Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-14-2019, 03:18 PM | #1 |
Drives: Red FRS
Thoughts on this built engine for my Turbo FRS
https://www.rallysportdirect.com/par...ru-short-block
Looking to build my engine. The shop I would take it to is recommending this engine. Any thoughts? |
08-14-2019, 03:54 PM | #2 | |
Drives: 2017 toyota 86
What turbo are you going to be running and at how much boost? |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Conman (08-14-2019) |
08-14-2019, 03:58 PM | #3 |
Drives: Red FRS
08-14-2019, 05:03 PM | #5 |
Drives: Red FRS
That’s jus what they recommend... Why would or wouldn’t you use a different compression ratio? The IAG described it as being safer for boost... I don’t care what hp number I make. I just want my engine to not blow up.
08-14-2019, 05:31 PM | #6 |
Drives: Bone stock
IAG is a great company. Do it!!
Sent from my SM-N960U using Tapatalk |
08-14-2019, 06:48 PM | #7 |
Drives: Q5 + BRZ + M796
Dropping compression will allow for more power and especially more power on pump gas, but you may find there is less fuel economy and less power down low or off boost with slightly more turbo lag. It is definitely not necessary for modest goals and isn’t too necessary if you have easy access to E85. Unlike a supercharger, the turbo can have its boost modulated better with an electronic boost controller to adjust for 91 or for doing boost by gear or progressive boosting. If you want to go further than 400whp then definitely drop compression.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Conman (08-14-2019) |
08-14-2019, 07:16 PM | #8 |
The Following User Says Thank You to Grady For This Useful Post: | wparsons (08-15-2019) |
08-14-2019, 08:00 PM | #9 | |
350whp on 91 and 425whp on E85 should be perfectly fine and safe on stock compression with forged rods/pistons. It’s largely on the tune and boost controller for safety once you have forged internals. The trade off is lower compression requires more boost to make the same power So you’ll have more turbo lag/spool up and less low end torque/throttle response, worse MPG, and less off boost power. but assuming your turbo can pump enough air you’ll have more top end potential. But with sub 425whp goals your probably better off with stock compression. Or do 12:1 or 11.5:1 for a happy medium. |
08-14-2019, 08:34 PM | #10 |
Pump gas is really the deciding factor, besides power potential and reliability. I would rather be able to make big power on pump gas than be concerned about low end power.
Are there many people making more than 300whp on 91? 350whp on 91 seems sketchy, even on a built motor. A built motor can help avoid failure from higher power, but not from preignition/detonation.
08-14-2019, 08:51 PM | #11 | |
But not really anyone with a built block that kept stock compression and runs 91 that’s posted a dyno that I’ve found. Usually either lowered compression, or uses E85. Personally if I had E85 and only wanted sub 450whp i would keep stock compression, or only slightly drop it. And just keep the boost low if I ever had to resort to pump. |
08-14-2019, 10:54 PM | #12 |
Drives: 13' BRZ
Well that took a turn
The Following 3 Users Say Thank You to Scjacob827 For This Useful Post: |
08-14-2019, 11:08 PM | #13 | |
I would run 10.5:1
08-14-2019, 11:31 PM | #14 | |
Also, this post of this thread had this link, which showed the dyno below for a slightly modded WRX throwing down decent numbers on 93 octane.
That post led to this response, which I'll quote anyways: Quote:
Similar Threads | ||||
Whats my car worth? (Built engine, Turbo kit) | glorydays | FR-S / BRZ vs.... | 16 | 07-13-2019 08:55 AM |
Built FI engine on 100 RON | Boris_Petrov | Engine, Exhaust, Transmission | 9 | 03-10-2019 04:55 AM |
Fully built engine with big turbo in dubai TARGET 550WHP | SUB-ZERO | Forced Induction | 84 | 12-01-2014 12:34 AM |
9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ | SUB-ZERO | Forced Induction | 44 | 07-09-2014 09:44 PM |
What is the best turbo for a fully built engine scion frs | SUB-ZERO | Forced Induction | 41 | 09-18-2013 06:41 PM |
