Tracking / Autocross / HPDE / Drifting What these cars were built for! |
09-08-2023, 12:20 AM | #15 | |
Custom User Title
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
09-08-2023, 12:59 AM | #16 | ||
Custom User Title
09-11-2023, 01:57 PM | #17 | |
Drives: 2015 FR-S
Realistically I just keep it at the lowest level that barely registers on the bottom of the dipstick. That allows me to not mess with it and it's likely negligible weight, but if I need a quick spray there's some in there. |
09-11-2023, 02:52 PM | #18 |
Pawn in game of life
Drives: 19 STX BRZzz
I started the super challenge on the low fuel light and ran the 3rd place runoff with the needle even with the red line. Zero issues. Even had enough gas to go and get more gas.
Autocross nut
09-11-2023, 03:19 PM | #19 | |
Drives: 2015 FR-S
Now I'm wondering if my fuel gauge is wireless and it was reading your fuel level the whole time |
09-11-2023, 04:05 PM | #20 | |
Drives: '13 FRS - STX
We panicked and did the same with an overfill halfway through the pro I think last year. |
09-11-2023, 04:09 PM | #21 |
Drives: 2016 Scion FRS
My gauge seems to pick up any addition of fuel. I've added half a gallon during challenges with the fuel light on and it turns off the light and moves the needle.
But I've talked to several others that will add 2 gallons, not move the needle off E, then add another 2 gallons, and find themselves at like 5/8th's of a tank. |
09-11-2023, 05:03 PM | #22 |
Drives: 2022 BRZ; 2014 BRZ
The second gen has a similar response, you need 2-3 gallons for it to register anything. Haven't tried it yet in the first gen, but sounds like they probably use the same programing.
09-11-2023, 08:52 PM | #23 | |
Custom User Title
The Following User Says Thank You to Locust For This Useful Post: | jcaserta (09-12-2023) |
09-11-2023, 08:59 PM | #24 | ||
Custom User Title
And to clarify - It's not an "at once" thing. You can add a gallon, take a run, add a gallon, take a run, and then add another gallon and it'll update. It has to come up a certain amount below the level it thinks its reading at before it'll believe itself. I haven't figured out what the trigger point for when this behavior kicks in is yet but it's at least below 3/4 and above 1/8 because you can throw in gas at near full and it'll update immediately.
09-12-2023, 08:20 AM | #25 |
Wonder if these cars are like the ND Miata where you can plug in an OBD dongle and get to the exact percentage the ECU reads. They otherwise act the same with 2 gallons left when the gas light comes on and don't register a fill up if it's less than a couple of gallons.
09-12-2023, 09:02 AM | #26 | |
Drives: 2015 FR-S
I'll set up the fuel level PID in racecapture and at the next event try to determine if it's like the ND or not (where the dash is inaccurate but the obd signal is correct) |
09-12-2023, 10:10 AM | #27 | |
Drives: '22 BRZ
Yes, you can check live fuel level with an OBD2 reader.
The Following 2 Users Say Thank You to DocWalt For This Useful Post: | jcaserta (09-13-2023), strat61caster (09-12-2023) |
09-12-2023, 12:04 PM | #28 | |
Drives: Toyota GT86
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
Similar Threads | ||||
P0462 - Fuel Level Sensor | TurboBRZ | Issues | Warranty | Recalls / TSB | 20 | 05-13-2019 08:04 PM |
Fuel level Gauge swap. | knopper91 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-13-2016 11:58 AM |
Remote Fuel Level Gauge | pleong | Electronics | Audio | NAV | Infotainment | 5 | 08-21-2015 09:50 AM |
Low fuel level and engine performance | whatsinaname | BRZ First-Gen (2012+) -- General Topics | 20 | 12-03-2013 12:55 PM |
Fuel level | GeeTee86 | Issues | Warranty | Recalls / TSB | 6 | 05-21-2013 05:57 AM |
