Old 01-09-2022, 04:59 PM   #15
dreamwonder
Drives: GR86 2022
are the tow hook plate mounts no longer an option on the new gen?
Not sure, but not a fan of the off center position. I actually tried just taping on the license plate only, like I did for the previous 2 FRSes I had but there is curvature on the grill that makes it very difficult to do so.
dreamwonder is offline   Reply With Quote
The Following User Says Thank You to dreamwonder For This Useful Post:
soundman98 (01-09-2022)
Old 01-09-2022, 05:03 PM   #16
dreamwonder
Drives: GR86 2022
Originally Posted by Chan View Post
Congrats! I’m assuming that’s the Steel color. I have the same one coming hopefully early Feb. I specifically asked my dealer not to put on the front bracket.
I like what you did there. Did you ask the dealer for that bracket? Or did you just get an aftermarket one?
Thanks, yes the color is Steel. The bracket is oem, you will find it in the truck (assuming dealer did not already installed it).
Old 01-12-2022, 08:26 AM   #17
dreamwonder
Drives: GR86 2022
Swapped the oem mirror with a Gentax auto dim. Mirror was $86 on amazon and wire harness was $12 from local dealer (not required if slicing into car's wiring).
Gentex Series 8 FramelessAuto-Dimming Mirror 50-genk8a
The Following 2 Users Say Thank You to dreamwonder For This Useful Post:
jkamelo (01-13-2022), soundman98 (01-12-2022)
Old 01-15-2022, 03:13 PM   #18
dreamwonder
Drives: GR86 2022
Got a working solution for mounting the Garmin Catalyst, holds the phone too.
eSamcore Phone Holder for Car, $12 on Amazon.
jongers (01-15-2022), Pat (01-16-2022)
Old 01-16-2022, 12:03 PM   #19
driveside79
driveside79's Avatar
Drives: 2022 GR86 MT
Looks like you had to do some re-wiring work to the harness you bought? Can you share details on that please? Thanks!
driveside79 is offline   Reply With Quote
Old 01-16-2022, 12:23 PM   #20
Pat
Pat's Avatar
Drives: 2023 BRZ
Looks like some custom work there. Care to share more details?
How does it hold the phone? Just using the same interface as the Catalyst? Or do you remove that for the phone mount?
The more details you can share the better. And pictures of it exploded would be helpful.
Old 01-17-2022, 03:23 PM   #21
dreamwonder
Drives: GR86 2022
Yea, when I did it to my previous 86es, it was just plug and play with that oem harness, so I guess this time either I bought the wrong version of the mirror or the plug type changed.
Mirror comes with a wired connector, so what I did was took the oem harness, cut off the black connector and patched the mirror's connector to it.
--Oem harness middle wire is ground, connects to the black wire of the mirror's connector.
--Oem harness white wire is the switched 12v, connects to the red wire of the mirror's connector.
Old 01-17-2022, 03:38 PM   #22
dreamwonder
Drives: GR86 2022
The phone is held with the Catalyst interface. Its not a strong hold but it has only fell on me maybe once, since last spring. The trick is to make sure the phone's metal plate is on the outside so that it doesn't slip down. Or even a piece of tape will do.
The catalyst is attached to the mount with the help of a random piece of plastic that was sanded with very rough sand paper to help with adhesion.
--Catalyst to plastic, 3M double sided tape, the 30lb version.
--plastic to phone mount, crazy glue. Sealed it off with some rtv, probably not needed but whatever.
Wire management is just 3M double sided tape.
Pat (01-17-2022)
Old 01-17-2022, 05:38 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
Thank you. I tried using the Catalyst mount for my phone, too. It does work most of the time, but just didn't make me feel it was quite secure enough.
Old 01-22-2022, 12:47 AM   #24
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
Ticked 300 miles off the break-in milage.
Installed an auto-dimming HomeLink mirror (Subaru part). Works nice.
Stocked my Tic-Tac cubby with six classic peppermint pieces:
McMCOO is offline   Reply With Quote
The Following 5 Users Say Thank You to McMCOO For This Useful Post:
636 (04-05-2022), Blighty (01-23-2022), MJones_RB (06-08-2022), mn_ca (01-22-2022), Varelco (02-01-2022)
Old 01-22-2022, 12:52 PM   #25
dreamwonder
Drives: GR86 2022
Read the manual today and found an easter egg on page 107ish. The pin unlock feature is very cool.
Old 01-22-2022, 06:11 PM   #26
Cunilingus69
Drives: GR86
I hit the fuel cut off in 1st and 2nd realized I didn't have the buzzer on. The revs run out so fast. Came from a car that did 80 in 2nd.
Cunilingus69 is offline   Reply With Quote
The Following User Says Thank You to Cunilingus69 For This Useful Post:
soundman98 (01-22-2022)
Old 01-22-2022, 08:00 PM   #27
McMCOO
Anti-Social Media
McMCOO's Avatar
I did another 400 miles today. I'm 60 miles short of 1000. Drove from Vancouver, WA to Yakima and return using non-freeway route. Getting really good at the 4k thing. Kinda good. Ok a B-minus for sure. Perfect weather and in the mid-40s except in a couple spots. My Prius tires didn't kill me.
At Costco now getting CrossClimate2's for the winter.
The Following 2 Users Say Thank You to McMCOO For This Useful Post:
Pete (01-24-2022), Stonehorsw (01-22-2022)
Old 01-24-2022, 01:39 PM   #28
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Are these consumed by suction of mouth?
Dzmitry is offline   Reply With Quote
GR86 Premium MPG joeDoe GR86 General Topics (2nd Gen 2022+ Toyota 86) 40 01-31-2022 01:03 PM
Why BRZ Over GR86? Lelandjt BRZ Second-Gen (2022+) -- General Topics 45 12-26-2021 08:41 AM
GR86/BRZ Aerodynamics Jianlun GR86 General Topics (2nd Gen 2022+ Toyota 86) 4 12-15-2021 10:39 AM
GR86 PCD teppey GR86 General Topics (2nd Gen 2022+ Toyota 86) 23 07-29-2021 11:12 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 37 07-18-2021 03:38 PM
