Old 02-24-2023, 04:48 AM   #351
PikachuBRZ
waiting on yellow gas
PikachuBRZ's Avatar
Drives: 2017 BRZ Series.Yellow #247
FWIW I just got confirmation from Enkei that the TS-10 uses the same spoke profile for the 17x8 +45 and 17x9 +45 so it looks like the 17x9 should fit. Unfortunately I was asking about the TS-5.
Update: Enkei finally confirmed that the spoke profile for the TS-5 17x9 +45 is the same as the 17x8 +45 so they should clear the brembos as well
"Straight roads are for fast cars, turns are for fast drivers" - Colin McRae
PikachuBRZ is offline   Reply With Quote
Old 04-02-2023, 11:28 PM   #352
Drafter
Drives: 2017 Brz
Thank you for this thread. Gave me confidence in my purchase. Installed my new Konig Ampliform 17x9’s today. Fit with lots of space.
Drafter is offline   Reply With Quote
The Following 2 Users Say Thank You to Drafter For This Useful Post:
Busybee (04-26-2024), Tatsu333 (04-03-2023)
Old 04-03-2023, 10:44 AM   #353
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Looks good! What size tire are you running on your new wheels?
Tatsu333 is offline   Reply With Quote
Old 04-04-2023, 10:43 PM   #354
Drafter
Drives: 2017 Brz
Pilot sport 4s in 245/45zr17.
I hadn’t had anything other than the stock primacy’s so this is a world of difference.
The Following User Says Thank You to Drafter For This Useful Post:
Tatsu333 (04-05-2023)
Old 05-21-2023, 08:08 PM   #355
FerdFiesturd
FerdFiesturd's Avatar
Drives: 2019 BRZ Series.Gray
I just wanted to add some more info for 17x8.0 +45 Enkei RPF1s. I recently upgraded from a 2013 FR-S to a 2019 Performance Pack BRZ. I tried fitting my RPF1's to the BRZ and wheel weight clearance is an issue. The caliper to spokes clearance is fine and the tire to strut clearance is fine, but the wheel weights contact the caliper. I've included some pictures for reference.
P.S. Sorry the pictures aren't oriented correctly, I'm not sure why they are getting rotated.
FerdFiesturd is offline   Reply With Quote
Old 06-17-2023, 07:37 PM   #356
FerdFiesturd
OZ Racing Hyper GT HLT 17x7.5 +35 in Star Graphite. The wheels fit with plenty of clearance, more than the stock wheels. Probably around 10mm of clearance from the caliper to the spokes. Honestly the wheel weights look like the closest point.
No spacers
Suspension is 100% stock.
225/45R17 Michelin PS4S
PS Please ignore the very poorly bedded rotors haha
The Following 2 Users Say Thank You to FerdFiesturd For This Useful Post:
Busybee (04-26-2024), Tatsu333 (06-19-2023)
Old 07-06-2023, 11:31 PM   #357
SlwFRZ86
SlwFRZ86's Avatar
Drives: 17 brz limited
can anyone confirm Cr Kiwami clears brembos ? 18x9.5+38 are the specs
SlwFRZ86 is offline   Reply With Quote
Old 07-18-2023, 02:51 PM   #358
RedReplicant
Drives: None
3mm clearance for stock Gen 2 BRZ 18" wheel
RedReplicant is offline   Reply With Quote
Old 08-26-2023, 04:30 PM   #359
N_Raged
Drives: 2019 BRZ Sport-Tech RS
2008 Forester XT STi Enkei 17x7 +48 DO NOT FIT. Need 10mm spacer.
N_Raged is offline   Reply With Quote
Old 09-21-2023, 11:02 PM   #360
N_Raged
RTX Frost 17x7.0 ET40 fits but requires a 3mm spacer, resulting in 4mm of brake clearance.
Old 11-25-2023, 06:03 PM   #361
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by APEX Race Parts View Post
The 17x9.5" ET40 is really engineered for more hardcore track enthusiasts that want to maximize tire sidewall support for wider compounds. The fitment requires more attention to detail, but yields fantastic results with the proper supporting mods. More aggressive camber specifications are going to be required to prevent rubbing the fenders under suspension compression, but with track oriented wide wheel & tire fitments like this it is always still possible to scrub the inner plastic fender liners. This wider fitment will sit ~11mm closer to the suspension in comparison to the 17x9" ET35, so aftermarket coilovers with a slim silhouette are a requirement. Furthermore, the wheel can make contact with your front tie rods at full lock.
- Ryan
What to do to avoid any contact with the front tie rods with this 17x9.5+40 set up? Thanks!
botbs is offline   Reply With Quote
Old 11-25-2023, 07:55 PM   #362
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Don't go full lock, or install tie rack stops/limiters
EndlessAzure is offline   Reply With Quote
Old 11-26-2023, 07:20 AM   #363
tobin
tobin's Avatar
Drives: '13 BRZ
Originally Posted by N_Raged View Post
Does anyone know if the base 17x7.0 ET48 factory wheels clear the Brembos if we use a spacer?
Bump, same question.
tobin is online now   Reply With Quote
Old 11-26-2023, 11:00 PM   #364
N_Raged
I was able to test the base 17x7 wheel from the 2017-2020 facelift models and no amount of spacer will make it work.
I haven't been able to get my hands on 2013-2016 base wheels but I'm going to assume it's the same issue.
I settled on 17x7 ET40 RTX Frost wheels with a 3mm spacer and it's perfect.
The Following User Says Thank You to N_Raged For This Useful Post:
tobin (11-27-2023)
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
