Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-17-2022, 07:43 AM | #1 |
Drives: 2013 FRS
Rear springs for Tarmac 2
Hi, I have the RCE Tarmac 2s (KW clubsports) and would like to stiffen the rear slightly. Currently has the 70-170 blue springs they came with. 400# or 7kg I think. What springs can I get and where?
WIFE: "How can there be anything left to buy?"
06-17-2022, 09:00 AM | #2 | |
We do Swifts generally...60mm ID. Give us a call if you'd like to order or send us an email. 8 kg/mm is a common way to go in the rear if you're keeping the fronts at 7. Any stiffer than that in the rear and I'd recommend increasing front rates as well. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | bmacfrs (06-17-2022) |
06-17-2022, 12:31 PM | #3 | |
Drives: 2013 FRS
06-17-2022, 01:53 PM | #4 |
7 inch
06-19-2022, 09:44 AM | #5 |
Drives: 2020 BRZ Sport Tech RS
Why not order the 80-170 spring kit from ST suspensions?
06-19-2022, 07:11 PM | #6 | |
Drives: '13 FRS - STX
A pair of eibach or hyperco springs with shipping should be <$150. |
The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (06-27-2022) |
06-22-2022, 02:53 PM | #7 |
Meh - for me, I'd rather pay the difference to have the ST/KW springs and have them match (colour-wise) the original front springs, but I'm picky like that...LOL.
07-13-2022, 09:26 PM | #8 |
Drives: 2013 FRS
So I found a set of Swift springs that are 60mm diameter, 8kg, and 178mm length (7inch). Looking at their part number sheet this is the only length they have in that diameter and rate. The originals on the shock is 170mm (6.67 inch). Installing these by simply replacing the spring and inculding the helper and spacer rings collapses the helper all the way. Its not crushed by theres no room left. Is this okay or do I HAVE to find 7 inch springs?
07-13-2022, 09:29 PM | #9 | |
Drives: 2013 FRS
Sent from my SM-S901U using Tapatalk
07-13-2022, 09:59 PM | #10 |
That's totally fine like that. If you were to lower the car more the helpers would be uh, helpful to keep the main springs captive. But at your current height they're just taking up space, which is fine though you could remove them.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | bmacfrs (07-14-2022) |
07-13-2022, 10:14 PM | #11 |
Drives: Crapcan
Mine are like that too. It’s no big deal.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | bmacfrs (07-14-2022) |
07-14-2022, 10:01 PM | #12 | |
Drives: 2013 FRS
I assume I will need to readjust lower?
Similar Threads | ||||
FS: RCE Tarmac springs | mpoynter | Brakes, Suspension, Chassis | 2 | 12-02-2017 07:34 AM |
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs | leunglambs | NY / NJ / CT / PA | 3 | 06-09-2017 02:49 PM |
FS: RCE Tarmac Springs | trippinbillies40 | Brakes, Suspension, Chassis | 1 | 05-26-2017 06:40 PM |
wtb: rce tarmac springs | redlined600 | Want-To-Buy Requests | 0 | 04-09-2015 12:52 PM |
RCE Springs from Tarmac Zero - 280# NEW | jack43 | Brakes, Suspension, Chassis | 0 | 03-22-2014 02:41 PM |
