12-05-2022, 12:58 PM | #239 |
Drives: GR86
In that case it would be pretty simple to reconstruct. I don't have a Gen1 to test on so I don't have that part, but if I did I could probably build the 3D model.
What someone needs is to be able to take fairly accurate (within 0.1mm) measurements of the parts including the switches (both OEM and intended additional button/switch). For FDM printing I imagine you'd want to go with a 2-part design - face for one and the "structure" on the back as a second part. That way you could take advantage of a textured build plate to get a nice finish on the face and still print the structure with the layer lines oriented for best strength. SLA would naturally side-step that, but fewer people run that type of printer. I've done similar stuff myself, it takes a bit of experience but not years and years. Fun fact: there are lots of instances where it's better to design something differently than the original piece because of the inherent differences between injection molding (which is how most OEM parts are made) and 3D printing. The key difference being that an injection molded part can't have geometry that would prevent it being removed from the mold, and 3D printing has to account for supporting overhangs and weakness in Z-axis stress points (if FDM). |
The Following User Says Thank You to Spektyr For This Useful Post: | Takumi788 (12-05-2022) |
12-05-2022, 05:16 PM | #240 | |
S🅱️inalla
Drives: 2013 Subaru BRZ [WRB]
Link to the pedal kit seems to be dead. Any chance you still have the STL for the pedal stopper? I've got a spacer made of aluminum but I'd love to print an extended stopper and get rid of the deadzone. |
12-05-2022, 09:07 PM | #241 | |
ProCrastinationConsultant
https://mesocustoms.com/ he's got some of the switch templates pre-made, he would just need to update the overall size to one that fits in the 86. otherwise, i just bought a 2-position switch panel from air on board for the tacoma for some other switches i'll be mounting you'd need the SPT9_ series. i've got the spt92 on my workbench now. switches fit nicely in it, however the texture/color is off from the switches, but any 3d printed version will have similar issues. https://www.aironboard.com/online/pr...ch-panels.html
12-09-2022, 01:48 AM | #242 |
Drives: BRZ, Canyon
For anyone that has the tool for replacing the direct injector seals, i designed a case for it. The tool costs enough, i didn't want it rolling around free in my toolbox.
https://www.thingiverse.com/thing:5694942 |
The Following 5 Users Say Thank You to Sevs753 For This Useful Post: | bcj (12-09-2022), RedReplicant (02-03-2023), soundman98 (12-09-2022), Spektyr (12-11-2022), Takumi788 (12-09-2022) |
12-11-2022, 05:04 PM | #243 |
Drives: GR86
02-03-2023, 10:35 AM | #244 |
Way back I looked into the "JDM" 51R battery tray and as usual things escalated. A 51R AGM battery gets expensive and ends up around 27 lbs which isn't that great, so I started looking into other options.
Settled on the Deka ETX30L, which is (probably) the same as a Braille battery and seems to be a solid and inexpensive AGM battery. About 20 lbs. Needed to add some posts, which I got from Voltphreaks. Plenty of other options. Then the OEM Subaru 51R rod and tie down work well. These are available from US Subaru dealers. battery rod - 82161AG001 tie down - 82182AG010 Then the tray, which I made and had 3d printed in ABS so it wouldn't melt. This was about 35-40 bucks (I can't print ABS myself). I added a strip of foam under the tie down. And yeah, works great so far and looks OEM-ish. I work from home sometimes and don't turn the car on for a couple days at a time with no issues in cold weather. Saves 10-20 lbs depending on the battery you're replacing. All in it's less expesnive (probably) then another OEM or Group 35 battery. We'll see how long it lasts, but initial signs are good. I'll post the files if anyone is interested. Briefly thought about having these produced but I don't think we're going to do that. To be clear, don't print these in regular ol' PETG or whatever because it will melt. - Andrew |
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post: | bcj (02-03-2023), cmiovino (05-13-2024), Dadhawk (02-03-2023), DocWalt (02-27-2023), dragoontwo (02-03-2023), soundman98 (02-04-2023) |
02-03-2023, 01:00 PM | #245 | |
Drives: GR86
PETG is better, getting pliable at 85C / 185F. That makes it good for interior parts where PLA would fail, but still not enough for engine bay temps. ABS is good to 105C / 220F. I wouldn't bolt it to the engine block, but otherwise it's not going to melt under the hood. |
The Following 2 Users Say Thank You to Spektyr For This Useful Post: | Racecomp Engineering (02-03-2023), soundman98 (02-04-2023) |
02-03-2023, 01:41 PM | #246 | |
- Andrew |
02-03-2023, 03:13 PM | #247 |
Drives: Crapcan
Just don't get any brake fluid on it.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (02-04-2023) |
02-03-2023, 03:25 PM | #248 |
Drives: GR86
Good point.
PC (Polycarbonate) is probably the best way to go for under-hood parts. Even higher heat tolerance. I'm not sure how it'd handle brake fluid, but iirc it's less reactive than ABS in general. Then again, there isn't a whole lot of materials that tolerate brake fluid. That stuff is nasty. |
The Following User Says Thank You to Spektyr For This Useful Post: | NoHaveMSG (02-03-2023) |
02-03-2023, 03:39 PM | #249 | |
Drives: Crapcan
03-03-2023, 06:04 AM | #250 |
Drives: Toyota 86
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
The Following 3 Users Say Thank You to makinen For This Useful Post: |
03-07-2023, 07:10 PM | #251 |
Drives: Toyota 86
1st gen. door mirror wing
Hi,
This is a kind of anti-buffeting device, so to speak, concentrated on the aesthetic side more.
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ Last edited by makinen; 03-07-2023 at 07:46 PM. |
The Following 6 Users Say Thank You to makinen For This Useful Post: | DocWalt (03-08-2023), Jdmjunkie (03-08-2023), NoHaveMSG (03-08-2023), RedReplicant (03-08-2023), soundman98 (03-08-2023), yberther (03-09-2023) |
03-22-2023, 01:12 PM | #252 |
Drives: '22 BRZ
Working on a copy of the GR86 Cup car hood vent... an expensive print to reproduce at a print shop, not too bad at home but a bit annoying. I'll print it in ASA on my Ender, it's too big for my Method even split into three pieces. Annoying because the Method has way better surface finish but oh well.
The Following 4 Users Say Thank You to DocWalt For This Useful Post: |
Similar Threads | ||||
Official DTM Autobody Services Thread for FT86Club! | DTMAUTOBODY | Southern California | 9 | 12-31-2013 02:09 PM |
Official FT86Club Chatroom? | wrxgoose | Site Announcements / Questions / Issues | 13 | 09-15-2012 05:26 PM |
Official FT86Club decal idea? | Hanzo | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-21-2012 08:09 PM |
