View the official forum sponsors list |
03-12-2019, 05:49 PM | #15 |
FT86Club Official Vendor
Drives: Launch-Year Whiteout FR-S
APEX flow formed wheels are manufactured in China, and we have over 13 years of working history with our factory. All of our wheels are built to our specifications, and third-party tested by the VIA in Japan to meet JWL standards.
Please let me know if I can answer any other questions. - Ryan
04-08-2019, 12:42 PM | #17 |
The Following User Says Thank You to ka-t_240 For This Useful Post: | APEX Race Parts (04-08-2019) |
04-19-2020, 03:59 AM | #18 |
Drives: Subaru BRZ 2015 Limited
Hello, I currently have just eibach sportlines 1.5 drop with 245/4017. So I was wondering if I would be able to dial in -1.2 F and -1 R without any rubbing issues? I wanted to run a bit of camber for handling and to tuck the fronts to make it more flush. I also have 5mm spacer incase I do.
04-22-2020, 01:57 PM | #19 | |
- Ryan
05-09-2020, 04:07 PM | #20 | |
Drives: 2018 Subaru BRZ tS
05-11-2020, 01:55 PM | #21 | |
Camber bolts cannot effectively be used with this configuration, as it diminishes clearance further and will lead to rubbing the front suspension. Ultimately adjustable camber plates are the better solution. Not only can do they have have a broader range of camber (and caster adjustment), the tolerance between the wheel/tire and the suspension goes unchanged as everything loves in harmony. If the goal is to maximize performance and increase tire longevity for spirited driving/track use, adjustable camber plates are a no brainer and will pay for themselves quickly. If an enthusiast simply wants to dial in a little negative camber for aesthetics/fitment, then camber bolts are certainly an inexpensive way to accomplish it but a lower offset 9" wheel or spacers would need to be used. We'll soon have 9" ET35 wheels available which will have 7mm of extra strut clearance in comparison to the ET42, however, negative camber will be a requirement to then clear the outer fenders. - Ryan
05-11-2020, 09:10 PM | #22 |
Thank you so much for the explanation, as well as the hint for new offset coming up! I will keep that in mind!
07-02-2020, 05:17 PM | #23 |
Satin Bronze is our newest finish for the ARC-8 design, and has quickly become one of our favorites. What do you guys think?
BRZ Performance Package ARC-8 Wheels in Matte Bronze Finish F&R:17x9" ET42 - 255/40-17 Hankook RS-4
07-28-2020, 03:21 AM | #24 |
Drives: Friggin Really Sweet
Matt bronze look great in red and red BBK’s. Do you have Satin gold for it yet as well? thx!
The Following User Says Thank You to HachirocksU For This Useful Post: | APEX Race Parts (07-28-2020) |
07-28-2020, 09:16 AM | #25 | |
TRACKBREAD
07-28-2020, 01:18 PM | #26 | |
Many enthusiasts performing the camber bolt mod may not understand the pros/cons of going this route vs. dialing in camber at the top through camber plates. Compromising inner clearance between wheel/tire and front struts is not ideal for enthusiasts wanting to run wide wheels and tires, and track enthusiast will want a broader range of camber (and caster adjustment) anyways. - Ryan
07-28-2020, 02:12 PM | #27 | |
We will likely add Satin Gold to the ARC-8 flow form line of wheels as well - Ryan
The Following User Says Thank You to APEX Race Parts For This Useful Post: | HachirocksU (07-29-2020) |
07-28-2020, 03:17 PM | #28 |
JHerbert Racing
Drives: 2013 Scion FRS
Just got a set for my M3. Very impressed with the quality for the price.
The Following User Says Thank You to Takumi788 For This Useful Post: | APEX Race Parts (07-29-2020) |
Similar Threads | ||||
► APEX | FR-S/BRZ Track Wheels V.2 Group Buy | APEX Race Parts | Groupbuys | 77 | 11-25-2017 04:03 PM |
► APEX | FR-S/BRZ Track Wheels V.2 Group Buy | APEX Race Parts | Groupbuys | 211 | 09-19-2016 06:53 PM |
► APEX | FR-S/BRZ Light-Weight Track Wheels | APEX Race Parts | Wheels and Tires | 7 | 05-27-2016 03:18 AM |
► Styluz Wheels ► 17x7 18x7.5 5x100 ► In Stock ► Free Shipping | FM Wheels | Wheels and Tires | 2 | 08-01-2013 05:18 PM |
