Software Tuning Discuss all software tuning topics. |
04-15-2023, 02:48 PM | #1 |
Drives: 2013 FRS GTX3076R
Turbo knock during spool up
Wondering if anyone can help me with this please,
My car is a 2013MY BO1C ROM, turbocharged (GTX3076R), DW700 injectors, GM 3 bar map, self tuned (Ecutek), 3port MAC, 93 octane shell (Canada), stock catback, stock front pipe. I'm noticing that I have been getting knock in the 0.8-1.3 load range right when the turbo is spooling up. I've never noticed this before as I had a 3psi wg spring previously and I recently just installed a 5psi spring causing the turbo to spool up much earlier. I figured the knock was just from the earlier spool so I pull some timing from the effected knock areas, however despite the timing reduction in the ignition base map I am still getting knock, it seems to be slightly better after the timing reduction, but I am at the point where I have so little timing in this area and it still knocks. Tried adding some fuel and increasing the DI, still knocks, blended some ethanol into the gas to make an E30 blend, still knocks, knocks even when I am free revving it with the clutch in. I am at a complete loss on what to do next. Car runs great at full throttle no knock whatsoever. Attached is a copy of the datalogs with the car on 93 octane, I don't have logs of the car with e30. Could this be low speed preignition? The current oil I have in the car is just API SN oil which isn't LSPI rated, and the oil has 5000kms on it. I am hoping that the knock is due to the oil I am using as the car didn't really knock before, perhaps the oil degraded a bit? When the car had no knock the ambient temps were also much colder, 0-5c, now spring is here the ambient temps 8-12c. Can anyone provide insight please and thanks. Last edited by yzf219; 04-15-2023 at 02:59 PM. Reason: More info |
04-18-2023, 03:35 PM | #2 | |
Sent from my SM-G991W using Tapatalk |
The Following 2 Users Say Thank You to yzf219 For This Useful Post: | DarkPira7e (04-18-2023), tomm.brz (04-19-2023) |
04-18-2023, 04:05 PM | #3 | |
Rust bucket enthusiast
04-18-2023, 06:13 PM | #4 | |
Intake/exhaust cam advance angle high/low det was the name. Intake has 2 tables high det and low det. Same goes for the exhaust. Sent from my SM-G991W using Tapatalk |
The Following User Says Thank You to yzf219 For This Useful Post: | DarkPira7e (04-18-2023) |
04-25-2023, 02:09 AM | #5 |
Just another update, the knock corrections are back, changing the vvt tables didn't help, changing to an lspi approved oil also didn't help.
04-25-2023, 02:18 AM | #6 |
Drives: brz 2017 hksv2
try advance DI injection angle at low rpm high load
i put 320 instead of 300 try also advancing the PI angle under 3200-3400rpm with a custom map, PI timing is fixed at 360 but you can advance to say 380 or 390 or 400 with a custom map Do not make it too rich at low rpm high load and when it is in spooling zone, it doesnt like when it s too rich So if you lower ignition timings knock don t go away? Sorry still haven t seen the log as it is too big to look at that with my phone at the mom |
The Following User Says Thank You to tomm.brz For This Useful Post: | yzf219 (04-25-2023) |
04-25-2023, 02:46 AM | #7 | |
I was actually just reading your post on you solving a similar issue. I appreciate your suggestions, I'll try the pi and di angle changes. I actually just got done updating the tune and leaned the areas around 0.8-1.2load 2600-3200rpm to around 12.7 Afr, haven't test driven yet though. And that is correct, altering ignition timings doesn't make any difference to the knock correction. Thanks again for your help! Sent from my SM-G991W using Tapatalk |
04-25-2023, 02:59 AM | #8 |
yeah this car doesn t have the ability to split DI into multiple injections which would help so theoretic goal is to advance PI angle so that it can sit more on closed valves and also more chances to vaporize better
Also the retarded DI angle that even oem tune has at low rpm high load causes more piston impingement and wall wetting and that s worse for lspi interesting is subaru on late gen1 Euro advanced the DI a lot everywhere Anyway also the opposite could actually work somehow, see Cosworth that for his auoercharger retards a lot DI angle ( like around 260-280 instead of 300) and also uses very low cam timing values and little overlap.... i guess what works, works. How much PI have you setup? you can PM your tune if you want i ll take a look together with the log |
04-25-2023, 12:05 PM | #9 | |
Similar Threads | ||||
Full Spool 8" Differential | DiscoQuinn | Engine, Exhaust, Transmission | 15 | 01-13-2022 10:41 PM |
Over boosted - Jdl Turbo Kit. Engine Knock. R | Donovan34 | Forced Induction | 9 | 10-28-2020 12:57 PM |
Knock Knock? Expired Warranty | Frivo | Issues | Warranty | Recalls / TSB | 20 | 08-17-2020 09:04 PM |
Gt 4202 spool info | solidsnake11 | Forced Induction | 3 | 12-01-2019 06:43 AM |
tip in knock with turbo | jamesm | Software Tuning | 75 | 03-12-2014 12:29 AM |
