DIY (Do-It-Yourself) Guides For all DIYs. |
09-23-2020, 09:30 PM | #1 |
AEM CD-7 Digital Dash Swap Information
Been looking around the forums and internet and can’t seem to find anyone who has done a gauge cluster swap on an FR-S/BRZ/GT86 for the AEM CD-7 Digital Dash. Specifically trying to prepare for any issues I might run into with effectively deleting the stock factory cluster given I worry that the ECU might have some issues with that cluster not being connected. Anyone with experience doing this or some guidance on where I might find some more information would be great!
10-01-2020, 05:39 PM | #2 |
Drives: Scion FR-S Series 10 #2462
Since the AEM just connects to the OBDII port, you could just keep the stock gauges plugged in and hidden in the dash.
10-01-2020, 10:15 PM | #3 | |
Drives: MR2, Sliver BRZ
Most of this wont be a issue maybe if you have a racecar.. but replacing cluster other then that will be pretty hard. Im sure im forgetting a couple of other bigger things but a lot of issues. Lastly.. OBD2 is not the same as canbus. So although is supports obd2 you still need a way to replicate the canbus system,Completely different.
Always looking to tinker with something..
01-11-2021, 04:40 PM | #4 | |
Given all this and my desire to keep the car street friendly, I am going to look to figure out a mounting solution to get my dash attached to the steering column sitting in front of the stock cluster. |
12-08-2022, 01:37 AM | #5 |
Idiot
Drives: 2014 BRZ
Hey geraldjust, since there's almost no information about cluster swapping the on the internet would you be willing to go into more detail into the AEM swap? Perhaps a tutorial or some kind of instructions if its not too much to ask?
12-08-2022, 03:17 AM | #6 |
As explained above, unless your running a aftermarket ecu, you cant do much of the advanced functions or replace the stock cluster. If your willing to mount your CD-7 on top of your existing cluster then get the OBD2 kit you can get with your AEM. But then its pretty self explanatory.
Tags |
aem, dash, gauge, gauge cluster |
Similar Threads | ||||
In-dash digital speedometer | vaer | Electronics | Audio | NAV | Infotainment | 4 | 04-14-2020 10:19 AM |
(FS) IL - BNIB: AEM Digital Gauge Set with ATI Dash Pod (willing to split) | ildylan | Interior Parts (Incl. Lighting) | 6 | 10-09-2015 04:15 PM |
Digital race dash | Trap63 | Electronics | Audio | NAV | Infotainment | 1 | 09-22-2013 04:17 PM |
Dash swap | Jon11561 | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 03-11-2013 09:53 PM |
BRZ /FRS Dash Swap? | Skippman | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 02-03-2013 04:18 PM |
