Engine Swaps Discussion of engine swaps. |
12-16-2023, 09:56 PM | #57 | |
Drives: Crapcan
Swapping the short block with FA20 heads just seems like the wrong way to go about it to me. Complete FA24’s with transmission(also supposedly improved) are under 7k. Seem’s like it would be easier to go that route and work out what needs changed so the ECU can read the sensors it needs to run. If I had a bigger budget I’d have a complete FA24 in my garage right now. We already know about 99% sure that it is using the same signal type as the 17’+ cars for cam and crank position. Merging the engine harnesses, or building new crank and cam reluctor along with swapping to the FA20 crank sensor(pre 17’ cars) seems like it would be less intrusive.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | new2subaru (12-17-2023), peachch (05-13-2024), Spuds (12-16-2023), Tatsu333 (12-17-2023), Teseo (12-17-2023) |
12-17-2023, 04:36 AM | #58 |
Drives: brz 2017 hksv2
i dont think 7k is with trasmission..link?
usually 7k is tge long block complete but without transmission |
12-17-2023, 11:58 AM | #59 |
Drives: Crapcan
Can’t find one right now. The first one I thought I found didn’t include trans but it was pictured. If I find another I will link it. There were over half a dozen FA24’s engines on eBay a few days ago but now there are not many.
12-17-2023, 01:33 PM | #60 |
ok i thought u were talking about official subaru prices
12-17-2023, 02:32 PM | #61 |
Drives: Crapcan
From what I recall from Opie’s thread, he couldn’t buy an FA24 short block without a VIN. I am sure that will change in the future when availability is a bit better.
Also noticing that FA24DIT(turbo) engines are much cheaper, just the FA20DIT.
12-18-2023, 06:51 PM | #62 | |
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | Dadhawk (12-18-2023) |
12-20-2023, 04:42 PM | #63 |
12-21-2023, 04:21 PM | #64 |
First 86 Driver Baby!
Drives: FR-S, Flex
12-21-2023, 09:36 PM | #65 |
Drives: Crapcan
I measured a set of FA20 heads a while back and at the FA24 bore there didn’t seem to be much gasket space. I’ll have to check again when I pull another engine apart here in another month or so.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | kmbkk (12-21-2023) |
12-21-2023, 10:45 PM | #66 |
Drives: FR-S, Flex
From what I’ve researched the difference between the heads and block is one of the issues needed to resolve for this to work well.
Similar Threads | ||||
First autox in my GR86 | justinco | Tracking / Autocross / HPDE / Drifting | 10 | 05-30-2022 07:52 PM |
Why BRZ Over GR86? | Lelandjt | BRZ Second-Gen (2022+) -- General Topics | 45 | 12-26-2021 08:41 AM |
TOM'S GR86 Catalogue | DeeAich | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 6 | 11-15-2021 12:14 AM |
GR86 PCD | teppey | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 23 | 07-29-2021 11:12 PM |
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 37 | 07-18-2021 03:38 PM |
