01-13-2021, 08:39 AM | #2437 |
Drives: '16 BRZ Limited
I was looking at just getting a smaller fan, but not sure if there's a major difference in 120mm cooler fans. Issue is i can't close the side panel with the included fan installed so right now only running 1 of the 2 140mm fans that came with the cooler.
I would prefer to stick with an air cooled set up, at least for now especially while parts are still harder to get. Also a little nervous with water cooling since this was my first build |
01-13-2021, 08:36 PM | #2438 | |
[insert cool phrase here]
Drives: BRZ Premium
Don't be scared with water cooling. All in one aka AIO are just as simple. Just make sure your case can fit one. That's pretty much it. I did my first build two years ago and I went with an AIO. Zero maintenance.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following 2 Users Say Thank You to Mr.ac For This Useful Post: | soundman98 (01-13-2021), Spuds (01-13-2021) |
01-13-2021, 08:41 PM | #2439 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
If you're set on a slim air cooler, look into the Noctua NH-L9a
The Following 3 Users Say Thank You to weederr33 For This Useful Post: |
01-13-2021, 09:49 PM | #2440 |
The Dictater
Drives: '13 Red Scion FRS
As others have said, all in one water coolers are just as easy to set up as air coolers. The pump unit is small and attaches to the CPU, and the radiator/fan just takes over a fan mount on your case. Most newer cases have thick enough fan mounting locations to support a radiator/fan combo.
The Following User Says Thank You to Spuds For This Useful Post: | meWant (01-13-2021) |
01-13-2021, 10:40 PM | #2441 |
Hmm probably should've researched better prior to purchasing lol. Everything has been assembled since Christmas eve so no more returning for me
The Following User Says Thank You to meWant For This Useful Post: | Spuds (01-14-2021) |
01-14-2021, 12:02 AM | #2442 |
The Dictater
Well, now you can get the mod bug for your PC lol. Think of it as a learning experience. Research is good for figuring out what to do, but truly learning why requires experience. CPU cooler interference is probably the hardest aspect of a build to predict so if that's the only issue you got out of your first build then you did pretty good.
01-14-2021, 12:07 AM | #2443 | |
ProCrastinationConsultant
i had some bad pc memory a while back once. it only caused problems in very specific games at different times. i replaced a $200 power supply because it seemed more voltage related than a bad memory sector-- like my graphics card was pulling more than my power supply could take...
01-14-2021, 12:20 AM | #2444 | |
01-14-2021, 02:00 PM | #2445 |
I didn't see this posted, but gave very strong Dead Space vibes
01-14-2021, 02:12 PM | #2446 |
Drives: 2018 Subaru BRZ
So I followed the advice I got from the forums and changed my plans for the build. This is what I came up with, so far I've only purchased the case and motherboard, no rush on the rest of the stuff since I can't find a GPU anyways.
CPU:AMD Ryzen 5 3600 6 core SSD:Adata XPG Pro 1TB SSD Power: Corsair CX750 750W Fully modular Cooling: Corsair Hydro Series H60 AIO RAM: Corsair Vengeance LPX 16GB Motherboard: ASUS ROG Strix B550 GPU I'm thinking maybe I'll get lucky and get my hands on a 3060ti. |
The Following 4 Users Say Thank You to spcmafia For This Useful Post: |
01-14-2021, 03:24 PM | #2447 | |
The Dictater
01-14-2021, 03:31 PM | #2448 |
Because compromise ®
Drives: Red Herring
AIOs are passé. You need submersed mineral oil cooling.
01-14-2021, 03:56 PM | #2449 | |
The Following User Says Thank You to weederr33 For This Useful Post: | spcmafia (01-15-2021) |
01-14-2021, 08:24 PM | #2450 | |
Drives: BRZ Premium
And this is the Micro Center brand Inland Premium 1TB. I paid $125.
The Following 5 Users Say Thank You to Mr.ac For This Useful Post: | Dadhawk (01-14-2021), meWant (01-15-2021), soundman98 (01-14-2021), spcmafia (01-15-2021), weederr33 (01-15-2021) |
Tags |
pc master race, u no have 3080 |
Similar Threads | ||||
gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 04:32 PM |
GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 06:37 PM |
