Old 10-13-2021, 08:20 PM   #1
sam.eightsix
Drives: 2017 Toyota 860
'17 Toyota 86 - 1st suspension purchase
Hey all,
Having trouble deciding between 3 different coilovers and have a few questions. Usage is for my daily, wanting to lower it about 1.2 inches.
Located in BC, Canada, so I buy pretty much all of my parts from ft86motorsports - to save duties/customs - and there's a promo running that puts all of my top options in the same price category:
1. BC Racing BR Coilovers $1,261.49 (https://www.ft86motorsports.com/prom...-brz-6019.html)
2. Megan Racing Street Series Coilovers $1,208.99 (https://www.ft86motorsports.com/susp...-fr-s-brz.html)
3. Tein Flex A Coilover System wqith Hydraulic Bump Stop $1,298.99 (https://www.ft86motorsports.com/susp...-fr-s-brz.html)
So my questions are:
1. Is it felt unanimously that any one of these is superior? Can anyone note a serious drawback about any one of them?
2. The BC racing have +$200 option to add aluminum damper bodies - why would I want to do this? is it just weight reduction?
3. I won't be tracking the car yet, but friends have been teaching me how to drift a little (as safely as possible on empty rural backroads) so I'd like to know if one stands out for performance - I've read poor things about TEIN for performance, and then read poor things for BC on quality.
4. It is my understanding that rear lower control arms and rear toe arms are a must at the same time - can anyone weigh in? And is there anything else I'd be missing?
Thanks all for your time, thoughts, and advice!
sam.eightsix is offline   Reply With Quote
Old 10-13-2021, 11:37 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
1. No and not really
2. Heat transfer, but most use coated steel for cost and longevity
3. ymmv
4. Factory toe arms are sufficient unless you want to stance the car. Spc camber arms will help keep rear alignment even and allow you to adjust camber properly. Some people get lucky and their car is even and lands where they want with factory parts but they are cheap parts to get it right on the first alignment.
ineedyourdiddly
Old 10-14-2021, 09:24 AM   #3
wparsons
wparsons's Avatar
None of those are great options. What are your priorities with the car? Just having it low? Good ride quality?
flickr
Old 10-14-2021, 12:53 PM   #4
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Apexi EXV
Fortune Auto 500
Tein Flex A
BC and Megan can go rust on a civic.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 10-14-2021, 01:01 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
IMO you do not need either rear LCAs or toe arms. Ive been streeting and tracking on the stock ones for 4 years at -1.25" ride height on Swift lowering springs (w/ Bilsteins), 40 track days and approaching 60k street miles.
Old 10-14-2021, 06:13 PM   #6
Poogchomp
Poogchomp's Avatar
Drives: Chevrolet Ram 250
1. If I was forced to pick one from your list I'd go with the teins. BC and Megan are, no.
2. Weight reduction, heat transfer, and corrosion resistance.
3. You might be happy with the teins, or you might be better off saving for something better for future track use. As someone previously stated, your mileage may vary.
4. Toe arms not necessary unless you go crazy with negative camber. Rear lca will be necessary if you want the adjustability. Spec rear lcas are fairly cheap so why not. You might want to get front camer bolts if you don't go with an option that has camber plates or slotted mounts if you want front camber adjustments.
This is just my usually incorrect opinion though.
Poogchomp is offline   Reply With Quote
Old 10-15-2021, 09:34 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Rear LCAs are IMO overprescribed. Rear camber will most likely be about where you want it when lowered anyway, if lateral grip is a priority. For sure there's no reason to get them until you see where you are with the stock arms.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Calum (10-15-2021), x808drifter (10-15-2021)
Old 10-15-2021, 04:42 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
And a set of camber bolts can get you enough adjustment to even things out of you run into a minor side to side difference.
coilovers, suspension
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
Cusco: Toyota 86 / Subaru BRZ Suspension & Bracing !! Speed Element Brakes, Suspension, Chassis 42 06-14-2013 02:20 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
I think Toyota/Scion is making a BIG mistake with the FR-S' suspension tuning Impey Barbicane Suspension | Chassis | Brakes -- Sponsored by 949 Racing 128 03-27-2012 12:34 PM
