Northern California NorCal
Old 07-10-2021, 06:09 PM   #1
abyssFT86
Drives: 2020 BRZ Limited
Peninsula / San Jose: Help with Coilover + End Link + Rear LCA Install
Might be a long shot but putting this out there:
I recently bought some coilovers and am looking for help with install. Looking for either (a) someone on the forum with experience who enjoys doing this kind of install and really knows their stuff or (b) a mechanic shop where I could "ride along" and help do the install. Really love learning and being involved with the process so hoping to find something where I can be involved with the setup rather than just dropping it at a mechanic, though that will obviously be the fallback.
Happy to pay for the help at a rate that we agree on.
This install is a little more complex than some of the plug and play coilover installs in that I need to:
1. Disassemble the coilover to set the bump stop
2. Install new (shorter) front end links
3. Install rear lower control arms to allow adjustment of rear camber.
Open to doing this in my parking space with Jack stands if that is feasible (not sure if it is given the need to load suspension for the end link installs and torque things down) or open to bringing it somewhere that has a lift / better setup.
Let me know if you / someone you know would be a fit.
abyssFT86 is offline   Reply With Quote
Old 07-12-2021, 09:34 PM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Speedelement is nearby you and can help you do the install as well as alignment afterwards. They have a low car friendly alignment machine. I do recommend having them to do it as the suspension needs to be loaded in order to torque properly.
Bach415 is offline   Reply With Quote
Old 08-30-2021, 02:25 PM   #3
Dman8
Drives: 2015 WRB BRZ
Do you still need help? I only joined a few days ago so didn’t see your post until now, but I can help you.
Dman8 is offline   Reply With Quote
DIY: Whiteline Front End Link Install thekevinvo DIY (Do-It-Yourself) Guides 0 09-08-2020 04:30 PM
Rear toe link and toe changes Suberman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-30-2014 06:49 AM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 09:39 PM
Hancha Rear Toe Link Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-05-2013 08:18 PM
Toe Link Install problems SLICVIC Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 03-30-2013 08:20 PM
