Old 03-06-2018, 04:31 PM   #127
DC2R
Drives: 2014 Scion FR-S
Seems to be hit or miss with some of these installations. Got condensation but if I'm spending $35 on gaskets I want it to work for sure. Is the gaskets and adhesive sufficient?
DC2R is offline   Reply With Quote
Old 03-11-2018, 08:07 AM   #128
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
PM'd you!
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
The Following User Says Thank You to wdninja For This Useful Post:
DC2R (03-11-2018)
Old 01-27-2022, 02:55 PM   #129
RFB
RFB's Avatar
Drives: FRS
Originally Posted by RFB View Post
Sure seems like it really sucks the water past the gaskets !
The water came down the channel and UNDER the tape and through the gasket .
Four and a half years ago, with the Toyota oem gaskets, I sealed the top of the tail lights (as per my original post) with snow man snot from the dollar store (any waterproof putty will do).
The tails are still dry.
Now after many years, the snow man snot has dried on one tail light and allowed a leak at the usual spot. Had eight ounces of rain water inside.
After draining and drying , I replaced the trunk seal with white paste rubber (flex seal) , and also used it on the new stock gasket so it will last more than ten years this time.
The trunk snowman snot trick still works. It should be done on any gen 1 twin as water will always attack unless the path of the trunk sluice stops flooding the water down.
RFB is offline   Reply With Quote
condensation, diy, gaskets, tail lights
Tail Light Condensation rbrtndrws Issues | Warranty | Recalls / TSB 1033 04-16-2019 10:57 AM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
tail light Sketch575 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-11-2012 02:32 AM
Tail light replacement? alexm Cosmetic Modification (Interior/Exterior/Lighting) 5 06-05-2012 04:38 PM
