Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-08-2022, 11:07 PM | #1 |
Drives: Gr86
AP Racing Brake kit — options for rear brakes
Ready to pick up an AP Racing brake kit. Wondering what my options are for upgrading the rear brakes. I watched a video of a guy swapping the rear calipers with the stock front calipers, but he didn’t list the rotors he used in the rear to fit the stock front calipers. Any ideas?
Or any better ideas on how to improve the rear brakes? |
07-09-2022, 08:03 AM | #3 |
ProCrastinationConsultant
i thought the official response from AP racing was that they were designed around keeping the balance with the oem rear calipers.
07-11-2022, 02:57 PM | #4 |
Drives: #337 2017 Toyota 86
Stock rear calipers are a good match for the AP Racing Sprint front kit. There is no real need to update the rear calipers.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
The Following User Says Thank You to Lincoln Logs For This Useful Post: | JRitt (09-30-2022) |
07-11-2022, 06:33 PM | #5 | |
PM to order, and I'll get you squared away. Keep in mind Essex/AP has not delivered ANY production kits for the 22+ yet, so it'll be a preorder and your kit will ship as soon as the kits actually make it out of production. |
07-15-2022, 11:21 AM | #6 | |
Drives: 2012 BRZ Premium WRB 6MT
Whatever pads you decide to go with in our front AP Racing brake kit, just get the same matching pad compound for your rear OEM calipers. Also, make sure you have some good brake fluid. We recommend AP Racing R2. Shoot me a PM if you need more personalized recommendations. Thanks!
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com |
The Following 2 Users Say Thank You to JRitt For This Useful Post: | chickunfut (09-30-2022), soundman98 (07-15-2022) |
07-16-2022, 10:40 AM | #7 | |
Drives: 18 Brz (Sold) / 22 BRZ
Is gen1 square set-up for pads? Gen2 is staggered, with GG on Fronts and FF on rears. Putting a square setup on that, would move 5-10% the bias to rear axle. |
The Following User Says Thank You to Stonehorsw For This Useful Post: | Pat (07-16-2022) |
07-18-2022, 03:29 PM | #8 |
Gen 2 should also be square unless you have a specifically designed stagger, or have a specific reason for doing it.
07-18-2022, 04:06 PM | #9 | |
Front: AK (Akebono) FA431 GG Rear: NBK (Nisshimbo) FN410 FF Terminology according to SAE J866 (tested as per J661) |
07-18-2022, 04:30 PM | #10 |
Factory pads are not, so that they can identify who's abusing the car (the new front has a temp paint stripe), but for performance driving applications, nothing has changed.
07-18-2022, 05:55 PM | #11 | |
Anyways, when I was going to the track, the brake controls engineer that worked with this unit for other applications reviewed (dry conditions) and did not see big issues. Just a little bit of laggy response of the brake controls. Other thing, sometimes is good to turn off controls if pushing hard, as you know. |
09-29-2022, 11:39 PM | #12 |
Drives: Toyota 86
I am interesting to upgrade my front brake to the "Essex - AP Racing Competition Endurance", and I see the disc size is 325x32mm.
Now, from this discussion, I understand I don't need to upgrade the Rear Brake, just replace the pad to the same as the front brake use. And if I leave the Rear parts as it is, the OEM disc is 290 x 18mm. I am wondering is there a need to upgrade the rear disc? Not just for the performance, but also for the looks as well. Or maybe I just chose the Essex AP Racing Big Brake Kit (SPRINT) - 299x32 mm version. It is 600 USD cheaper I don't do heavy track. I DD my 86, but spirited driving my car in any chance I get. Any feedback will be appreciated. |
09-30-2022, 07:50 AM | #13 | |
Unless you are having some specific rear brake problem, there's no need to change your rear discs. Yes, you could just change them to something with a slot and they would look better, but that wouldn't be a major performance gain. I'd suggest running the Ferodo DS2500 pads we offer with our kit, and also get a set of DS2500 for your OEM rear calipers. They are a fantastic sport pad and will do everything you'll ever need. In terms of choosing the Sprint 299mm BBK vs. our 325mm kit, it sounds like the smaller Sprint Kit would do everything you need. Our 299mm Kit has won endurance racing championships. Here is a link to an article I wrote to help you choose: FT86 299mm vs. 325mm AP Racing by Essex Brake Kit Comparison Let us know if you need any additional guidance and thank you for your consideration!
The Following User Says Thank You to JRitt For This Useful Post: | CSG Mike (09-30-2022) |
09-30-2022, 11:32 AM | #14 | |
Drives: Toyota 86
The Following User Says Thank You to twasd For This Useful Post: | JRitt (10-06-2022) |
Similar Threads | ||||
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 05:53 PM |
Dual (Independent) Rear Calipers for Brakes & E-Brake | Wesley | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 11-15-2016 09:08 PM |
FS: 6-pot/4-pot Front/Rear Big Brake kit by RR Racing | Kostamojen | Brakes, Suspension, Chassis | 1 | 10-04-2016 07:10 PM |
Brembo: GT, GT-R, Club Sport Brakes, AP Racing BBK & Agency Power Brake & Clutch Line | eauto | Brakes, Suspension, Chassis | 361 | 10-15-2014 01:43 PM |
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc | smellslikecurry | Brakes, Suspension, Chassis | 27 | 08-15-2014 11:52 AM |
