Old 02-05-2020, 08:44 PM   #1
staybrzy
Talking Tire size?
I got 18x8+45 wheels and am not sure if I should run 225/35/18, 225/40/18, or 235/40/18. I want to run 235s but am not sure if It'd be too large a speedo error. Thoughts?
staybrzy is offline   Reply With Quote
Old 02-05-2020, 09:00 PM   #2
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Definitely go for the 225/40. The 235 is an option, but it’s a bit too tall if you ask me. 225/40 is perfect for the 8 inch wide wheel
Will BRZ is offline   Reply With Quote
Old 02-05-2020, 09:01 PM   #3
equachie
Drives: Subaru Brz - WRB
Speedo error would be ~3.1km/hr on 235/40/18.
100km/hr= 103.1km/hr with those.
equachie is offline   Reply With Quote
Old 02-05-2020, 09:10 PM   #4
staybrzy
Isn't height the (40)? So you're saying the wheel will be taller at 235 width as opposed to 225? Also, should I go 225/40 or 225/35?
Old 02-05-2020, 09:29 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It's aspect ratio, not height, it varies with width, a 215/45/17 is the same diameter as a 245/40/17.
ineedyourdiddly
Old 02-05-2020, 09:31 PM   #6
Will BRZ
Drives: 2015 BRZ
225/40/18 is a very common size. You’ll be able to find a good variety of tires for good prices. That size is under a 2% difference from stock and the speedometer will be about like 1.14mph under your actual speed I think. 235/40 is a 3.2% difference and the speedo will be almost 2mph under. I’ve seen people even running 215 on an 8 inch wheel too, but it’s up to you. I’d just take the 225/40/18. It’ll look good on the wheel, you’ll save some money, and it’ll be lighter than the thicker tire
The Following 2 Users Say Thank You to Will BRZ For This Useful Post:
Vital (02-06-2020)
raijin, rims, size, tires, wheels
Need some help with what tire size i should get. sosky9 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-27-2018 04:20 PM
Tire rack giving me a hard time on tire size, so please help! NOI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-03-2017 06:27 PM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 02:40 PM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
