Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
05-24-2023, 11:38 PM | #15 |
For those who may still be curious what the issue was. I ended up taking it to a super reputable shop and had them drop the trans. The issue ended up being the clutch. It was installed improperly when it was replaced 15k miles ago and the clutch plates were bent and not making proper contact with the flywheel. I’ll leave some pictures, you can clearly see the inside of the clutch plate looks new and the outside is worn. If you live in the Bay Area I couldn’t recommend CM Autohaus more!
The Following 3 Users Say Thank You to Dububster For This Useful Post: |
05-25-2023, 08:14 AM | #16 |
Anti stance.
Can you expand on, "installed incorrectly..."?
05-25-2023, 01:54 PM | #17 |
05-25-2023, 03:45 PM | #18 |
Wheels for Brains
05-26-2023, 05:55 AM | #19 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
But facts remain facts, that clutch disc was obviously not rubbing right. |
05-26-2023, 09:36 AM | #20 |
Drives: 2013 frs base
When the previous clutch work was done, was the flywheel replaced or was the old one resurfaced?
05-26-2023, 02:45 PM | #21 |
Similar Threads | ||||
Engine sound generator replacment..... plug and play | Master Jedi | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 11 | 04-02-2022 01:04 PM |
Vibration after Clutch Replacment | AT-JeffT | Engine, Exhaust, Transmission | 12 | 03-10-2020 08:09 PM |
Windshield replacment vendor referrals | jeepmor | Northwest | 2 | 07-09-2014 07:03 AM |
BRZ Premium Reflector Replacment | Jimmylightning | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-20-2013 11:35 PM |
6x9's Stealth install - rear speaker replacment | GTS86 | Electronics | Audio | NAV | Infotainment | 7 | 10-16-2013 09:55 AM |
