Toyota Yaris
Where is the Unicorn and other idiots who called me a dumbass for saying the rods were the weak link in this motor. No way I' boost, don't have time for it. It has plenty power as is.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
08-23-2014, 11:28 AM | #170 |
I think we've known the rods were the weak point for a long time now... It's really the only thing that has broken on the engine due to high power. There are some other more isolated failures with bearings/cams but I wouldn't do really high boost without doing a built bottom end with rods. Rods breaking can take out all kinds of expensive stuff. I imagine if it failed the wrong way it could even damage the supercharger on top of the engine.
The Following User Says Thank You to xwd For This Useful Post: | CSG David (08-23-2014) |
03-13-2019, 06:26 PM | #171 |
Drives: 2013 FR-S Argento
Ran across this - old old thread so sorry for the necro, but thinking about these kits. Anyone know what happened to the 210+? I never hear of any kits out there (and their results).
03-13-2019, 06:50 PM | #172 | |
Rust bucket enthusiast
Correct me please if the 215+ is something entirely different... |
03-13-2019, 07:34 PM | #173 | |
Sent from my SM-G965U using Tapatalk |
03-15-2019, 07:02 PM | #174 | |
Drives: UK GT86
They made them, the noise on the forum died out though. I'm sure that @86 South Africa runs one.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | bfrank1972 (03-16-2019) |
03-16-2019, 08:01 AM | #175 | |
03-16-2019, 01:37 PM | #176 |
Drives: 2013 frs red
With na mods stopping at 200 whp I'm considering some conservative boost myself. The guys who told me 5 years ago that id end up doing this were on the money.
06-18-2019, 02:58 PM | #177 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Sorry haven’t been hugely active on here. Driven both the normal 210 kits, and the SPS (which I decided was worth the extra cash). It’s in the region of 10-15% more efficient, which means it manages heat better + makes a little more power. No idea how much HP you’d gain, but my thinking was if it’s more efficient generally and therefore manages heat better then it was worth it. Been driving mine on and off different %s of ethanol for well over a year now, and it’s awesome. With 50-70% ethanol I’ve kicked some GTi ass a couple of times too which was quite satisfying.
I like driving!
06-20-2019, 11:31 PM | #178 |
Drives: 2015 Firestorm 08/05/15
According to Jon Bond Performance, the only difference in the so called new sprintex x or plus, is the rotors are coated from sprintex for better heat management. Which results in a tiny improvement of efficiency. Sprintex still hasn’t resolved the front seal issue in so much as the units use oil, fact. I had my rebuilt 2 times by Jon Bond performance. Second time was under his warranty. Also Bond offers this service of ceramic coating the rotor pac as well.
The money I had in this used unit I could have easily paid for an Elderbrock or an optioned out JDL turbo set up. I’d be curious to know how the Jeep folks are doing with the oil situation in the intake manifold. Simply updating user manuals with check oil more frequently is sprintex,s form of customer service. I had to cut my losses. Back N/A on E85 delicious stage 2 tune set up and no more worrying. Even you guys with the new blower set up, for giggles and grins, pull your blower off for inspection, tell me the intake manifold is not coated in supercharger nose drive gear oil. Guarantee you it is. Do not **** around without checking your supercharger oil at minimum once a week. Just my personal PSA . Last conversation with Jon Bond, he was going to stop rebuilding these units. Verify with Jon, or better yet try and get replacement parts I. E. Seals and bearing kits from Sprintex. Good luck. |
The Following 2 Users Say Thank You to sroby For This Useful Post: | kev0 (06-20-2019), Ultramaroon (06-20-2019) |
06-20-2019, 11:44 PM | #179 | |
Drives: '14
06-21-2019, 04:03 PM | #180 | |
2013 Series 10 FRS #553
06-21-2019, 06:42 PM | #181 |
Drives: UK GT86
I just checked my SC oil for the 1st time in 5k miles, still on the full level on the dipstick. Some must be worse than others. When my car has the valve spring recall done it will give me a chance to assess what the blower is doing after 25k worth of miles.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | 86TOYO2k17 (06-21-2019) |
06-22-2019, 01:46 AM | #182 | |
Drives: GT 86
Don't be worried I had the 210 for close on 3 yrs and it copped a bit of a flogging and checked and topped up oil every month or so with no issues. Had a 69mm pulley and rev limiter set to 7800 so it was over revved alot and it's still good ! |
The Following User Says Thank You to sam69 For This Useful Post: | kev0 (06-22-2019) |
Similar Threads | ||||
Abbey Motorsport Sprintex SC updated Dyno plots | Mark@Abbey m/s | Forced Induction | 49 | 02-15-2017 11:13 PM |
Khorne's - AUDM Red 86 GTS Sprintex | Khorne | Member's Car Journals | 53 | 08-31-2014 09:44 AM |
Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 11:09 AM |
Abbey Motorpsort GT86 Sprintex installation | Mark@Abbey m/s | Forced Induction | 18 | 09-07-2013 04:11 AM |
Sprintex Supercharger Sneak Peak!!! | invisage | Forced Induction | 52 | 03-03-2013 06:11 AM |
