09-27-2023, 11:20 AM | #5993 | |
Drives: 2017 BRZ w/PP
Skill issue, I thought I had the rpm and I didn't |
12-02-2023, 06:01 AM | #5994 | |
Did you get another unit? was is silent? I have two friends with the JRSC. One owned it for 1-2 years and is pretty silent. The other one installed it recently and has the "crickets" sound. I have just installed mine and yeap, very loud crickets sound. like this. is it possible that the belt pushes the pulley a little bit too hard to the point it moves the internal shaft enough to make the blades contact the housing? how harmful is it? will it just wear out? if so, would it affect performance? |
12-02-2023, 03:31 PM | #5995 | |
Drives: JRSC BRZ SOLD
12-04-2023, 02:22 PM | #5996 | |
With the hood open I can hear the crickets, but it's waaaaay quieter. You'd have to really listen for it while driving to hear it over all the vroom vroom noises. |
The Following User Says Thank You to johnnyeisu For This Useful Post: | CSG Mike (12-04-2023) |
12-08-2023, 12:39 PM | #5997 | ||
Wow! what a difference, yours is basically silent. The crickets noise from my unit is much lower now. Mic didn't pick up the sound 100%, but you can tell its still there. Here is a video of my setup: |
12-08-2023, 02:19 PM | #5998 |
Drives: 2013 Satin White Pearl BRZ
I need to replace one of the idlers that came with the kit. What are y'all doing for those. I'm not seeing anything on the jrsc website.
Sent from my SM-S908U using Tapatalk |
12-11-2023, 10:10 AM | #5999 |
01-30-2024, 02:23 AM | #6000 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
Does anyone have an ACE Radiator and Intake Scoop installed with your JRSC?
If so, how did it turn out? How was the installation around all the JRSC piping? Was it helpful, specifically at the track? Thanks! Last edited by BatStig; 01-30-2024 at 04:27 AM. |
01-30-2024, 03:55 PM | #6001 | |
Make sure all the foam around the top of your radiator is intact. Venting your hood will have a much larger effect. Also, make sure your fender liners are fully intact. If you are not running liners, the Ace shroud will help more by band-aiding the lack of liners. |
The Following User Says Thank You to CSG Mike For This Useful Post: | BatStig (01-30-2024) |
01-31-2024, 11:49 PM | #6002 | |
Some say.....
I already have the Trackspec vents. Fender liners will be fully intact once I remove the brake ducts I no longer need thanks to my lovey CSG pads. I am upgrading my radiator and I will make sure that all stock foam and air guides are in place. I am just trying to get as much air to get through the stack as possible.
While searching for anyone who had used the Ace Scoop, I found a post from you from 2021: Quote:
Thank you @CSG Mike! |
02-01-2024, 12:12 AM | #6003 | |
The JDL bash bar will make mounting the intercooler more challenging, but can be done. |
The Following User Says Thank You to CSG Mike For This Useful Post: | BatStig (02-01-2024) |
03-19-2024, 02:42 AM | #6004 |
Drives: 2017 BRZ PP
This is the first time I've heard of this. Logically makes sense though. Is this a problem with stock pulley cars?
03-19-2024, 02:16 PM | #6005 | |
FWIW I have an ACE Shroud Installed. Shows pretty easily what you need to do for install and drilling for IC Piping, this is Harrop Install. The hoses are now wrapped with 1" Heater Hose so they don't chafe
Kyle H. - #89 STX
05-18-2024, 08:55 AM | #6006 |
pessimistic skeptic
I just replaced the traction fluid second time in seven years with JRSC. Everything is still running fine.
I use the following straight through exhaust system to reduce the stress on the engine with JR stock tune.Works great. 2019 86 header HKS Hi Performance SpecL exhaust HKS dual resonator front pipe I also have the JR dual radiator installed to help with heat. The only big problem I had was because of the failed valve springs that is a known problem but I had to pay out of pocket to replace them since installing JRSC voided the warranty. While doing the replacement, the service left two of the ignition coils loose and I had to figure out the problem myself after that. With those done, car is back to normal. No regrets, and still very much satisfied. |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
