08-18-2022, 10:08 AM | #701 |
Drives: '23 BRZ Limited
Do you guys not RTFM? lol
In the US, outside of Hyundai/Kia, it's pretty standard to have a: 3/36 - Bumper to bumper 5/60 - Powertrain 5/unlimited for rust Emissions is a bit different.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | raisingAnarchy (08-19-2022), Tcoat (08-18-2022) |
08-18-2022, 10:28 AM | #702 |
1st86 Driver!
In the US, the Feds require the emissions warranty for light-duty vehicles to be at minimum all emissions related parts are covered for 2 years or 24,000 miles, with the catalytic converter and ECU covered for 8 years or 80,000 miles.
That is why most areas with emissions testing requirement usually exclude the first two years. I think the requirement in California may be higher but not sure. For example, seems I remember that they require any car considered to be "low emissions" such as plug in hybrids, to be warranted up to 15 years/150,000 miles for any part that would make the check engine light come on.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (08-18-2022) |
08-18-2022, 11:19 AM | #703 | |
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Dadhawk (08-18-2022) |
08-18-2022, 08:45 PM | #704 |
Drives: 2022 GR86
1k Oil change analysis by Blackstone. Note the RTV comment.
The Following 5 Users Say Thank You to Starbucker For This Useful Post: | Dadhawk (08-19-2022), DylanJZA (08-19-2022), JusTheG (08-19-2022), soundman98 (08-18-2022), Tcoat (08-19-2022) |
08-18-2022, 09:08 PM | #705 |
ProCrastinationConsultant
i thought you and tcoat had both said something similar before,
one shouldn't really be watching the UOA for silicone products, but for increased engine wear indicators, indicating poor lubrication from reduced pressure and/or blocked passageways.
The Following User Says Thank You to soundman98 For This Useful Post: | Tcoat (08-19-2022) |
08-18-2022, 09:41 PM | #706 |
Drives: honda element
wood i be wrong to think that the problematic RTV wouldnt necessarily show in the oil sample?
think of it like this. the RTV isnt meant to dissolve in the oil - the opposite. assumably the exposed bead on the inside of the oil pan is touching oil all the time. if a piece falls into the oil - its floating, getting sucked to the pickup - but is it dissolving into the oil though (enough to show on a test)? hell if it was - it wouldnt be that bigga issue - because then it would get through the pickup screen, hit the filter, and be gone with an oil change. |
The Following User Says Thank You to austintampa For This Useful Post: | Petah78 (08-18-2022) |
08-18-2022, 09:42 PM | #707 | |
The Following 6 Users Say Thank You to OkieSnuffBox For This Useful Post: | flippy (09-13-2022), justinco (08-19-2022), Petah78 (08-18-2022), raisingAnarchy (08-19-2022), Tcoat (08-19-2022), Ultramaroon (08-19-2022) |
08-18-2022, 10:05 PM | #708 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
The Following User Says Thank You to Petah78 For This Useful Post: | soundman98 (08-18-2022) |
08-18-2022, 10:43 PM | #709 | |
i know how to fix this for owners - i dont know how to manufacture it but I might give it a shot. |
08-19-2022, 06:14 AM | #710 |
Thanks!
Yes there will be higher silicone and metals in the first couple of tests. As the analysis very clearly states that is perfectly normal and expected. Hell, if it didn't show elevated silicone in the first sample I would question the validity of the test! If you are still getting high metals by the third or fourth test THEN you can start to worry.
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (08-19-2022) |
08-19-2022, 06:28 AM | #711 | ||
A) All the sealant starts being introduced before the filter B) All the oil passes through the filter at all times. Not going to repeat the whole thing but neither of these assumptions can be made. Quote:
As you yourself demonstrated by opening up the filter there are at least 4 different sealants used. Between all your pictures we have grey, green, pink and black. Of all of them the one I would be most curious as to the source would be the green. It has a high probability of being introduced someplace between the filter and the pan. There is also a lot of it and those little flat pieces could act as a valve while plugging a channel. Under the right pressure they could open and let enough oil through but get just the wrong combination of conditions and they suck closed and BANG.
08-19-2022, 07:01 AM | #712 | |
I always assumed that the factory fill was just normal oil but those are all oil additives to reduce wear not the byproduct of engine operation. There is so, so much moly that I can't help but think that the factory fill is actually a special oil specifically for break in. If this is the case then guys that preach the "get that crap out as fast as you can" method are not doing themselves any favours.
The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Decep (08-20-2022), OldBiker (07-05-2023), Opie (08-22-2022), Petah78 (08-19-2022), soundman98 (08-19-2022) |
08-19-2022, 07:43 AM | #713 | |
08-19-2022, 10:52 AM | #714 |
Drives: Subaru BRZ
Here's mine, this is not the OEM fill, which I drained after 975 miles, but Motul 300V 5w-30 after three HPDE weekends. I though my copper level was high, but not worried anymore looking at the report above.
The Following 5 Users Say Thank You to Code Monkey For This Useful Post: | DarkSunrise (08-20-2022), DylanJZA (08-19-2022), JusTheG (08-19-2022), Petah78 (08-19-2022), Tcoat (08-19-2022) |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
