Old 06-18-2020, 04:59 PM   #1
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Help identifying sound. Newly rebuilt coilovers installed.
I made a new thread because I did not want to derail the other person’s thread. I installed a rebuilt AST 5100 using stock top hats are from a 2017 car (asked damper rebuilder to install the tops hats for me, to make sure I don’t screw it up), new spl front end links and front lower hole camber bolts. Everything else stock. The sound is most audible in the front driver’s side. The sound is a distinct thud in all small dips of the road not metal on metal hitting each other. Only in lower speed like less than 10-15miles/hr in parking area. I did double and triple checked on all nuts and bolts and all are torqued to specs and tight. Couple videos attached. Note: I have not done an alignment. Thank you in advance. Wanted to see if anybody had similar issue and got it resolved. (You may or may not need headphones to hear it. Camera is under wheel well so the sound of engine is loud too.)
tintumz22 is offline   Reply With Quote
Old 06-19-2020, 10:48 AM   #2
M0nk3y
Where are you at on the valving for the shocks currently?
If you're all the way at zero on the rebound, turn it up a couple clicks and retest.
You could have something on the rebound side of things where the piston isn't completely seating and it making the noise. Especially if it's only occurring at low speed and not high speed (like hitting a highway bridge rut or something) - I'd suspect it's something along those lines.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
tintumz22 (06-19-2020)
Old 06-19-2020, 11:18 AM   #3
tintumz22
tintumz22's Avatar
Thank you for your reply. I'll try that again on my lunch. I tried it full stiff setting, midway and full soft but just drove it in street normally. Maybe I need to drive it harder to push that piston seated.
Old 06-19-2020, 11:44 AM   #4
CSG Mike
CSG Mike's Avatar
Is your top nut properly tightened?
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
DarkPira7e (06-19-2020), DarkSunrise (06-20-2020), tintumz22 (06-19-2020)
Old 06-19-2020, 11:47 AM   #5
Code Monkey
Drives: Subaru BRZ
^ My first thought.
Code Monkey is offline   Reply With Quote
Old 06-19-2020, 12:02 PM   #6
tintumz22
tintumz22's Avatar
Originally Posted by Code Monkey View Post
^ My first thought.
Yes, double checked it too. I tightened to the point that I felt the allen key part is almost gonna give but backed off. Both sides are tight. Or do you guys can suggest a different way to tightened them?
Old 06-19-2020, 12:38 PM   #7
M0nk3y
Allen key?
It's an M12 nut
Kyle H. - #89 STX
Old 06-19-2020, 01:29 PM   #8
tintumz22
tintumz22's Avatar
Allen key?
It's an M12 nut
Sorry, I was not specific. Used an allen key to keep the shaft still and used a passed through wrench to tighten the nut. Use an impact gun to see if that will tighten it better? Not sure if they used impact gun from the rebuilder to install the top hats but I can try that because I have an electric one.
Old 06-19-2020, 01:48 PM   #9
CSG Mike
CSG Mike's Avatar
Use a pass-through torque wrench.
Old 06-19-2020, 02:53 PM   #10
tintumz22
tintumz22's Avatar
I have a normal torque wrench and crows foot for it that can work on a socket. How many ft lbs is recommended to tighten it?
Old 06-19-2020, 03:35 PM   #11
CSG Mike
CSG Mike's Avatar
I have no idea; ask your rebuilder or reference your owner's manual.
Old 06-19-2020, 03:52 PM   #12
tintumz22
tintumz22's Avatar
Thanks. Will do. I appreciate all the replies.
Old 06-19-2020, 06:03 PM   #13
norcalpb
norcalpb's Avatar
Looks like 41lbs
norcalpb is online now   Reply With Quote
The Following User Says Thank You to norcalpb For This Useful Post:
Old 06-19-2020, 08:35 PM   #14
CSG Mike
CSG Mike's Avatar
Stop top hat =/= stock center nut. Depending on his shaft, it may be different, which may have a different torque spec.
OEM is M12x1.25, but Tein and JRZ are both M14x1.5. AST is typically M12x1.25, but not always.
norcalpb (06-20-2020), tintumz22 (06-19-2020)
Newly installed Apexi EXV N1 coilovers clunk noise when car’s cold stlgrym3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-02-2018 01:04 PM
Balance newly installed tires/rims golemslord Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-15-2016 05:44 PM
Newly installed problems JG Engine, Exhaust, Transmission 16 06-27-2015 11:33 AM
Feedback through newly installed tweeters mit_peid Electronics | Audio | NAV | Infotainment 24 04-07-2013 10:05 AM
