11-22-2021, 09:19 PM | #1 |
Drives: 22 BRZ limited
What did you do to your 2nd gen BRZ today?
Let's get this second gen thread going.
I installed my STI start button from my 20. I also installed my flexible v-bars. While I had the dsh apart I went ahead and removed the engine speaker that was right there. I also found a quick and easy way to unplug the active sound control(engine noise speaker computer). Open the passenger door, remove the side panel and the plug for the unit is right there. I was able to get a couple of fingers in there and dialed the plug. See the attached photos. Last edited by dragoontwo; 12-06-2021 at 07:39 PM. Reason: Title change. |
The Following 24 Users Say Thank You to dragoontwo For This Useful Post: | bcj (11-24-2021), bholliday (12-02-2021), Busybee (12-16-2023), Dzmitry (11-23-2021), Espi (03-18-2022), FritoPendejo (11-22-2021), Frost (11-23-2021), JusTheG (11-24-2021), Kona61 (11-22-2021), Lonewolf (11-22-2021), mazeroni (11-23-2021), Midnightsky (11-22-2021), NoGoodNames (01-14-2022), Ohio Enthusiast (11-23-2021), Pete (11-23-2021), PhatFreshPrince (11-23-2021), Racecomp Engineering (11-23-2021), soundman98 (11-23-2021), Spuds (11-27-2021), Sym (11-24-2021), tenderization (11-22-2021), timurrrr (11-23-2021), wolffbite (11-24-2021), Yoshoobaroo (11-23-2021) |
11-22-2021, 09:41 PM | #2 |
Drives: FRS
How thoughtful of them to have made it so easy.
Got wheels swapped back to OEM on the FRS so I can swap my Motegis onto the BRZ when it finally arrives, got tradein value for it as well. They offered me more than carvana did so I'm happy with that. |
11-23-2021, 09:14 AM | #3 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
So just unplug that lower plug on the bottom of the silver box?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
The Following User Says Thank You to Frost For This Useful Post: | PhatFreshPrince (11-23-2021) |
11-23-2021, 09:34 AM | #4 |
The Following 4 Users Say Thank You to dragoontwo For This Useful Post: |
11-23-2021, 10:46 AM | #5 | |
TRACKBREAD
What did you do to your BRZ today?
Do you have the part number for that switch? It looks different from the others I’ve seen. How was the install?
11-23-2021, 11:02 AM | #6 | ||
Lots of dash removal to get to the little bugger. The HVAC control panel needs to come off, so the radio panel also needs to be slid out far enough to get it off. Quote:
The Following User Says Thank You to dragoontwo For This Useful Post: | Yoshoobaroo (11-23-2021) |
11-23-2021, 06:09 PM | #7 |
No codes readable from my end having the ASC disconnected. Not sure what the dealer may see, but also don't care.
Re: STI push button. I'm a dumbass. It's even easier than the last model to replace. Just grab the trim around the button and pull it straight out. It can be a bit fussy lining it up to reinstall though. Should take less than a minute to change. |
The Following 3 Users Say Thank You to dragoontwo For This Useful Post: |
11-23-2021, 07:16 PM | #8 |
TRACKBREAD
Got her home!
The Following 25 Users Say Thank You to Yoshoobaroo For This Useful Post: | alphasaur (11-24-2021), azndavepgh (11-23-2021), Blighty (11-24-2021), BrahmaBull1990 (12-06-2021), Busybee (12-16-2023), dragoontwo (11-23-2021), Dzmitry (11-24-2021), Espi (03-18-2022), JD001 (12-24-2021), Jegan_V (11-23-2021), JusTheG (11-24-2021), Kona61 (11-24-2021), mazeroni (11-25-2021), MikeNSX2 (11-23-2021), MyHybridBurnsGasAndTires (11-23-2021), Panda Grahams (11-23-2021), PhatFreshPrince (11-24-2021), Racecomp Engineering (01-02-2022), slimfit (11-23-2021), soundman98 (11-23-2021), SpectreRT (11-23-2021), spike021 (12-23-2021), Stonehorsw (11-23-2021), tenderization (11-24-2021), timurrrr (11-23-2021) |
11-23-2021, 09:41 PM | #9 |
Drives: Ice Silver 2022 BRZ Limited
Ordered a stainless steel WC Lathewerks shift knob.
Chris makes outstanding shift knobs, and I have one in my Focus ST and had one in my just sold Miata ND. |
11-23-2021, 09:48 PM | #10 |
Drives: Subaru BRZ
11-23-2021, 10:42 PM | #11 |
TRACKBREAD
I tried my tomei Duracon type SS shift knob and it didn’t fit. It screwed on just fine until it had to fit over the reverse lockout, looks like that diameter is a bit bigger now.
Edit: the new shift knob has a 27.75mm diameter bore for the reverse lockout. The old shift knobs were only ~24mm. For everyone considering custom made knobs, make sure your machinist knows this dimension is different from the 1st gen cars. Last edited by Yoshoobaroo; 11-24-2021 at 09:27 AM. |
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post: |
11-24-2021, 10:26 AM | #12 | |
Mebmer
Drives: Sienna, GR86, FL5
The car seems to make a not-so-nice buzzy sound that I think/hope is all coming from the generator. Reviewer comments seem to be neutral to negative about it. I guess the thing will be EV quiet without it, but that's where aftermarket can begin. Big thanks for being probably the first person to get to the bottom of this one! |
11-24-2021, 10:37 AM | #13 |
TRACKBREAD
1st milestone
11-24-2021, 12:19 PM | #14 |
The Following 2 Users Say Thank You to Frost For This Useful Post: | timurrrr (11-24-2021), Yoshoobaroo (11-24-2021) |
Similar Threads | ||||
WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 10:36 PM |
Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 02:51 PM |
just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 10:05 PM |
TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 01:16 AM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
