01-23-2022, 10:11 PM | #295 | |
Drives: Frs
So depending on the desired height you will rub. I know the question is for the back but for sure you will rub right before full lock with too much camber and or low height up front. (This is of course with +45 rims) Just relaying what I went through……
Ridiculous!
01-24-2022, 10:54 AM | #296 |
Drives: 1996 Turbo Miata
01-24-2022, 11:16 AM | #297 | |
Drives: '23 BRZ Limited
01-24-2022, 11:17 AM | #298 | |
01-24-2022, 11:41 AM | #299 |
Drives: Frs
Folks with +35 offset are rubbing the outer fender in the back according to some postings I’ve read.
Ridiculous!
01-24-2022, 11:42 AM | #300 |
FT86Club Official Vendor
Drives: GR86/FRS/GT3RS/F80/E92M/E46M/FK8CTR
This is going to be the weak point for many aftermarket wheel companies. We are working in tandem with manufacturers to produce sets in an offset range/width combo that should work with little to no chassis modification - the last thing anyone wants to do is to cut up their new car.
SYSTEM MOTORSPORTS Top Distributor for Rays Engineering / Volk / Advan / BBS / Work / SSR, & More! www.systemmotorsports.com thomson@systemmotorsports.com / sales@systemmotorsports.com Follow us on Instagram! / OUR '22 GR86 BUILD THREAD |
01-24-2022, 11:44 AM | #301 |
Realistically all new orders are about ~8-10+ months from initial date of ordering, and even then that's an estimation. Right now the bulk of our inbound shipments from Rays/Volk/Advan that are coming in as we speak were ordered around ~Feb/March 2021.
The Following User Says Thank You to systemmotorsports For This Useful Post: | Kona61 (01-24-2022) |
01-24-2022, 11:56 AM | #302 |
Drives: 2022 WRB Limited 6 Speed
So I decided with another wheel instead of 57DR..
Still same specs though. Just placed an order for some white Work Emotion D9R's in 18x9.5 +38 with a custom 5x100 bolt pattern directly from work. My options I'm thinking for setups right now is.. 1.) 245/35 tires, will need to shave/trim inner fenders for sure If I want to aim for a 2 inch drop 2.) 225/40 tires, more stretch than I would like.. but I think it would work. Probably still fender trim/shave 3.) 235/30 tires, eh not really sure if I'd do this, would prefer more meat. But I'm open to it |
01-24-2022, 11:58 AM | #303 | |
I really wanted to aim for a 2 inch drop since I'll be trimming but I'll see how i feel once my wheels arrive (Work Emotion D9R) From what I've seen, those specs on 255 are very doable with no trimming as long as you do a very conservative drop, probably an inch or so |
01-24-2022, 12:08 PM | #304 |
Drives: 2017 86 860 Special Edition
I'm seeing a lot of 9-9.5 widths with stretched 225/235 tires. What I would like to see is what offset is needed with R-comp/200tw 245-255 tires on these widths.
I guess like all things once more of these cars are out there and modified the answer will reveal itself. |
The Following User Says Thank You to RayRay88 For This Useful Post: | Pete (01-24-2022) |
01-24-2022, 12:29 PM | #305 | |
First on our list is 18x10 with a 255/265 R-comp.
01-24-2022, 01:18 PM | #306 | |
Drives: 2022 BRZ Sport-Tech
Yea, so Imma do 20mm or full inch drop and at least -2 camber rear. Hopefully I can have this tried out in March. Picking up the wheels anytime soon? |
01-24-2022, 01:47 PM | #307 |
Drives: 2022 GR86
Just to make future archaeology simpler, here's the link to that thread:
https://www.ft86club.com/forums/showthread.php?t=148559 (you know, message footers tend to change over time) |
The Following User Says Thank You to timurrrr For This Useful Post: | systemmotorsports (01-24-2022) |
01-24-2022, 02:21 PM | #308 | |
Just got my pre order in and a work representative reached back out to the company I'm buying from and said it's March-April ETA. Just in time for summer. |
Similar Threads | ||||
Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
