Tracking / Autocross / HPDE / Drifting What these cars were built for! |
04-05-2023, 01:58 PM | #43 |
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | kask2_6.0 (04-06-2023) |
04-06-2023, 09:38 AM | #44 |
Track Day Junkie
Drives: 2022 BRZ Limited
Custom made louvers
Just posted this in my Journal. See details there.
I have yet to have a heat issue, but I haven't done a really hot day at the track either. I do have the long tube Nameless headers and want to get some of their added heat out. BTW, that's just my "street splitter" and street gargoyle that's on the car.
Try this Jalapeno son! It ain't hot...
Scargo on IWSTI (Journal of STI track car) Scargod on NASIOC. Track Day Videos |
04-06-2023, 10:26 AM | #45 | |
Drives: Toyota GT86
So I have stuck to just doing a handful of laps then coming in to let things cool down. I am hoping this saves me from the need to update coils and major cooling updates. I will be switching my coils and harness if my method doesn't work lol
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-06-2023, 07:09 PM | #46 |
Drives: 2013 Subaru BRZ
so where can we order em up :P i wanna get in on the first 20. got FB messenger or anything?
The Following User Says Thank You to Goosfraba121 For This Useful Post: | kask2_6.0 (04-06-2023) |
04-06-2023, 09:51 PM | #47 |
Drives: 2018 BRZ tS
In to order
The Following User Says Thank You to SkyeHack For This Useful Post: | kask2_6.0 (04-06-2023) |
04-06-2023, 11:12 PM | #48 | |
Drives: 13 BRZ
@gk.engineering.co |
12-25-2023, 07:02 AM | #49 |
Drives: 2017 Toyota 86
12-25-2023, 07:40 PM | #50 | |
12-26-2023, 12:25 AM | #51 | |
Drives: Crapcan
12-28-2023, 09:00 AM | #52 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
I actually like it a lot. It matches my viper hood vents https://www.viperpartsusa.com/wp-con...451-003-00.jpg
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. |
12-28-2023, 02:40 PM | #53 |
I have good luck with wrapping the coil in gold foil tape. verus hood vents for a street car or track spec Hood vents for a dedicated track car
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
12-28-2023, 02:56 PM | #54 | |
To visualize, compare the surface area of the inlet (front bumper opening), to the outlet. To put this in perspective, the outlet is MUCH larger for the aux radiators, than inlets, on most German cars. By increasing area appropriately, you're reducing pressure differential, because you're simply flowing more. High pressure through a coffee stirer, vs low pressure through a Mcdonalds straw. Which flows more? |
The Following User Says Thank You to CSG Mike For This Useful Post: | norcalpb (12-29-2023) |
01-07-2024, 06:43 PM | #55 |
sure, I get cross section, but those don't look like they're much less than my vents. Or I'm just misremembering my vents.
Similar Threads | ||||
Coil pack issue, pls help | Limitz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 09-19-2022 12:17 AM |
Varis V1 CF Cooling Hood | beltax90 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 09-04-2020 07:33 PM |
Strange issue - looking for suggestions - Possible DI or Coil pack problem | sfruski | Engine, Exhaust, Transmission | 6 | 10-02-2018 01:07 PM |
Overheating / Cooling System Basics | Rennmeister | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 11-08-2017 05:16 PM |
FS: VARIS cooling bonnet hood 2 | Chris6052 | Canada Classifieds | 10 | 08-18-2017 07:59 PM |
