Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
03-04-2023, 04:10 PM | #15 | |
WRBLUE BRZ
Drives: 2016 Subaru BRZ
03-04-2023, 04:15 PM | #16 | |
chicken tonight
JB weld is only good for wide surface area. It's still just glue.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (03-05-2023) |
03-04-2023, 04:29 PM | #17 |
WRBLUE BRZ
I just tried to put my pinky finger under the pedal bracket there. It elevated from the firewall and I can feel like there is a flat head stud and the gap between firewall and the bracket is about 5mm. So drill is possible but it can't be tap
03-04-2023, 04:55 PM | #18 |
TRACKBREAD
You can use a bottoming tap to thread it.
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Ultramaroon (03-04-2023) |
03-04-2023, 06:12 PM | #19 |
chicken tonight
I was such a dufus coming in here, glossing over the posts.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
03-04-2023, 06:29 PM | #20 |
Drives: Crapcan
I was looking at it wrong too
Need to cut that flush, center punch it with an auto punch, and drill it out. Then try to nutsert it.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (03-05-2023), Ultramaroon (03-04-2023) |
03-04-2023, 06:42 PM | #21 | |
chicken tonight
03-04-2023, 06:47 PM | #22 |
Drives: Crapcan
That is a good idea.
03-04-2023, 06:47 PM | #23 |
chicken tonight
I am lethal with a dremel and a short stack of cutoff wheels.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (03-04-2023), soundman98 (03-05-2023) |
03-05-2023, 07:21 AM | #24 |
WRBLUE BRZ
I will ask a cnc shop for making a pedal spacer. Instead of drilling and cutting.
Verus spacer as a reference but use the lower hole of pedal bracket as mounting point of a spacer and flatten of the broke one. Honestly, I don't feel comfortable for cut or drill anything if I have another choice. Last edited by pym19109; 03-05-2023 at 07:56 AM. |
The Following 2 Users Say Thank You to pym19109 For This Useful Post: | NoHaveMSG (03-05-2023), Ultramaroon (03-05-2023) |
03-05-2023, 08:27 AM | #25 | |
TRACKBREAD
If you need a CAD file feel free to PM me a sketch with dimensions of what you need. I don't have a spacer for reference but i can whip up a 3d file and a basic drawing they can use to make a toolpath. |
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
03-05-2023, 10:02 AM | #26 | |
WRBLUE BRZ
I will maeaure the clearance again and try to write it on paper first. Thank you for your help. if I need a CAD file I will PM you |
The Following 2 Users Say Thank You to pym19109 For This Useful Post: | Ultramaroon (03-05-2023), Yoshoobaroo (03-05-2023) |
03-05-2023, 10:09 AM | #27 | |
Drives: Crapcan
That’s a good idea. If you can get a CAD file sites like sendcutsend.com is a cheap place to have parts made. Just FYI you can run about 10mm thick and still use the factory bottom stud to hold the pedal. I am running 10mm spacer and using the factory studs. If you go with a thicker spacer you may need to space out the pedal stop too or you risk damaging the pedal.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | pym19109 (03-05-2023), Ultramaroon (03-05-2023) |
03-05-2023, 10:47 AM | #28 | |
WRBLUE BRZ
Similar Threads | ||||
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) | BOND007_LTK | DIY (Do-It-Yourself) Guides | 5 | 05-20-2022 04:12 PM |
Beastronix pedal box, Nardi Gara Sport 350mm, Velox and Cusco pedal brackets etc. | captain awesome | Interior Parts (Incl. Lighting) | 2 | 04-21-2021 10:56 AM |
FS: OEM Pedal Box | MicheleAbbate | Interior Parts (Incl. Lighting) | 14 | 02-26-2020 02:02 PM |
Painting pedal covers + dead pedal | iconic | DIY (Do-It-Yourself) Guides | 4 | 12-22-2019 12:39 AM |
Gas pedal | tintumz22 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-22-2012 09:42 AM |
