Forced Induction Turbo, Supercharger, Methanol, Nitrous |
03-26-2023, 08:14 PM | #1 |
Drives: low black brz
Boxer engines share same header setup for turbo GT86
Hello I was wondering if there were any Subaru engines that have a similar exhaust setup that I can install a turbo from a used manifold. Will all I need for a entry setup is a turbo, (“idk”WHAT connects directly to it?) BOV filter, the part for intake! Then a down pipe that goes to over pipe. Planning to keep intercooler oem. Does that seem like a “complete” setup that’ll stay running as I add to? I’ll need a tune I assume I have open flash maybe suggest??
03-26-2023, 08:27 PM | #2 |
Rust bucket enthusiast
Yeah I mean all you really need is all the parts you need and bam it's done. Ez
03-26-2023, 09:22 PM | #3 |
chicken tonight
I don't understand why everyone doesn't do it.
03-26-2023, 11:18 PM | #4 |
ProCrastinationConsultant
yep, just need to widen the front frame rails, tweak the hood height and the entire fa20t from the new wrx drops right in.
03-27-2023, 05:18 AM | #5 |
The exhaust manifold and J-Pipe on turbo FA engines goes the opposite direction. On an engine stand, easy. In the car, not so much.
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | CSG Mike (03-27-2023), soundman98 (03-27-2023) |
03-27-2023, 09:33 PM | #6 |
no problem, just remove the radiator. that's only there for the EPA anyways.
Tags |
manifold, oft, reliable, setup, turbo |
Similar Threads | ||||
3D Printed Subaru WRX Engine - How Boxer Engines Work | phm14 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 0 | 05-16-2020 10:43 PM |
Boxer Engines Poll | JD001 | Other Vehicles & General Automotive Discussions | 43 | 06-03-2016 03:29 PM |
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
Torque dip common to NA boxer engines? | zdr93523 | Engine, Exhaust, Transmission | 45 | 04-18-2014 08:35 PM |
Boxer Engines and Superchargers | brillo | Engine, Exhaust, Transmission | 2 | 01-06-2012 05:49 AM |
