Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-26-2021, 12:52 AM | #1 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
Top hats for stock Ts shocks
I was wondering if you can get top hats with camber adjustment for stock Ts brz shocks
Wait until my Flex capacitor hits 88
02-26-2021, 03:50 AM | #2 |
Drives: 17 BRZ ,21 GR Yaris, 23 GR86
Raceseng makes nice top hats
02-26-2021, 09:06 AM | #3 | |
They make great top hats, but I don't recommend them for stock shocks.
- Andrew |
02-26-2021, 01:44 PM | #4 | |
I was going to wear out the stock ts shocks and replace with some Bilsteins and some top hats if possible.
02-26-2021, 05:02 PM | #5 |
Drives: '23 BRZ
On my car, Raceseng plates plus 1.2" lowering springs resulted in bottoming of the stock struts. They work great with same setup with Bilsteins though! What's your ride height?
The Following User Says Thank You to ZDan For This Useful Post: | gen3v8 (02-26-2021) |
02-26-2021, 06:20 PM | #6 |
I have the standard Sti pink springs
02-27-2021, 08:46 AM | #7 |
Drives: '23 BRZ
Should be OK, but camber plates will take away some bump travel so be aware of that. Bilsteins have a lot more bump travel so even at -1.25" ride height I'm OK now. With stock struts the ride was horrendous, front struts would bottom out with a big bang over the *smallest* bumps!
The Following User Says Thank You to ZDan For This Useful Post: | gen3v8 (03-08-2021) |
02-27-2021, 10:25 AM | #8 | |
Not all camber plates take away bump travel...if they mount on top of the OEM spring perch you're okay but most will usually raise ride height slightly. I'm not sure what's easily available for you in Australia, but Pedders, Cusco, and Beatrush have camber plate options. Of those I would probably choose the Beatrush as I generally don't like the generic flat camber plates and worry about them bending (it happens). They'll all raise ride height though (no change in bump travel). We have an option that actually lowers the car and does not remove bump travel, but they're backordered and we're on the other side of the world. - Andrew |
03-08-2021, 01:09 PM | #9 |
Drives: 2020 BRZ
03-08-2021, 04:10 PM | #10 |
Similar Threads | ||||
FS: OEM FR-S struts & shocks w/ top hats, springs, and front end links | indafastln | Brakes, Suspension, Chassis | 0 | 05-16-2017 02:13 PM |
WTB: OEM/stock suspension assembly (springs, shocks, top hats) | f0rge | Canada Classifieds | 4 | 12-07-2015 05:45 PM |
On lowering springs for and stock shocks, time for new shocks... | Basket Case | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-16-2015 08:31 AM |
FRS stock wheels (no tmps) and shocks (with top hats) in 626 | JeffTing | Southern California | 0 | 07-06-2014 01:30 AM |
