06-26-2023, 06:56 PM | #29 | |
Drives: 2023 brz limited 6mt red
I’m hoping someone finds a solution soon! I think “non-track” people would love to see this same test done in a canyon or mountain road… or a comparable ratio of right hand turn g measure to equal net of pressure loss which is no real constant. I think If the street only people know they are carrying atleast 40+ psi of oil pressure this may calm some people down. Or you will see people selling brz’s based off how many total right turns they made at what g… ha ha
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
The Following User Says Thank You to vindiesel For This Useful Post: | brianbot5000 (06-27-2023) |
06-26-2023, 08:10 PM | #30 |
Drives: 2023 Gray BRZ
The idea of cavitation in the pickup appeals to me... especially since it appears they have expanded the mid-section (screen at the top of the tube) to provide MORE screen area because of the RTV problems. If that is the case, it would take more than oil pan baffles to fix it... and would explain why the older engines seem to do better in this regard. Either way, a scary problem as even relatively low-g right handers seem to cause pressure drops. Kudos to 900BRZ for the great work.
06-27-2023, 08:08 AM | #31 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
EDIT: Please note, I am writing this to add constructive feedback to the the diagnosis, I LOVE your critical breakdown and data. I mean no disrespect. You have provided by FAR the most data driven analysis of this problem. Many thanks. From having seen internal documents within Subaru, they said they adjusted the shape of the pan to reduce frothing at the pickup. I assume this is more to ensure that consistent oil flow can be had at the pickup. This leads me to my point: I think the issue is that the pickup is not reliably being presented with oil to suck up. The pump will cavitate as a result but the cause isn't the cavitation but a byproduct. If frothing was an issue, the easiest way to have fixed that was either to make the pickup go deeper into the pan where the highest amount of G doesn't affect it BUT you also have to consider the oil return coming back is actually hitting the spot where the pickup is intaking oil. If the G is high enough, maybe oil isn't flowing back to that spot. Short of seeing the oil paths, I am baffled (pun intended) as to why right turns don't allow for oil to return in enough volume back to the intake.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK Last edited by Frost; 06-27-2023 at 08:20 AM. |
The Following User Says Thank You to Frost For This Useful Post: | vindiesel (06-27-2023) |
06-27-2023, 12:22 PM | #32 |
Also, I'd like to add, the video does make mention of first gens not getting as severe and as long pressure drops on the same turns. Any chance we can get full lap of the first gen followed by a full lap of the second on the same track?
Thanks!
OTA LIVE TIMING LINK |
06-27-2023, 12:39 PM | #33 |
Drives: frs
Hope Toyota's dealerships doesn't see this video...otherwise they could start decline warranties
06-27-2023, 01:33 PM | #34 |
A little explainer on cavitation:
https://dienerprecisionpumps.com/pum...w-to-avoid-it/ I believe our oil pumps are rotary positive displacement pumps. Again, it will crop up IF you don't have adequate oil supply and thus make the pump have to suck harder to draw up oil. Remember that in order for cavitation to occur, the fluid in question has to flash vaporize due to the pressure it is being exposed to in effect lowers its boiling point. Thus it flashes into vapor creating a pocket of gas. Then you expose it back to high pressure and your force the bubble to collapse thus creating a shock wave. If we were having cavitation, you'd be wrecking the oil pump pretty damn quick. I'm not saying cavitation isn't happening, I am saying we're looking at a symptom and not the cause. The answer is lack of oil accessible to the pickup based on the data we've been shown so far.
06-27-2023, 03:45 PM | #35 |
There might be some cavitation at the impeller, but I doubt it. The cavitation we are talking about (imprecise choice of words) is happening in the pickup tube. The theory being it sucks some air/froth as a result of braking/turning in. But the shape (and according to me the bulbous mid-section) prevents it from quickly re-establishing good flow to the pump.
Imagine sucking fluid through a straight straw... if the straw loses contact with the fluid, you will suck air, but flow will resume immediately as the straw is immersed again. But consider a straw with a big bulb in the middle... it takes longer to re-establish flow because the bulb is full of air now and has to be drained--its pressure must fall sufficiently below ambient to suck up the oil... and a larger volume of gas takes longer... especially since the pump impeller is designed for low-volume hi-pressure operation in fluid, not sucking on air. Just a theory... |
06-27-2023, 03:48 PM | #36 | |
Drives: 2017 BRZ PP, 2004 WRX
Track driving in 3rd or 4th gear around some corners... totally different realm than even 50mph in a wide autocross sweeper. IMO, it's really track driving these oiling issues crop up at. Also factor in track driving has repeated high RPM use, braking, rinse and repeat. It's a lot on a car.
The Following User Says Thank You to cmiovino For This Useful Post: | vindiesel (06-27-2023) |
06-27-2023, 04:20 PM | #37 | |
What pushes the fluid up the intake is the atmospheric pressure within the system. Liquid doesn't move to a void, it gets pushed from an area of high pressure towards the void. The issue here is that you don't want to lose suction flow mid corner at high load.
06-27-2023, 04:54 PM | #38 |
They self prime, but it takes a few seconds... I think that is the problem. I suspect, without proof, that the priming function is slowed down because of the now bulbous shape of the tube... forcing it to suck more air. There is probably the same momentary loss of suction as the older engines, but it now takes longer to re-establish prime and flow.
Actually it is the difference between atmospheric pressure and the pressure at the top of the inlet tube that pushes up the fluid... the rotating impeller simply reduces the pressure a little and up comes the fluid. But all of this takes time. |
06-27-2023, 09:08 PM | #39 | |
Drives: '23 GR86, '17 BRZ
Driving even super hard on the street doesn't put anywhere CLOSE to the stress on a car that track driving does. Even in the case where someone has a fast curvy road, that they know extremely well, that is 100% clear of any traffic, on 200tw tires, where they are willing to push every corner up to the point of potentially going off the road... there's still the fact that you probably can't do lap after lap after lap of that section for 20 minutes straight without interruption. |
06-27-2023, 09:49 PM | #40 |
Drives: 17 BRZ
Youtube recommended me the video last night THEN I came here as I just knew this thread would exist! LOL
Anyways, good luck everyone and hope a solution is found. |
06-28-2023, 05:22 AM | #41 |
Drives: GT86, 22 BRZ
Thanks for making this video @900BRZ, love your work!
I'll like to see the Greddy baffle tested. It has a plate that sticks up that is designed to prevent oil from going into the front chain cover. The FA20/FA24 engine has a structure in which a large amount of engine oil accumulated in the oil pan flows into the front chain cover due to intense braking G when driving on a circuit. The oil pressure will drop, and in the worst case, the engine may blow. |
The Following User Says Thank You to drift86 For This Useful Post: | mike2100 (06-28-2023) |
06-28-2023, 08:02 AM | #42 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
Very strange - wondering what's going on here. |
Similar Threads | ||||
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 05:15 PM |
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) -- General Topics | 50 | 10-29-2022 07:36 AM |
High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 09:51 AM |
FS: NEW Bluemoon Oil Baffle & Killer-B pick up tube. | FRSH86 | Engine, Exhaust, Bolt-Ons | 2 | 04-20-2020 10:49 AM |
Compatibility: Moroso Baffle and Killer Bee Oil sump | Nightflo | Engine, Exhaust, Transmission | 3 | 04-27-2019 09:40 PM |
