09-18-2019, 11:51 AM | #8667 |
Drives: 13 DGM BRZ 6MT
Still wanting to sell:
Raceseng 72.5mm pulley for Sprintex 210 (will include smaller idler pulley if wanted) - $100 Sprintex 210 Intercooler kit (never installed, includes blanking plugs for IC or non-IC setups) - $850 Moto East / Xero Limit flex fuel kit with evap ECU plug and gauge - $420 Willing to ship! |
09-18-2019, 10:32 PM | #8668 |
Drives: 2015 brz
09-19-2019, 02:13 AM | #8669 |
Drives: '14
If i'm running extremely lean and rich (lean for first 7 minutes of driving, then incredibly rich), but my AFR stays at around 14.xx, would it be a problem? I'd assume that it is a problem but my AFR's are stoic.
09-19-2019, 10:09 AM | #8670 | |
2013 Series 10 FRS #553
09-19-2019, 10:16 AM | #8671 |
Drives: '14
Lean when idling. 30% Fuel trims until after about 7 minutes of warming up, then my fuel trims drop to about -20% under normal throttle. Fuel trims are never lean after the warm up, only rich.
09-19-2019, 06:55 PM | #8672 |
Drives: 2013 GT86
Sorry a couple more questions.. just trying to scout all the information before I start installation.
1. I see some people replace the plastic connections at the back for brass. How necessary is it to do this? I mean, should I do this before I do the install? Are they prone to leaking or breaking or something? 2. Does the 72mm pulley need a smaller idler pulley? 3. The instructions say not to start up the car without a tune. But it would be good to be able to start it up and make sure all the belts etc are aligned properly etc before getting it to a tuner. - I was originally hoping I could get some sort of base tune, perhaps using my OFT just so I could nurse it to the tuners as I don't have anything to pull a car trailer with. Do most people buy an EcuTek license and cable and an e-tune and then take their car to the tuner (or just e-tune)? |
09-22-2019, 08:02 AM | #8673 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
2: No 3: You can start it and idle it. I would not drive it. Not sure about the tuner scene in NZ but we have e-tuned these around the world. A lot of work went into getting it right. The high compression coupled with high temps and instant boost is something that took a long time to iron out. |
09-22-2019, 03:00 PM | #8674 | |
Drives: '14
09-23-2019, 10:13 PM | #8675 | |
Drives: 2013 GT86
09-23-2019, 10:50 PM | #8676 | |
The Following User Says Thank You to jflogerzi For This Useful Post: | Xero-Limit (09-24-2019) |
09-23-2019, 11:19 PM | #8677 |
Drives: 2013 GT86
As I understand it I can buy a bluetooth Ecutek so I can flash a tune on with my iPhone is that correct? That would be useful as I don't have a PC laptop (only Mac).
09-23-2019, 11:41 PM | #8678 |
Drives: '14
Can't flash tunes with iPhone even if you have the bluetooth dongle. I have the same kit. I just use Bootcamp on my Mac to flash tunes.
The Following User Says Thank You to kev0 For This Useful Post: | tzbang (09-23-2019) |
09-25-2019, 01:38 AM | #8679 |
Drives: 2013 GT86
Ok now I have a MAP sensor question.. from what I have read earlier the Sprintex setup needs to use the OEM sensor. But on the Delicious Tuning site they say that you must use their 11psi MAP sensor?
Does everyone still run the OEM sensor and what tunes are everyone using? I'm a bit unsure which way to go, trailer the car down to a local Ecutek tuner and pay for them to tune it on the dyno. Still have to pay for the Ecutek license and dyno-time. I'm unsure how much experience they've had with these SC kits.. I doubt it would be much. Or e-tune Xero-limit, their package is $849 DT, their package is $1095 (+75 for the TJ Hunt Especial - Crackle and Pop I have no idea what that is..) |
09-25-2019, 01:40 AM | #8680 |
Etune for sure. I am using stock map sensor... And using the 72mm pulley without issues
You can't go wrong with either. Both are solid tuners for this kit. Sent from my GM1915 using Tapatalk
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
