Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-15-2018, 05:09 AM | #15 |
Drives: Crystal white brz
Clutch: exedy stage 2 15955
FI: Fullblown stage 1 with 2867 Mi: 20 LOL Power?? Not sure never dyno (I assume same as other kits) Lockout: nope Stiffness: basically stock DD: yup Would I buy again: initial impressions are great, but time will tell. I’ll update once broken in. Review: install super easy. Great clutch feel with interesting engagement. It isn’t jerky but it takes a few times start stop to get used to. So far I’m happy and would recommend. Update: so far it’s doing well. I’m beyond the break in. It does make noise in the 3k-4K rpm range for some reason? Other than that works great. Last edited by Crystalwhitebrzsti; 01-12-2019 at 12:37 PM. Reason: Updating review |
The Following User Says Thank You to Crystalwhitebrzsti For This Useful Post: | ShadowReaper (11-29-2020) |
02-19-2019, 02:54 PM | #16 |
Drives: '13 with go fast bits attached
Clutch: South Bend Clutch Stage 2 (Daily)
SC/T/NA: Supercharged (Edelbrock) MI/KM: 300 Miles Power/TQ: 218 FTLBS TQ Lockout:No Issues yet Stiffness: Slightly stiffer than stock DD?: Yes Would you buy again: Yes Review: The engagement point is slightly deeper than OEM. The engagements are smooth and aside from the lower engagement point that makes it feel like you have a dead spot until you get used to it it's excellent. Holding the power from the Supercharger makes the car feel much more responsive. |
The Following User Says Thank You to diluzio91 For This Useful Post: | PerCompLLC (07-20-2021) |
07-28-2019, 08:30 PM | #17 |
Drives: 2015 midnight blue limited edition.
Finally found the thread I was looking for. I've run into the dreaded TOB problem after 70k miles. I'm NA stock right now but would definitely doing FI turbo in the future. Considering Excedy Stage 2 right now but I'm scared of that TOB. Would you recommend getting another brand altogether. Also anyone think it's worth getting a stronger fork and pivot once you upgrade your clutch ??
08-02-2019, 11:02 PM | #18 |
Drives: 2014 BRZ
Clutch: Exedy Stage 1
SC/T/NA: Turbo - 93 Octane MI/KM: 20k Power/TQ: 300/240 Lockout: None Stiffness: Stock + 10% DD?: Yes Would you buy again: Yes Review: Quiet and extremely easy to drive, completely streetable and feels like an OEM clutch. Just slightly heavier than the stocker, just enough to notice and be confident that the difference is not placebo effect. Engagement point is a **** hair closer to the floor than factory, and you can get going at low rpms. At the power level I'm at right now I have absolutely zero buyer's remorse. Hopefully it will hold up to ethanol, PTuning used it with a 300 wtq car for some time so I might be okay. Will report back when that time comes.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
The Following User Says Thank You to Amputechture For This Useful Post: | Drifter X (01-14-2020) |
01-14-2020, 04:13 AM | #19 |
Guest
Posts: n/a
Clutch: Sachs Performance
SC/T/NA: HKS SC MI/KM: 200miles Power/TQ: 340 HP @ Wheels, 389 TQ/NM @ Wheels Lockout: nope Stiffness: Stiffer than OEM. DD?: Itエs possible but I wouldnエt do it, digital feeling like 1 or 0 nothing in between. Also a lot of roar and vibration while down touring between 2500 -3500rpm. Would you buy again: Yes Review: Clutch feel is better than stock more tension but only for tracktoy or sunday drives. I feel more control but for daily use not mine, Iエm looking for the HKS LA Clutch with flywheel. |
02-03-2020, 08:53 AM | #20 |
Identifying as a Member
Drives: 2013 FRS LS1
Clutch: South Bend Clutches Stage 2 Daily, new Exedy OEM flywheel
SC/T/NA: N/A MI/KM: 1.5k miles Power/TQ: (OFT 2+ with full exhaust) Lockout: No Stiffness: OEM if not softer DD?: Yes Would you buy again: Absolutely Review: I installed a lot at once (IRP shifter, verus tob fork, verus pivot ball, exedy oem flywheel, and SBC stage 2 daily), so there were a lot of changes. But the grab is slightly harder than stock - nothing that you can't adjust to after a few days of driving. The clutch pedal feels lighter than stock (might be for other reasons). Overall I love the feel of the clutch for the higher tq rating values. Also the drive-ability comparison from stock is almost unnoticeable. This thread was a big influence on my decision to buy this clutch kit and I couldn't be happier with my decision. I'm new to SBC but I'll definitely be a repeat customer.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline Last edited by Tomm; 02-05-2020 at 06:18 AM. |
The Following 2 Users Say Thank You to Tomm For This Useful Post: | Drifter X (02-03-2020), PerCompLLC (07-20-2021) |
02-05-2020, 03:07 AM | #21 |
Drives: 2017 Toyota 86
Clutch: ACT SB8 XTSS
SC/T/NA: Turbo(10k miles) NA(10k miles) MI/KM: 20k total Power/TQ: 350/280 and whatever fbo is Lockout: Nothing for the first 17000 miles, started to lock out of 1st when cold. Turned out shifter was out of adjustment. Fixed it when doing clutch fork and pivot. Stiffness?: Before clutch fork is HARD. After I'd say medium to stock. DD?: Break in period is terrible. After break in if tune is not optimized (10% throttle) start and go traffic is a little hard. All things considered it's not too bad you do need to rev it up a little more because of light weight flywheel. Would you buy again: meh idk Review: Clutch engagement is a lot more quicker so you don't need to wait a little after shift. A lot easier to heel toe because revs up faster. Takes a bit getting used to but a must do for track car even at stock power! |
02-05-2020, 12:29 PM | #22 |
First 86 Driver Baby!
Drives: FR-S, Flex
Well my clutch is going out (Comp Clutch Stage 3 w/lightened flywheel), so I'm going to try the Southbend Stage 2 Endurance. I'm dropping my car off at PTuning on Monday to get it done, along with the Verus fork and pivot ball. I'll report back how it compares...
02-10-2020, 06:57 PM | #23 |
Drives: FR-S, Flex
Quick follow-up to my clutch install...the SB clutch is MUCH easier to drive than the CC. It’s been almost 4 years since I installed the CC kit but I can tell the pedal is much softer and easier to depress. My CC engagement point had gotten muddy, meaning it wasn’t always the same place. It always took more force to depress the pedal, but it’s a night and day difference comparing the 2 clutches. I only have about 50 miles on it, so I’ll give a more comprehensive review once I get it broken in, but already I can tell I’m really going to enjoy the SB clutch setup!
03-23-2020, 03:19 AM | #24 |
Drives: 2013 Subaru BRZ
Since I had such a hard time finding reviews of clutches for FI that held power and did not feel awful:
Clutch: Spec Stage 2+ SC/T/NA: Edelbrock supercharger, Flex Fuel MI/KM: 1000 Power/TQ: 300/250 conservatively Lockout: No issues yet Stiffness: OEM DD?: Yes. Would you buy again: (Y/N?) Yes, although it was impulse buy after finding it cheap, but I had used a Spec clutch on my Mustang. Review: I kept the OEM flywheel (new) as I did not want to have drivability issues. I also installed the Verus fork and pivot ball. Engagement window is definitely smaller, but still manageable. Holds power without issue and pedal feels as light as OEM in my memory, but may need another twin for comparison. May return for feedback as I get more miles on the clutch, but am happy thus far. |
The Following User Says Thank You to scraejtp For This Useful Post: | Drifter X (03-23-2020) |
07-08-2020, 08:51 PM | #25 |
Drives: 2016 Scion FRS Halo
Clutch: South Bend Stage 2 DXD racing / 315 ft/lb
SC/T/NA: Edelbrock supercharger MI/KM: about 500 miles total on clutch (not much with supercharger) Power/TQ: Don't know yet .. Lockout: No issues yet Stiffness: very OEM, I like it a little better actually DD?: Not really a DD, around 3-5k annual Would you buy again: (Y/N?) Yes.. I looked over all I could find and almost went ACT.. but a lot of feedback made me think it's more of a track clutch even the tamer ones.. It was threads like this that made me willing to go with South Bend Review: The clutch itself that came with it is an Exedy clutch full disc, I also mated it with an Exedy OEM flywheel. The pressure plate is their forte and I really like it in a street environment so far (not a lot of miles on it yet). It has as some reviewers have mentioned slightly lower engagment beginning (hardly different than OEM). It also has a broader engagement range before fully disengaged or engaged. Makes it easier to ride the clutch shifting through gears, but that's about it. Beyond that it feels very oem .. can tell it grabs better whether it can really hold 315 ft/lbs idk. I doubt I'll throw that much torque at it. I did it with new Verus clutch fork, pivot, and new oem sleeve retainer. I used the TOB in the kit. I hope it holds up because it feels great and I would install another if it does hold up. |
07-08-2020, 09:54 PM | #26 |
Rust bucket enthusiast
SC/T/NA: Turbo MI/KM: 5,000 miles Power/TQ: 330/260 Lockout: None Stiffness: Slightly stiffer than stock DD?: Feels like any sports car from the 90s, definitely doable day to day Would you buy again: definitely Review: Feels like stock but with more authority. No noise, no skipping or hopping in traffic, no noise. Used with stock flywheel. |
10-29-2020, 04:55 PM | #27 |
Master Collaborator
This is an excellent thread to read through now that I am shopping around to beef up my drive train. Has anyone had any experience with McLeod dual-disc, or any of their three other clutches that they have available for this platform?
Here is a link to their top-of-the-line Mag Force SE which I am interested in. Quite expensive, but it is rated at 700 HP: https://www.mcleodracing.com/mag-force-se/p40 And here is all of the choices they have available for this platform: https://www.mcleodracing.com/sport-compact/c28 If anyone has ANY experience with this brand on any OTHER platforms, also please let me know. |
11-29-2020, 05:38 PM | #28 | |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Instagram: 86_Maul |
Similar Threads | ||||
Aftermarket flywheel with the OEM clutch | kster1 | Engine, Exhaust, Transmission | 1 | 10-21-2014 11:11 PM |
WTB: Aftermarket clutch for FI application (FOUND!) | GTB/ZR-1 | Transmission and Driveline | 2 | 09-27-2013 07:21 AM |
Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 10:22 AM |
Island Import Performance - FRS, FT86, BRZ Clutch Master Super Sale!!!! | IslandImportPerformance | Transmission and Driveline | 0 | 06-07-2012 11:49 PM |
What Aftermarket parts would you like to see for the FT86/FRS | mkivalex | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 11-14-2011 10:50 AM |
